block heaters
Old Nov 8, 2007 | 07:57 PM
c00nhunterjoe's Avatar
c00nhunterjoe
block heaters
after a whole night on the plug in 15 degree weather, how warm is your heat on startup? do you have a hot truck? or is it just warm?
Old Nov 8, 2007 | 08:50 PM
FARM69's Avatar
FARM69
If I remember right mine is just warm. It's not blazin hot but it's enough to start getting the ice off the windshield.
Old Nov 8, 2007 | 09:00 PM
MADVAN's Avatar
MADVAN
The 1000w heater will only warm the motor for the startup.
While its heating its also loosing heat from heat rise/absorb thru the rad / H-core / motor. If the thermo was to open or in bypass (stuck) you will have even less temp. The heater has no temp control on it for the same reason. If you can get 90/100* your doing real good.
You can plug the heater in on a hot summer day and it will not puke the coolant.
Bill
Old Nov 8, 2007 | 09:53 PM
IDMooseMan's Avatar
IDMooseMan
Mine is warm. It barely gets up to the "O" in NORMAL on the gauge.
Old Nov 9, 2007 | 08:06 AM
97-psd's Avatar
97-psd
mine is warm and I rarely have ice on the windshield, and warm is definitely better than hand numbing cold
Old Nov 9, 2007 | 08:21 AM
Action4478's Avatar
Action4478
Never looked at the guage, I use mine cause I live 2-3 miles from work , Its always comfortable for the short ride...
Old Nov 9, 2007 | 08:34 AM
1997F-350's Avatar
1997F-350
warm. it will keep the windshield mostly defrosted and not frozen. heater blows warm air.
Old Nov 9, 2007 | 11:12 AM
FARM69's Avatar
FARM69
With block heater plugged in it still takes a few minutes for the water temp to reach 100 on my guague.
cdrmotorsports
Sep 27, 2010 03:03 PM
KonaGrown
49
Apr 1, 2009 10:18 PM
frankster
Mar 11, 2003 07:45 AM
beartracks
Sep 14, 2001 03:29 PM
FE427TP
Jun 6, 2000 08:05 PM
