Glow plugs
Old Nov 8, 2007 | 03:17 AM
Boonebird's Avatar
Boonebird
Glow plugs
i replaced my glow plugs it still seems liek they are not work a friend of mine told me to replace a solenoid. Does any one have any idea. in the nor east its starting to get cold at night its a bear for her to start. I dont want to cause any damage. Thoughts on what i could do or check its a 1997 f350 7.3.
Old Nov 8, 2007 | 05:12 AM
Cuda_jim's Avatar
Cuda_jim
Next cold start use a screw driver and cross out the 2 big terminals on the GPR, Glow Plug Relay, for 30-60 seconds, jump in the truck and start it. If it fires up OK then you need a GPR. DO NOT USE A STARTER SOLENOID. It will fail. Get a MR99 from autozone or GPR109 from NAPA.
BTW: There is a block heater that can be plugged into a 115VAC wall outlet. It takes about 3 hours to warm the engine from dead cold. Most here use a timer so the truck is nice and toasty in the morning for work.
Old Nov 8, 2007 | 10:03 AM
Boonebird's Avatar
Boonebird
I have used it in the past. Its a pain in the butt my truck is about a 150 feet away from the house. Ill try that to see what happens. Thanks.
Old Nov 8, 2007 | 10:35 AM
ForemanES's Avatar
ForemanES
I have never once started my truck with the block heater. With a properly functioning GP system it should start fine down to the single digits.
I would not recomend the napa gpr-109 because I have replaced mine 3 times last winter under napas 1 year warranty and guess what its getting cold and this one isnt working. (click here) I would try this out if I were you.
Also did you use motorcraft glow plugs? They can be bought from autozone for less that $10 a piece. Many members here dont recomend the use of autolites or other aftermarket brands.
Old Nov 8, 2007 | 10:37 AM
ForemanES's Avatar
ForemanES
Also what motor oil are you using? If its really cold where you are it might be a good idea to switch to a lighter weight oil.
Old Nov 8, 2007 | 10:50 AM
Boonebird's Avatar
Boonebird
Yeas they where motorcraft. I wised up to that after reading what you guys had to say about autolite and what not. The ones that where in there where brand new oh well.
Old Nov 8, 2007 | 01:57 PM
Neal 97 250's Avatar
Neal 97 250
How much do the motorcraft ones go for at the stealr or wherever you got them from?
Old Nov 8, 2007 | 02:05 PM
cchildress's Avatar
cchildress
What napa calls there gpr is just a rebuilt heavy starter solenoid and can not take that much power. They will burn up and you will be replaceing them often. Like Foreman said.....I tried the same rout bc they were cheaper. Best to just buy the GPR from the stealership!
Old Nov 8, 2007 | 02:06 PM
Neal 97 250
Oh I see the price now. less than 10 each at Autozone. Sorry.
Old Nov 8, 2007 | 02:48 PM
Boonebird's Avatar
Boonebird
Stealership LOL.
Old Nov 8, 2007 | 07:39 PM
johnstoys2's Avatar
johnstoys2
the timer sounds like a great idea ! Is there a certain type of timer to use ?
Old Nov 8, 2007 | 07:47 PM
Action4478's Avatar
Action4478
Something that can handle 1000 watts .....
Old Nov 8, 2007 | 08:36 PM
kawa's Avatar
kawa
Hardware stores or Electrical outlets usually carry the heave duty timers.
I'v used one on a hot tub for years.
Old Nov 8, 2007 | 08:38 PM
Neal 97 250
Here's a thought: put the truck in the hot tub so she can be cozy all night. Show her you love her. LOL
Old Nov 9, 2007 | 07:41 AM
Action4478's Avatar
Action4478
