Fuel filter
Old Nov 8, 2007 | 03:18 AM
Boonebird's Avatar
Boonebird
Fuel filter
Where is it located on the 97 f350 7.3 stoker?
Old Nov 8, 2007 | 05:03 AM
Cuda_jim's Avatar
Cuda_jim
Under the decorative cover on the engine. It has a flip up door but It's better to remove it. You will see a 4-5 inch round cover that unscrews. Open the yellow lever on it to drain the fuel. Put a container under the front of the engine to catch it. Look at the bottom of the housing for dirt, corrosion ect. The fuel heater is in there too, it's a piece of wire that is connected in 3 places with solder...wiggle it. If it's loose or broken you can unplug it. It's a squarish looking connector is on the driver-side of the housing.
Old Nov 8, 2007 | 10:52 AM
Boonebird's Avatar
Boonebird
I went out and poped the hood and still cant find it. Any more help?
Old Nov 8, 2007 | 11:07 AM
Cuda_jim's Avatar
Cuda_jim
Look here: Thanks to TJBEGGS for the picture.
http://good-times.webshots.com/photo...ost=good-times
If you can't find it after viewing this picture you will need to send a picture of your engine so we can determine what's going on.
Old Nov 8, 2007 | 11:20 AM
Boonebird's Avatar
Boonebird
I got it know.
Old Nov 8, 2007 | 01:38 PM
Neal 97 250's Avatar
Neal 97 250
Mine didn't have the flip up cover I just had a smaller version of it. The filter is where the Carburator would be on a gasser
Old Dec 8, 2007 | 01:33 PM
fordman837000's Avatar
fordman837000
you unscrew it with a 1/2 rachet or a flat screwdriver turn it slowly though it might be on there very very tight its a round plastic cover that looks like it belongs on a gas job right in the center of the engine
