- new to 97 ford f350...a few problems, need some advice
- SCA on Wix filters on a fresh coolant flush Question
- Will the rear window from an 84 F series fit a 97 OBS?
- 97 powerstroke bogging down
- No power on hill from stop
- Start circuit problems
- Burning oil
- rattling after 20 mph
- Oil Cooler Leak
- Pyro sensor relocatiom
- oil leak from dip stick tube to pan
- 1997 F350 7.3 diesel 4wd - value?
- Engine temp light
- Transmission swap
- 97 f350 RPM's won't go over 2200
- Repair manual needed...
- 1996 starting issue, intermittent
- Obs build plans
- antifreeze leak!
- Help, Engine Skip due to Radio Interference
- Napa Gear Reduction starter
- 1995 Ford F-350 7.3 DI no pulling power
- What I found while putting in new injectors
- 1997 Ford F-250 XLT 7.3L International DIT is getting oil into fuel system....
- Engine and system maintenance
- Pulling the trigger
- 1996 F250 5 speed gear shift knob
- Testing fuel pressure
- Aftermarket Tie Rods?
- service engine light, power loss and hard shifts
