Need help NOW! Dashboard temperature low (possibly)
Old Nov 9, 2007 | 09:25 AM
eyyu's Avatar
eyyu
I left my truck sit for over a week. The outside temperature this mornign is not bad, only 40F. As I drive to work, I noticed the temperature reading is a lot lower than what I used to see. I took a long time (maybe 15 minutes) to see the needle moving. After driving 20 minutes lacal and 15 minute highway the needle is just a little bit past the minimum line of the "normal operating tem" range. After all those driving, I opened the hood and felt the top radiator hose is hot. The reservoir dose have coolant, though a little bit low. There is good heat when I turn on the heat. Also, as I was under the hood, I noticed a little smoke or oil vapor streaming out of the dipstick hole. Could there be anything wrong? or just me being too superspitious. The reason I want to know ASAP is that 3 hours from now, I have go on a 2 hour trip with the truck and I don't want to find it out in the middle of nowhere. Thanks a lot. Erwin
Old Nov 9, 2007 | 09:43 AM
61 uni's Avatar
61 uni
Mine NEVER gets past the "N" unless i'm towing.
Old Nov 9, 2007 | 09:46 AM
Neal 97 250's Avatar
Neal 97 250
The gauge seems a bit low but the factory gauges are nothing more than moving idiot lights. They are not very accurate. As long as it is in that big broad renge of NORMAL I wouldn't worry.
As far as the smoke/vapor more info needed. Does it dissipate like steam does when it is released? What color? How much? What does the dipstick read and is it a funny color?
Old Nov 9, 2007 | 09:54 AM
eyyu's Avatar
eyyu
Thanksw for quick reply. It's mor like oil smoke or vapor. I'm pretty sure it's not steam. The oil level is on it's max mark. Colore is alittle dark, I know that it's time to do the change, just didn't get to it yet. Not much, a lot less than what you see from a smoker's cigaret (not from his mouth), a little puff a time, not continous.
Old Nov 9, 2007 | 09:56 AM
Neal 97 250
I have never noticed mine doing that but if it is time to change the oil I guess it is possible. I wouldn't worry too much as long as it is running right. Maybe change the oil before you leave to be safe???
Old Nov 9, 2007 | 12:41 PM
jboard's Avatar
jboard
Mine is always right in the middle or just slightly below the middle of the normal range at operating temperature.
---------jeremy
Old Nov 9, 2007 | 12:44 PM
eyyu's Avatar
eyyu
That's what I thought it has always been and that's way it got me concerned this morning. Anyone piont me to the temperature sensor or sending unit?
---------jeremy
Old Nov 9, 2007 | 01:02 PM
Pest007's Avatar
Pest007
More than likely it could be your t-stat, there is a rubber ring that after a while wears out allowing coolant to flow, and not let the engine to warm up to normal operating temps
Old Nov 9, 2007 | 01:55 PM
Cuda_jim's Avatar
Cuda_jim
The coolant temp sensor is located just to the left of the thermostat...looking from the front of the truck. It has 1 wire going to it. Changing the sensor most likely won't fix it though. If you really want to know the engine temperature you need to get a real gage IMHO. I just got used to it. I can tell if the engine is too cold by the amount of heat that comes out of the vents. I have a small thermometer stuck in a vent. Good enough for me
Old Nov 9, 2007 | 02:09 PM
MADVAN's Avatar
MADVAN
So So So true! No one believes what you state. Its the failsafe in a OEM IH thermo (germany).
Also the PSD can have 2 coolant sensors. 1 for gauge and 1 for the light. Cuda stated location of the gauge sensor.
Bill
Old Nov 9, 2007 | 02:34 PM
tjbeggs's Avatar
tjbeggs
Bill where is the one for the light? or don't they all have them?
Old Nov 9, 2007 | 02:53 PM
MADVAN's Avatar
MADVAN
Was used up till about 96 i think in F/E series. Havent seen it in a later model (97 on).
Cuda may have 2 (96). Its on the pass side front of motor.
Bill
Old Nov 9, 2007 | 03:04 PM
Action4478's Avatar
Action4478
Bill
If its there on mine , its deep enough I wouldnt look for it...
Old Nov 9, 2007 | 03:37 PM
MADVAN's Avatar
MADVAN
Rick
Your 97 will not have it. Was used short term after the IDI. I have only seen it in 94.5. Books show up till 95/96, but think its BS. Another Ford mess. PSD has no reason for use of coolant sensor other than for the fake gauge. No point in it what so ever.
On another note (hyjack). With a scanner you cannot access coolant temp do to its not connected to pin 45 of the PCM (E-series). I allway's wondered if i tapped (gauge) the coolant ckt to the pin if it can be read on the scanner.
Does F-series have pin #45 on the PCM as a coolant sensor input? E-series has it.
Bill
Old Nov 9, 2007 | 04:47 PM
Action4478's Avatar
Action4478
I 'll look ....
