frustration as usual!
Old Nov 7, 2007 | 07:14 PM
tndiesel's Avatar
tndiesel
All I want to do is bleed the front brakes. After instructions from some of ya'll and finding the bleeder valve on passenger side I'm thinking 10-15 minutes, right? WRONG!! the flippin bleeder nut is rounded off and I'm just so frustrated mymind can't think of how to do this with it rounded off like this. Should I put a l;ittle PB blaster on there and try some pliers or something? GEEEEZ!
Old Nov 7, 2007 | 08:04 PM
IDMooseMan's Avatar
IDMooseMan
I'm partial to WD-40, myself, but it might work. Be careful with it, though. You don't want to get any into the brake fluid and contaminate it.
You might try taking a file to it. Just enough to give you some edges to work with.
Old Nov 7, 2007 | 08:06 PM
Talyn's Avatar
Talyn
need a torch and some fun times.
The other way i've been told to get them off is to weld something on it so you dont crush it with the pliars. Both of mine are frozen solid.
make sure you pick up a new bleader before you pull the old one.
basically you use a map gas, or a cutting torch (dont press the damn button! were not cutting) and heat up the area around the bleeder valve, not the valve itself, dont cherry it up to much but get it really hot.
Then take some room tempature water and slowly poor it on there. Basically the expansion and contraction should break the bleeder loose.
If you have welded something onto it, you should be able to turn it easier.
The guy i know who did that method used a laith and some brains and basically made a socket he could weld on there, and then used channel locks on it so you coudlnt round the nut off. 2 guys on it and it broke loose by hand.
But i suggest heating up the area around it to break the bond.
Propane is not hot enough btw. Thats what i tried with, to no sucssess.
The other way is simply to buy a new calliper. =)
Old Nov 7, 2007 | 08:53 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You can get replacement bleeder screws at most any parts store for about $1.50. Once you have a new one just grab the old one with some vise grips and spin it on outta there.
Old Nov 7, 2007 | 08:57 PM
tjbeggs's Avatar
tjbeggs
personally unless you know there is air in there I would wait until your done with your hay hauling. If that bleeder breaks off your in a heap of trouble.
Old Nov 7, 2007 | 09:03 PM
tndiesel's Avatar
tndiesel
Your probably right, it's just the old fluid looked pretty dirty and I thought a good flush/bleed would do it some good. The brakes feel pretty good as is. When you replace the old valve does all the fluid just come out when you take the old bleeder valve out?
Old Nov 7, 2007 | 09:08 PM
cookie88's Avatar
cookie88
FTE Emeritus
Nah. You will lose some, and they will definitely need to be bled, but you won't lose anywhere near all of it.
If it does brake, a reman caliper is only about $50.
Old Nov 7, 2007 | 09:09 PM
tjbeggs's Avatar
tjbeggs
it will come out if you let it gravity bleed for a long time or have someone help by pushing the pedal down then tightening the bleeder then letting the pedal up, loosen the bleeder and start over again pushing the pedal down..... A flush is a good thing to go just make sure you have an entire day and parts stores are open or another vehicle to drive if things go south.
Old Nov 7, 2007 | 09:11 PM
cookie88's Avatar
cookie88
FTE Emeritus
Oh, another thing. O'reilly carries a little gadget called a speed bleeder. Install them in place of all the bleed screws and it makes bleeding out the whole truck about a 20 minute job.
Old Nov 8, 2007 | 06:13 AM
tndiesel's Avatar
tndiesel
Before I realized I couldn't get the bleeder valva broke loose I went ahead and filled the MC to almost max level. It was only about halfway. So when take out the old bleeder valve to install a new one the brake fluid will just ooze out until I screw in the new one, right? I assume it won't hurt anything to ooze out all over the caliper?
Old Nov 8, 2007 | 07:42 AM
Action4478's Avatar
Action4478
Use a torch & heat the bleeder only,,,, red hot, let it cool a little , vice grips & it will come out....
Old Nov 8, 2007 | 07:47 AM
MLCinNCTX's Avatar
MLCinNCTX
You will be fine with the above. What you should have done, before filling the master cylinder, was use something like a turkey baster to empty the old fluid then fill.
Old Nov 8, 2007 | 08:05 AM
tndiesel's Avatar
tndiesel
Well then everything is normal, because I always seem to do the wrong thing before doing the right thing.
Old Nov 8, 2007 | 08:19 AM
MLCinNCTX's Avatar
MLCinNCTX
I won't say the way you did it is wrong, it is just that you can get the clean/new fluid through the system quicker when you start with the master cylinder full of clean fluid.
Get some new bleeders (if one is rounded the others are likely in bad shape) and a pair of vice grips and get to it. If you want to wait until you return from your hay trip just use the reference baster and get the fluid level correct.
Remember you never learn when it is easy, but you never forget the problems.
Old Nov 8, 2007 | 11:00 AM
tndiesel's Avatar
tndiesel
You are so right, I usually don't make the same mistakes twice.
