Well now that the old black beast is on the lot to be sold, I now have to start getting the new truck ready to last me another 200k. In the old truck I had pyro and trany gauges. The new truck is a manual so as far as I know I should not need a trany temp. I of course am putting in a new pyro. but do I put in a boost
At the same time? What does a boost gauge tell me? if Im not running any thing to wild do I realy need one?
I really only use the truck as a work vehicle/dayly driver. I pull trailers on the mountains some but I,m no speed demon.
The boost gauge isn't a "keep alive" gauge other than for your turbo if your pushing 30 psi or above. But it is a very nice gauge to have to gauge your truck efficency. If you see low boost can check for exhaust and intake leaks. Also a good indicator of problems if you have high EGT's really good to know boost number to diagnose. Plus its a cheap gauge. I would put on it.
You know it! but at least I have fun hauling the hay with the truck. in fact if it wenr for the horses I might not own a PSD I might still be driving my OBS f-150
Thanks for the in put guys! this form has so much good info!
Towing with a boost gauge is very helpful. I found that in my truck if I keep the boost between 15-20 psi the egts are managable when pulling hills. Sure I can get 30+ psi but the egts shoot up past anything safe
Where is the best place to get the 3 gauge cluster that mounts on the A pillar. How hard are they to install a wire. I am pretty dumb in this area so can anyone put it in Laymans terms?
AUTOMETER MAKES GREAT PODS. check out any vendor on here or summit or where ever you want. easy to wire up.
