Sponsored by: Real Truck
Gas vs PSD
Old Jul 5, 2011 | 09:29 AM
  #12586
Snowseeker's Avatar
Snowseeker
Originally Posted by TreySpooner65
I hear ya.. Its the strangest feeling. They are VERY heavy, especially when you are on your side and have nothing to push against to open the door.
I tried and tried to get my F150 door open and I couldnt. I ended up rolling down the drivers side power window (still working) and climbed out.
Now just imagine the truck caught fire and you only had a minute or so to get out. Thats why people say you should have an autopunch in the ashtray. For that and water escapes.
Old Jul 5, 2011 | 01:20 PM
  #12587
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Mine didnt catch fire.. luckily. But we got thrown around quite a bit. The truck flipped end over end, bed over nose. But for that reason I now have a a punch/belt cutter in my console.
Old Jul 5, 2011 | 03:44 PM
  #12588
Kajtek1's Avatar
Kajtek1
I would take his comment as "relative to the PSD." Simply because, the V10 takes less oil, and runs at higher RPMs, meaning that on the simplest level, 1 qt of oil in the V10 will be cycled and used more than 1 qt in a PSD.
That was a very simplified version of what I think he meant.
Close. My PS having 260k on the odometer doesn't burn much oil, I have to add it about once between 10,000 intervals and even that is because I never top off the oil during change to have a chance for refreshing shoot of detergents later on.
Have no idea how old the belt is, but it wasn't new when I got the truck 70k miles ago. I replaced fuel filter 60k miles ago only because I had some engine troubles, what turned out to be clogged tank strainers.
Old Jul 6, 2011 | 02:14 PM
  #12589
MDSuperDuty's Avatar
MDSuperDuty
Seeing as I can now be involved in this threads as I own a V10 why not stir that pot. No not really. Anyways I am really liking this V10 so far. Got it for a good price and wouldnt have found a diesel in that price range that I would have liked. This thing moves compared to that anemic 5.4 and drinks just a little more gasoline. I really don't care what one owns but I will say this. My friend has only owned Dodge HD pickups since I've known him. He had a 2002 reg cab cummins with a Banks chip, exhaust, and some 80hp injectors. That thing friggin moved! I'll never forget the one night crusing on the highway and he opened it up at 60mph and that thing actually broke loose from the pavement! Crazy amounts of power. I dont care what I do to my V10 it wont have that kind of power. I think the V10 is up to many tasks thrown at it (many municipalities around here have them and the 5.4) but if we were going to race a heavily modified diesel and a V10 , the diesel would probably toast a V10. Stock to stock powerplants would be fun but it always seems the diesel moves the loads better (the truck pull by some of the guys on here shows this, although the V10 does complete the job). So I like them both but will stick to the gas for now and keep it a little more simple.
I will have to go race my buddy now with his new modified Dodge.....even if I do get beat!
Old Jul 6, 2011 | 02:18 PM
  #12590
2006lariat's Avatar
2006lariat
Congrat's on the truck!
Old Jul 6, 2011 | 02:22 PM
  #12591
Super08's Avatar
Super08
Yup, not often you can find a dually short box. I think they look sharp.
Old Jul 6, 2011 | 02:42 PM
  #12592
bill11012's Avatar
bill11012
Modular motor junkie
A V10 is perfectly capable of breaking the tires free at 60. It just needs forced induction.
Old Jul 6, 2011 | 02:59 PM
  #12593
parkland's Avatar
parkland
LOL
a 4.6 could break the wheels loose at 60 with enough forced induction.
Diesel easily wins it for easy aftermarket power. Take a v10, add a supercharger, custom tuning, you are gonna spend way more than a diesel programmer. Plus, high HP diesels get good mileage, high HP gas engines generally do not.
That being said, I personally think a v10 with a turbocharger and water injection could be a really good unit. The water injection should save a lot of fuel while towing and such, while the turbo would add power when needed.
Old Jul 6, 2011 | 04:46 PM
  #12594
strokin'_tatsch's Avatar
strokin'_tatsch
I heart forced induction. This is about to go on my PSD. S466 that is fixing to have a billet wheel and a race cover and that will have a billet S594 in front of it. It will already break the tires loose at ~50mph with the stock turbo @ only 24psi due to boost leaks. What do you think it'll do at 60+psi and ~240cc more fuel?? Can you say extreme fun with the capability of towing whatever I want, whenever I want? One of these would probably rock out on a daily driven V10 @ 10psi though.
Old Jul 6, 2011 | 04:57 PM
  #12595
plgebbia's Avatar
plgebbia
Hey Travis, You must know somebody that lives reasonably close to Bill that can go pull against his V10....
That turbo looks pretty nice there Travis, How long will it be till you are using it?
Oh, BTW, I wonder how much forced induction would shorten the life of the V10? or wait, it wouldn't, their bulletproof
Old Jul 6, 2011 | 05:30 PM
  #12596
Kajtek1's Avatar
Kajtek1
Yeah, but not plugproof. I just read the topic where spark plug coming off V10 killed not only the engine, but whole truck by putting it on fire. Sad anybody has to drive bomb like that
Old Jul 6, 2011 | 05:34 PM
  #12597
parkland's Avatar
parkland
Turbocharged engines typically have tougher piston rings, pistons, and oil jet cooled piston setup. HP for racing and HP for towing are not the same thing, racing is intermittent use, and towing has a high duty cycle. Many high performance pistons are stronger than stock, but I've heard that they also wear out faster. There are many things to consider when charging the intake of and engine designed for N/A operation, many of which I probably don't know about. I think it might run nice with a little boost and custom programming. Water injection would probably REALLY help out, I imagine the v10 in a superduty would be running pretty rich at high power outputs.
Old Jul 6, 2011 | 05:54 PM
  #12598
monsterbaby's Avatar
monsterbaby
Now where is that autopunch and belt cutter again?
in a hard hit accident they don't do much good cause you won't be able to find the ashtray OR center counsel. In my case it was ok cause the passengers door no longer existed. Oh but we never have found my cell phone that was in the center counsel.
Old Jul 6, 2011 | 06:39 PM
  #12599
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Kajtek1
Generally diesel vs gassers save about 25-30% while driven, but the difference goes above 100% when you compare idle. No V10 owner will ever admit his consumption on idle, so it is hard to verify.
Years ago I run 4 cylinder engine out of 1 liter (a quart) bottle. Starting the carburated engine in colder weather it took less than 10 minutes to run it dry. That was a car making 30mpg
That figure doesn't surprise me for a cold engine - but all engines (diesel or gas) will use substantially more fuel when cold.
Both my 4V 5.4's lie-o-meter would change to reading consumption in L/hr when the speed dropped below 8km/h (5mph). The lie-o-meter on these was pretty accurate according to my hand calcs.
Once warm, at idle my modified (supercharged/intercooled/injectors etc. ~620rwhp) one would consume around 3.2l an hour at an 800rpm idle.
My unmodified one (still a 4V) would consume around 2.4l an hour @ 750rpm.
Both figures were with the air-con on and manual trans. Automatics would no doubt use slightly more fuel at idle.
I would imagine the V10 would be somewhere between those 2 figures, i.e. around 3/4 a gal an hour at idle.
Old Jul 6, 2011 | 06:44 PM
  #12600
A/Ox4's Avatar
A/Ox4
9 ECHO 1
If you dont have it you definitely cannot use it. At least if you have one you have a chance at using it. In my accident my interior was unaltered for the most part. We did eventually find my phone. It was wedged between the dash and the windshield. I had an iphone and about 1/2 of it was wedged in, and with force. It took both hands and me pushing my self off the dash with my feet to get it back. It was somehow unscratched.
