Gas vs PSD
No thanks. I'm of the opinion that when you are hundreds or thousands of miles from home and something breaks, fix it. Especially when getting back to a relative safe haven, in this cas campgrounds, is still practical. I'd much rather drop my camper there then have it stuck along side the highway in bum f**k nowhere.
It still pulled the trailer at 70 without an issue. Why would I pay to have it and my trailer towed when it runs just fine, other than a miss from one cylinder?
Neither a IAC or a COP will leave you on the side of the road.
I'm calling BS on this one. The ONLY way a single COP can keep an entire engine from running is if it grounds the +12V (and it doesn't have an integral ground), or has a direct short between the PCM input and +12V. And it would blow the fuse.
No way the engine wouldn't run whatsoever, and JUST replacing the COP fixed it.
It dam straight DID stop the vehicle and the ONLY thing wrong was 1 COP. The ECM detected to many miss fires and shut it down.
I couldn't figure out how or why either but I ended up picking Tracy up and lending him one of my vehicles for a couple days while they fixed it.
BTW, I will be interested in what he tells you cause if you get any other story then he lied to either you or Tracy.
Running it dry shouldn't hurt anything, as the lubrication is done by the oil, and gas does not have any lubricating qualities to it.
For misfire event monitoring for 2005:
"If a single cylinder is determined to be consistently misfiring in excess of the catalyst damage criteria, the fuel
injector to that cylinder will be shut off for 30 seconds to prevent catalyst damage. Up to two cylinders may be
disabled at the same time on 6 and 8 cylinder engines and one cylinder is disabled on 4 cylinder engines. This fuel
shut-off feature is used on all engines starting in the 2005 MY. After 30 seconds, the injector is re-enabled. If
misfire on that cylinder is again detected after 200 revs (about 5 to 10 seconds), the fuel injector will be shut off
again and the process will repeat until the misfire is no longer present. Note that ignition coil primary circuit failures
(see CCM section) will trigger the same type of fuel injector disablement."
http://www.motorcraftservice.com/vdi...f/OBDSM508.pdf
Further, on ignition coil monitoring:
"If an ignition coil primary circuit failure is detected for a single cylinder or coil pair, the fuel injector to that cylinder or
cylinder pair will be shut off for 30 seconds to prevent catalyst damage. Up to two cylinders may be disabled at the
same time on 6 and 8 cylinder engines and one cylinder is disabled on 4 cylinder engines. After 30 seconds, the
injector is re-enabled. If an ignition coil primary circuit failure is again detected, (about 0.10 seconds), the fuel
injector will be shut off again and the process will repeat until the fault is no longer present. Note that engine misfire
can trigger the same type of fuel injector disablement.
Now, I'm the first to admit that in-the-field observations sometimes do not follow what "the book" says. And a COP that is shorted could potentially cause the PCM to go into fits. But I suspect there was a fuse blown or some other cause that was not mentioned in idle conversation.
But this is the first time in 9 years of studying Ford's gassers that I have heard of one COP shutting down an entire engine. And by design, it doesn't happen on purpose.
Also they didn't "sell" him anything, it was under warranty.
I read what the book says Art, but I have heard from other people of being shut down from a COP failure and witnessed this one first hand. NOT saying I have heard it as being a big issue or a massive problem like say 305 Chev engines cracking blocks or the supposed massive amounts of CPS failures on 7.3s (I mean we all know that the 7.3 was just going to leave you stranded from all the massive amounts of htose that failed) But this was not the first one I have ever heard of and it was from other shops, some private some dealerships.
The tow truck driver who I also know fairly well told him this isn't the first one he had to tow in with that problem. take it for what it's worth.
but I had to jump all over that "usually"
