Sponsored by: Real Truck
Gas vs PSD
Old Jul 10, 2011 | 10:00 PM
  #12676
tgreening's Avatar
tgreening
Originally Posted by ToMang07
The reason I stayed away from the 6.0 is that you HAVE to do the "Bullet Proofing" to make it reliable: Bulletproof EGR or a Delete, Head Gaskets and Studs, and or New oil cooler if your delta was bad.
With those things done, they will last forever. Just a matter of whether you want to spend the money to do them. THEN throw in some tunes and mods and the thing is an animal.
Personally, i cna justify the $$$ for the "Bullet Proofing" to make it reliable, and I would just assume to stay out of the EPA crap.
Thats why I have the 7.3.
This is just flat out not true. I have an 06' at my shop with a 100k on it with nothing more than minor issues during it's service and it hauls heavy. Way heavier than the average owner will and on a regular basis.
Old Jul 10, 2011 | 11:11 PM
  #12677
exiled's Avatar
exiled
Originally Posted by bill11012
Neither one of those numbers is really that hot.
My point isn't the temps themselfs. Remember I let out of it when the alert on the eot sounded at 215•. Would have it gotten hotter? I dunno.
My point is that the temps did go up. I don't want to be stuck in 2nd in some narly hills pulling a load. I'll take my psd w/ its low end gobs of tq and a gear or 2 higher.
Old Jul 11, 2011 | 12:05 AM
  #12678
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by exiled
06 and 07? Just a guess.
Aight yall I made some more runs but I was empty and I shifted into 2nd. This test was just to see how long I could stand to be on the pedal without an upshift. Engine was turning 4k top speed was 45 mph. I held this up until my insight alerted me that my eot had reached 215•. I had been paying attention to the rpm and speed. Ect got to 205. Which took all of maybe a minute. So its not true that a diesel's engine fluids isn't going to run a fever if reved out and tranny not pulling. I just wasn't holding long enough. Just goes to show that the sucky gauges on our trucks doesn't show the whole picture.
This has me wondering how any of the other powertrains are pulling hills @ 55+ in 2nd gear.
The other day I was cruising down the Hwy in the heat of the day(about 103*) at a speed which shall not be mentioned. Engine was turning 2900RPM and I have 3.55 gears. I was unloaded, and again cruising for probably 20-30 miles this way. EOT was already 200* when I started this journey. EOT got up to 215*, but would not go over that. ECT settled at 214* and stayed there the whole time. Once I got to a point where the speed limit dropped to 45 and I had to slow down, the EOT dropped down to 203*(thermostat temp) and ECT to ~200* in about a minute.. So, this would back up your statement. If run hard enough a diesel can run pretty hot. Since mine is a 7.3L, it obviously won't like turning 4k RPM in stock form.. At higher RPM temps would have only gotten hotter like you said above.
On our 7.3's and 6.ohs the oil is getting heated more than normal though b/c of the HEUI(not sure what you drive). At one point during the run above I switched programs that runs less ICP than the others. Before switching tunes, cruising ICP was ~2500psi. After switching tunes, ICP dropped to about stock level which was ~1800psi. EOT dropped about 3* in less than a minute. So, ICP heats the oil up pretty significantly.. Just thought I'd throw that out there.
Old Jul 11, 2011 | 07:17 AM
  #12679
exiled's Avatar
exiled
I have a 6.0l. I bet if you had looked at the factory ECT gauge it wouldn't have moved any. Yea these engines are going to heat up when they're under load. I dunno if these temps we've seen is in a dangerious range and not the point I'm trying to make. My point is very simple if you where to be pulling a hill in first for a length of time your temps are going to rise. Probally at least 20•.
Old Jul 11, 2011 | 07:44 AM
  #12680
krewat's Avatar
krewat
FTE Leadership Emeritus
Hmm... now it's a good thing that a 6.0 made it to a whole 100K miles?
I thought 100K for a diesel was a walk in the park?
Old Jul 11, 2011 | 07:53 AM
  #12681
tgreening's Avatar
tgreening
Good to see the V10 Bible Thumpers are still out and about. My post was a simple responce to someones claim that a 6.0 HAS to have thousands of $s of work done before it can be used. It has nothing to do with the long since ridiculous V10 vs Every Other Engine on the Planet debate.
Old Jul 11, 2011 | 09:22 AM
  #12682
krewat's Avatar
krewat
I thought it was interesting that a particular 6.0 was lauded as having reached 100K miles. Without any work.
Old Jul 11, 2011 | 09:45 AM
  #12683
ToMang07's Avatar
ToMang07
Never said it HAD to be done. Only has the be done if you want to be SURE you won't blow the engine up. (Or WHEN you do.) I'm sure there's a few that never need headgaskets... but that seems to be the exception not the rule. Ones that haven't had then YET...is just that...YET.
I know a couple that have, buddy at work has one with 115k ish, works it hard, (Farmer) I just don't trust the design, and hate the EPA. It's too finicky, and unless you have gauges and are VERY **** about monitoring everything and fluid changes... it's a ticking time bomb. I just wanna mod and have fun. Don't want to frig with all the EPA crap and dump a load of money into it just to make it reliable.
Don;t get me wrong, the 6.0 is a GREAT engine after it's been bullitproofed. Just too much risk if it hasn't.
Flamesuit on.
Old Jul 11, 2011 | 09:48 AM
  #12684
hotroddsl's Avatar
hotroddsl
Why would any one want a V-10 when you can get a diesel? That's just silly!
Old Jul 11, 2011 | 10:54 AM
  #12685
krewat's Avatar
krewat
For various reasons. Many of which do not seem to make sense to certain people. So be it.
Old Jul 11, 2011 | 11:04 AM
  #12686
LSchicago2's Avatar
LSchicago2
Because we like trucks that run all day every day without problems. Something has to tow all the broke down diesels!
http://s2.photobucket.com/albums/y25...t=e345ff71.pbw
Old Jul 11, 2011 | 12:11 PM
  #12687
hotroddsl's Avatar
hotroddsl
Please.....we out perform, out hual, out tow, out last and just plain run circles around the V-10! I'm sure it will make a fine automotive engine, I'd love to put something like that in my cobra replica! But since I wanted it to go fast I had to go with a stroked Cleveland well that and a 24 valve would have been too hard too see over! Maybe I'll put one in my little '66 coupe if I can't find that 8 valve I've been looking for to put in it, they are very tempting because people seem to be giving the danm things away! Maybe marine use.....
Old Jul 11, 2011 | 12:17 PM
  #12688
krewat's Avatar
krewat
And there are still plenty of other reasons left as to why I don't WANT a diesel.
However, it seems my wants mean I'm stupid. Or something.
Old Jul 11, 2011 | 12:24 PM
  #12689
hotroddsl's Avatar
hotroddsl
Oh now! I didn't mean to hurt your feelings, these V-10guys are still so darn sensitive, I'm sorry!
Old Jul 11, 2011 | 12:51 PM
  #12690
ToMang07's Avatar
ToMang07
Someone told me once the V-10's came with lit vanity mirrors....
