Sponsored by: Real Truck
Gas vs PSD
Old Jun 18, 2010 | 10:54 AM
  #5086
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by phillips91
I'll scan my mag and post it on here if you want me to. There is a caption that shows how much force is exerted to the wheels in each gear at peak tq and they say that having better gearing helps it put more power to the ground.
Better gearing helps, no doubt. So does being a ****-ton of less weight.
Old Jun 18, 2010 | 10:55 AM
  #5087
phillips91's Avatar
phillips91
Originally Posted by ChargersFanInCO
2010 Chevrolet Camaro SS vs 2010 Dodge Challenger SRT8 vs 2011 Ford Mustang GT Comparison - Test Numbers - Motor Trend
Actually, it's the HP to Weight Ratio that makes the Mustang a screamer. NOWHERE in that article does it talk about being able to "put that torque to ground".
The Mustang is much lighter, and one will be gracing my driveway soon.
Actually I don't have to scan my mag. Just read the damn article before you post it to prove me wrong......
From the first paragraph on page 2.
It's also equipped with the shortest optional axle ratio (the $395 3.73:1 setup), so its overall gearing is more than 20 percent shorter than the others' in the lower gears (it'll chirp its tires on the 2-3 upshift). That means that despite generating 30 fewer pound-feet of peak torque, the force this powertrain delivers to the rear tire contact patches maxes out at 2364 pounds in first gear (at 24 mph), whereas the Challenger peaks at 2016, and the Camaro just 1826.
Old Jun 18, 2010 | 11:00 AM
  #5088
ChargersFanInCO
Oops...you got me on a car...(A car I like very much and will be owning when the dealer gets a GT coupe in RED) Now lets get back to your 5.4l vs a 6.4, twin turbo diesel....
Old Jun 18, 2010 | 11:16 AM
  #5089
4ord06's Avatar
4ord06
Originally Posted by Jrfish007
1.you can keep your algae poop, I'll burn the algae . BTW, the new 6.2 is E80 where as the 6.7 is B20. But putting ethanol into the tank is alcohol abuse in my book.
B20? Bah, only if you regard the manufacturers recommendations. Algea is only one of the many BIO options for Diesel.
2. No one here is talking about tuning or modding. That is a different story all together.
Sounds like another sore subject. Sorry. Please explain your modding capabilities on a V10 just from a simple tune? I'd be interested in knowing. Really.
3. Diesel engines are built with heavier components because the fuel expands more creating more pressure build up in the cylinder. This causes more force on the piston and more power (i.e. torque). This requires sturdier components, it a cause and effect thing, not really a big advantage. Also remember those stronger components weigh more, which means they have bigger parasitic loses.
That is a very good point. 4-600 more pounds can be seen when comparing gas vs diesel power plants, But we already know that as this discussion started sometime ago with a PSD out weighting a V10 at the very beginning.
4. What makes you think gas engines can't go under water? Jeeps do it all the time.
My point was the entire ignition system i.e sparkplugs/ cap and rotor.... I seen plenty of jeeps in water. Just not under it while continuing to run
5. Comparing the V10 to the Scorpio is a bad idea, you're talking about comparing a brand new engine with the latest and greatest technology to an engine designed almost 10 years ago (more then 10 really because it's just an expanded modular engine).
I wanted to compare the latest engines...sorry.
6. And yes, we have already agreed the diesel is the better choice for towing, so most semi's are diesel.
Cool.
the main arguments at this point in this thread are:
1. which is faster when towing up a hill and
2. gas is better for the the occasional tower who doesn't drive to many miles, unless they have $7k burning a hole in their pocket.
Hard to determine when there are 5 million plus responses...
Actually turbos were invented for airplanes. Before jet engines came out airplanes were limited in speed because the air was too thin at high altitudes. Diesels trucks didn't get them until about 20 years after planes.
Your hp and tq numbers are correct, but power at the crank means nothing. Tq to the wheels is what gets a load moving and keeps it moving. That is why my 5.4 with a 5 speed manual and 4.10 gears will get a load moving faster and easier than a 6.4 with a ts and 3.55 gears.
The mod motors make 80% of peak torque at 1,000 rpm. Let's say the 6.4 makes 90% of peak torque at 1,000 rpm(very generous number). My 5.4 has a 5.72 1st gear and 4.10 gear for a 23.45 final drive ratio. It makes 350 peak torque, so 280 at 1,000 rpm's. The 6.4 has a 3.11 1st gear and a 3.55 rear end for an 11.0 final drive ratio. It makes 650 peak torque, so 585 at 1,000 rpm. The hp numbers at 1,000 rpms are 53 for my 5.4 and 111 for the 6.4. My 5.4 will be turning 43 wheel rpm and the 6.4 will be turning 91 wheel rpm(roughly 3 mph for me and 6 mph for the 6.4).
Rear wheel tq is as follows
53 hp x 5252/43 wheel rpms=6,473 for my 5.4
111 hp x 5252/91 wheel rpms=6,406 for the 6.4.
If my 5.4 can do that, imagine what a properly geared v10 can do
I think you will find more turbos on Diesel power plants than anyother type. Which was the basis of my comment. Not that turbos were design specifically with the Diesel engine inmind...initially.
>>>mountaineer27
thats a true statement but diesel isnt oil. its a solvent too and will mix with water the same as gas
Hmm..Diesel fuel is a lubricant. Tis why some fuel injection systems rely on it to lubricate the system as its running. Hard to classify a solvent with that. But I need to do more research.
Old Jun 18, 2010 | 11:24 AM
  #5090
Lead Head's Avatar
Lead Head
Diesel fuel does offer far more lubricity then gasoline, but saying its not a solvent either is not true. It works quite well removing all the nasty dirt and grease off my motorcycles air filter. Many other people use it as a parts cleaner too since it isn't as destructive as gasoline on foam/plastic parts.
Old Jun 18, 2010 | 11:25 AM
  #5091
4ord06's Avatar
4ord06
It's a good read. Diesel fuel - Wikipedia, the free encyclopedia
  #5092
krewat's Avatar
krewat
FTE Leadership Emeritus
Diesel is definitely a "solvent" in terms of it's degreasing ability
Ever wash something in kerosene?
Old Jun 18, 2010 | 11:26 AM
  #5093
4ord06's Avatar
4ord06
Kind of like WD40 right.... Cleans well but lubricates.
Old Jun 18, 2010 | 11:58 AM
  #5094
Lead Head's Avatar
Lead Head
Originally Posted by 4ord06
This thread is getting pointless....So I'll add more to the rant.
I am an advocate of DIESEL technology. I only wish I new more.
Advantages over GAS
Runs LEAN mixtures. This means less fuel.
Modern direct injected gasoline engines can also run very very lean mixtures.
BIO fuel READY. Who else can say there truck is burning the poop created by Algea?
Gasoline engines will readily burn ethanol.
Easily tuneable. Upwards of 150-350+ HP and 500lbs of TQ from a TUNE. Not counting Nitrous, CNG, Propane (Not recommended).
That is correct for a turbo diesel, but not for an N/A diesel. Likewise tuning an N/A gas engine won't get you much, but tuning a turbo gasoline engine will net you very similar gains to a turbo diesel.
Diesel TRUCK motors are built with heavy dutier components.
You're right there, but gasoline engines don't beat on their internal components nearly as hard.
High compressioon ratios are DIESEL. Higher compression equals higher energy...
For N/A applications yes, but with modern high boost diesels (and turbocharged gasoline engines) compression ratios are coming down. For example, the new 6.7 PSD runs only 16.2:1 compression compared to the 22:1 of an IDI.
With the right air intake....you can even run it underwater.
A gasoline engine can run under water too, you just need properly sealed plug wires (or COP units). Not sure how this really applies to anything automotive related however.
A heavily modified Diesel truck has much better street manners in comparision to a GAS machine making the same power. I'm talking over 500HP here.
Really now? You mean like the 638HP Stock Corvette ZR1 that can easily achieve 25MPG + on the highway, and is known for being extremely docile around town? Or do you mean the ultra high boost diesels that have obscene amounts of turbo lag, blow black smoke everywhere and that need the EGTs constantly monitored to prevent burning them up?
Turbos were desiged for DIESELs.
Their first applications were in high altitude gasoline engines - ex aircraft.
Gas is a solvent. One teaspoon will contaminate 100,000 gallons of water. Oil...just floats. Look at BP. Think you can clean GAS outta the gulf?
That stuff floating around in the gulf certainly isn't diesel either
Diesel is being used by the Navy in Jets...I'm not aware of any 89 Oct Jets are you? Seriously? I'd like to know.
The main reason is because diesel fuel is much harder to ignite if its leaking out of a fuel tank.
HP and TORQUE is readily available at LOWER RPM. Who wants to hit 4500RPM anyways to meet max Horsepower?
Vehicle Specifications and Options - Ford Commercial Trucks
6.8 Horsepower 362hp @ 4,750RPM
Torque 457 lb.-ft. @ 3,250RPM
6.4 Horsepower 350hp @ 3,000RPM
Torque 650 lb.-ft. @ 2,000RPM
Granted, I am only looking at Ford and the Scorpion Diesel isn't listed which is why I reference the 6.4.
A turbocharged gasoline can just as easily make peak torque down low. For example, a 1989 Chrysler Turbo II engine makes 170 lb-ft @ 2400 RPM. Modern turbocharged gasoline engines can make peak torque as low as 1800 RPM (perhaps even lower in some cases)
How many gas fed Freight liners do you see going down the highway at 80MPH?
You got me.
Hope that clears some things up
Old Jun 18, 2010 | 12:04 PM
  #5095
phillips91's Avatar
phillips91
Whether it is a car, truck, motorcycle or whatever else it is, the same principal applies. No matter how much hp or tq you generate at the crankshaft, it doesn't mean a thing unless you can put it to the ground. The point of the mustang article(in the mag they break it down in all gears, not just first like the webpage) is to show that with the proper gearing a car/truck with less hp and tq at the crank can put more power to the ground.
Go back and read my reply to the other guy about the 5.4 and 6.4. I never said I could outpull it with a 5.4. I said that because of gearing it can get a load moving easier. One of the main arguments against gassers for the last 20 years has been that they can't get a load moving as easily as a diesel. With past generations technology, that is true. Just look at the video of Mike with his 4 speed auto and 3.73 geared v10. He didn't have the low rpm power to get the load moving and get the engine in the peak power band. That same tranny and rear end combo wouldn't affect a diesel because it is already in it's peak power band as soon as you press the gas pedal. With the newer trannys having better gearing, that eliminates that part of the equation. I took a 5.4 and outpulled Mike's v10, the 7.3 in the video(and the 7.3 in my driveway) and with more road I wouldn't have been but about 10 mph behind the 6.0 and 6.4(I was only 15 mph behind them, even with a shorter road). All because of one word. Gearing.
Old Jun 18, 2010 | 12:12 PM
  #5096
Jrfish007's Avatar
Jrfish007
Cool.
1. well... whatever. I didn't buy a V10 with being green in mind, I was only concerned about the green in my wallet.
2. ehh... the modding isn't a sore subject. It's pretty simple really, on a turbo engine (gas or diesel) you turn up the boost. On a N/A engine it's not so simple. So of course the PSD will out mod the V10, that's simple. For that reason I don't see much point going down that road, because a turbo engine will always be easier to mod, just replace some controller and make more power. the only possible method to keep up will be to say that with that $7k I save, I buy a supercharger. But that wouldn't make sense, just buy the PSD from the start and still make more power.
3. True points.
4. V10's don't have caps and rotor's, like most modern cars/trucks. while you do have point, I still don't think a PSD would be very good under water with all the electronics. Your probably referencing older vehicles in which case you may have a point.
5. I'm just saying that because some people are comparing the V10 to say the 7.3, which doesn't make sense to me. It's like comparing an old muscle car to a modern Ferrari. They were built for different markets. Just like the 7.3 and V10 where built and designed under different economics and for different markets at different times.
6. Yup, diesel is the better choice, I just wish it didn't cost $7k. If the PSD was $1k, I would have gotten one without a second thought.
  #5097
ChargersFanInCO
Not exactly...If that Mustang weighed another 1500lbs, the Camaro would have ate it for lunch. Even if you had no drivetrain loss it wouldn't matter if the torque and horsepower numbers are lower than an equally weighted vehicle. It's part gearing, but it's also a lower weight that helped that 'stang. The Mustang's saving grace is the hp/weight ratio. There is no substitute for hp/torque numbers. You can gear a V10 to a 7.87 if you'd like, and climb a tree with it...then lets see if you can go any faster than 65mph. The 6.4 makes SIX HUNDRED AND FIFTY lb/ft of low end torque. The V10 is 400-something at damn near redline. Period.
Old Jun 18, 2010 | 12:16 PM
  #5098
ChargersFanInCO
Would love to continue the discussion, but I'm off to a call...
Old Jun 18, 2010 | 12:21 PM
  #5099
Jrfish007's Avatar
Jrfish007
Actually it's max torque is at 3250 RPM, not even close to the 5200 redline. And it makes 90% of that at 1500 RPM. The fact that it's a V10 and not V8 allows Ford to put a more aggressive cam in and move the power band down. You can put a more aggressive cam in a V8, but it will idle like crap, the extra cylinders help smooth that idle out. This is why so many manufactures used to make V12's for high end cars.
And that's 457 ft-lb, about 200 less than the 6.4.
Old Jun 18, 2010 | 12:29 PM
  #5100
phillips91's Avatar
phillips91
Go back and read my reply again. I said with the proper gearing a car/truck with less crank hp/tq can put more power to the ground. Regardless of weight or times in the 1/4, the Mustang would have still put more power to the ground even if it was 3,000 lbs heavier. It would have been slower, but it would have still made less power at the crank and more power at the wheels. And for the record, the Mustang was only 200 lbs less than the Camaro. Can you tell a difference in how your truck runs if you have one passenger with you?
Then go back and read my calculations. Even though the 6.4 has 650 lbs of tq at the crank, the v10 still put more power to the ground when both were ran at peak tq doing the same speed. You can take an engine with 10,000 lbs of torque at the crank at 1,000 rpm's, but if it redlines at 1,000 rpm and you have to run a crazy tall gear just to turn 65 mph, then you are going to put less power to the ground than a v10 with 457 tq. It's a pretty simple equation. When you run out of rpm's you have to shift to a taller gear to go faster. When you switch to a taller gear you are still making the same power at the crank but much less at the wheels. The more times you have to shift, the more power you are losing to the wheels. The psd has a redline about half of what the v10 is, so it has to shift more to do the same speed.
