If a v-10 is faster than a PSD who cares, just add a simple programmer and light mods and the PSD will be untouchable. Im sure most of the people on here who research about their truck certainly don't drive stock anyway. all things the same, you can add a programmer to a gas engine and get minimal power gains but better shifting, add a programmer to a diesel and you just found yourself a whole new truck you have never seen before.
The die hard Ford fans didn't, they went gas. You just don't hear about them anymore because they got tired of threads like this
As for much of the 6.0's troubles being the dealer techs, well, yeah, that was a large part of it, methinks.
I have had no issues, with any of my Fords Gas or Diesel. I want a Duramax, that motor is quite possibly the best motor in the last 20 years. it had its minor problems but they are few and far between.
I want to build my 7.3 but for the cost a Used duramax with tuning and built trans is way below the cost after selling my truck then building my 7.3.
the 6.0's main downfall was the lack of head bolts per cylinder.
the 500 hp generated from such a motor is very modest. its 2.5x the size of the 5.9's, with < 2x the hp, BUT 3x the amount of torque. . . . the 14L ISM cummins is rated at 435hp at 600 rpm. 600 rpm!. it has a torque peak of just under 2,000 lb/ft at 1250 rpm, with factory redline of 2400-ish. its peak hp is a little over 500, so from 600 rpm to 2400 rpm it virtually has between 435 and ~500-525 hp. . . .
try again, your credibility on cummins goes out the window with this post.
I shouldn't need to tell you why but I will. The ISM cummins is NOT 14L never has been. It is also not rated at anywhere near 435hp. It is ACTUALLY rated at 280hp at 500rpm and it's torque rating is is 1150-1550 at 1200rpm (no where near 2000ft/lbs)
Now if your talking 14L then the N14 is rated at 310 @ 525rpm and 1250-1850ft/lbs at 1200
so what you ACTUALLY should have been quoting was the isx which is 14.9L
Rob, correct me if I'm wrong, but I thought when you get the new engines in a semi, you have options on horsepower. It could range from around 300HP up to perhaps 600HP, depending on the engine. I'm assuming the difference would be in the injectors, turbo, and tuning. In fact, with the right computer, program, and the right person using it, you can tune a big truck in much the same way as a PSD, correct?
The 6.7's number can be higher than listed if they've had the 400 flash done by the dealer.
Now what is the weight difference between the V-10, and PSD trucks?
My 2008 F-250 4X4 super cab short bed with my bumpers and usual crap, filled with gas, weighs 8100. I would expect a stock diesel with stock bumpers to be close to that number as well. My front bumper weighs around 275 and the rear is around 250. My tool box with crap probably weighs another 300 easy.
the 500 hp generated from such a motor is very modest. its 2.5x the size of the 5.9's, with < 2x the hp, BUT 3x the amount of torque. . . . the 14L ISM cummins is rated at 435hp at 600 rpm. 600 rpm!. it has a torque peak of just under 2,000 lb/ft at 1250 rpm, with factory redline of 2400-ish. its peak hp is a little over 500, so from 600 rpm to 2400 rpm it virtually has between 435 and ~500-525 hp. . . .thats almost its hp max from idle to redline.
Either I'm reading something wrong, or both of you are going to have to explain some math to me.
By my calculations, 280 hp @ 500 rpm would yield over 2,900 ft-lbs of torque at that speed, 435 hp @ 600 rpm would give over 3,800 ft-lbs, and 310 hp @ 525 rpm would be over 3100 ft-lbs--all waaaaaaaay above the peak torque numbers you are listing.
I would think that if some thought went into the tuning and it was done sensable then longevity could be increased. Going nuts w/ the tuning w/ out upgrading the parts that get stressed is just stupid and will no doubt cause failure. I think its safe to say that the tunes on this trucks from the factory are alittle mild. Alittle tuning can improve everthing across the board to suit your actual driving habits. That's the one thing the factory can't program for. Its inpossible to have a tune to best all of our driving habits. But the saying is wanna play you gotta pay.
tuning on highway tractors is less popular than pickups.
1st off, they get inspected all the time, so hacking off emission parts is not an option.
2nd, I met a dude that threw on a 50 HP chip on his 550 CAT PETE, and drivetrain problems developed within days. The truck was 2 weeks old.
3rd, we get away with big chips cause we're driving pickups around like toys. A semi is almost always hauling weight, so how can you really boost power without crazy EGT's and other problems?
Actually, turning up a semi is quite common, after the warranty is up. I asked Rob this question because I figured he'd know better than me, but semi engines, be it Detroit, Cummins, Caterpillar, Volvo, Mercedes, International, whatever, come available with different horsepower ratings. Same basic engine, just different tuning I assume, to get the HP you're looking for. As for longevity, assuming you maintain them, they're good for over a million miles. 600HP is the highest I have heard of. To go above that mark, requires more work and money.
