Gas vs PSD
HP defines the amount of work a particular power plant is able to do over time. If you're an engineer looking for a minimum acceptable standard for a certain task which needs to be accomplished, you will define the job by the HP required to accomplish the task. Then you can move on to selecting the appropriate power plant to meet those needs.
In electrical systems, the force is voltage and the flow is current. Combine the two for power, measured in watts.
In mechanical systems, the (rotational) force is torque and the flow is rpm. Combine the two for power, which is measured in horsepower.
With HP and gearing, you can create any torque you desire.
TQ is a measurement of the power being applied, but without RPM's is meaningless.
Lets play a game, you and I both have a go kart, and whatever gears we could ever imagine.
we both have 200 lb engines that make 100 HP. Mine makes it at 2000 RPM and yours makes it at 5000 RPM. Whos will be able to go faster?
It will be the same. HP is an absolute measure of power. You can use gears to get the most of the engine, but HP is HP.
HP IS the ability to do work.
when you say " 350 hp associated with 700 lb/ft of torque can do much more work than 350 hp associated with 350 lb/ft of torque." , you are mistaken.
It in fact CAN do the same work, just not at the same RPM.
no, im not mistaken. you look at the dyno curves of the motor with 700 lb/ft of torque, it will have closer to the max hp possible longer than the motor with only 350 lb/ft. we already went over this. . . .the 14L cummins and my motor are of identical design. . .one is just scaled down to 5.9 to fit into a pickup truck. we both have 500 hp (i actually have more cuz mine is at the wheels) but ill never tow what that big motor can tow. why? because the larger motor makes 1500 lb/ft of torque OR MORE. . . .which means he's got near-max hp off idle to redline. this means greater towing ability. everyone who says im mistaken thinks that the motor magically sits in its "peak hp" rpm. . .or that infinite gearing/rpm makes up for a lesser torque value. . . THAT is mistaken. while accelerating, the 350lb/ft motor might only be at that rpm <20% of the time, perhaps close to 40% at WOT acceleration. if you crack a downshift, you obviously are putting the motor closer to its peak. . . .i dont have to downshift because my 1000 lb/ft of torque makes my hp curve look like a giant mesa. . .giving me near-max hp throughout 1/2 my rpm range. believe me, i get it
.the 6.7 cummins has been an option in fords heaviest duty applications for years now. ive seen them with my own eyes, and the info is all over the net. im unaware of their future plans to use the motor, but theyve used it for years.
When the V10 came out, and especially after it got it's "PI head" performance boost, the torque curve, compared to ever other gasser out there, especially GM or Mopar, was almost flat, for a gasser. The V10 puts out 80% of it's peak torque at only 1000RPM. Given any "normal" torque converter, 1000RPM is no where near where the RPMs go when you just floor it when towing. More like 1500-1700, which is more like 85-90% of the peak torque of the V10.
So yes, comparing "peak HP" or even "peak torque" can not be the sole reason to buy a certain engine. However, that's a double-edged sword. It works in one way, but in others, not so much.
When you compare the "low" HP figure of the V10 compared to the Dodge Hemi, it's pretty clear that the V10 will do much better under load.
The diesels do a bit better, in that the torque curve is basically flat. Once the turbo comes in (after the initial lag), that torque is THERE.
That could be true, except for the head bolt/gasket problems that had nothing to do with emissions.
hehe that it was. . .
You are quite correct. Matter of fact, I will go a bit further.
dont see anything i disagree with here. . .large displacment v10 would naturally outperform smaller displacement gassers of the same hp. i never said the v10 wasnt impressive when comparing it to other gassers available.
That could be true, except for the head bolt/gasket problems that had nothing to do with emissions. i cant speak for everyone, but many a head gasket failures come from failed egr coolers/overheating/hydro-lock problems. i know a few guys who hot rod their 6.0's studded and deleted, one of those guys runs in the 10's with beefy connecting rods (i would drive one w/ a zf6 in a heartbeat), and others who keep stock tunes and do the deletes just so they avoid problems. ive said it before, the 6.0 is an excellent motor built upon a very reliable injection platform. . .but studs and deletes are a must.
But I will still say that EGR coolers be damned, the 6.0 had head bolt stretch issues that had nothing to do with green-stuff ingestion. It wasn't caused by ingesting coolant, but it DID cause coolant ingestion.
But I could be wrong
I think you have HP and TQ mixed up.
If it could make 500 HP at 1000 RPM, it should be making close to 1000 hp at 2000 RPM.
Like hp to find the wattage you mutiply the amps by volts. Your amps will increase as load does. The harder you pull the higher the amps. Looking back at what I said it is messed up. I was trying to compare a 30amp 220 lamp with lower wattage and it being brighter. Volt is like rpms but in pulses and amps is like tq. Amps is what kills not volts.
I reckon I'll drop this from my explaintion as it doesn't work.
my point, in a nutshell, is the motor was designed to make 500 hp, not the 1000 hp "on paper" that it COULD make with such a torque rating. the guys modding their rigs are taking greater advantage of the huge displacement diesels copious amount of torque across the board. so yes, a modded truck will do just what you said. make 500 hp near idle, and 2-3x that up to a similar-to-stock redline.
Funny thing is that James Watt came up with the term and accepted value of horsepower.
THANKS JAMES
