thanks , bought an 03 guess I should have reserched it first.............
That is only the 05+ Pickup though. The Ex never got the 3V V10 becuase 05 was the last year.
Originally Posted by Kajtek1
This is about 2011 models, so not directly related to original dispute, but would that make you wonder how diesels really compare to gassers in Ford engineer mind....
Fifth wheel towing F350 dually gas 14,600lbs.
Fifth wheel towing F350 dually Diesel 20,300 lbs.
That is the 6.2... The V10 can still tow 33,000 lbs.
Tell ya what P-nut any time. I educate you on the ability of the 6.0. until then do your homework and go watch some video of the 6.0 pulling.
I dont believe your account. I'd believe you had troubles but come on now. 3 engines failing with in 18k. Dude nobody is ever going to buy that. The odds of just 1 failing that fast is off the chart. 3? why dont you just quit with the fairy tales? On top of this story you claim to have other problems that didnt require a new engine. Please......
I think what a couple of things need to be taken into account from P-Nuts story.
Doesn't look like V10 exist for the year. No more plugs fishing
The 6.2 offers 385 HP. What is your V10 rated?
Its still in the F450-750.
The 6.2 is every bit as (un)likly to blow a plug as the 3V V10 and has 16 of them.
My V10s? One is rated at 265 and the PSD made 215 that year.
The other is at 310 ( the PSD made 250 that year) .
If you mean weight ratings, I would have to look. All I care about is staying under my GVWR. If I can hitch up to something and not be over I will pull it. Sometimes I do go over though.. Its not something I set out to do, but sometimes I will load up just to find that I'm way heaveir than I thought I would be.
Be *******es about it. The truck was 100% stock and couldn't hack 40k. Want to see the copy of the check from ford motor company buying back my old POS PSD?
I say we put a chain to each engine and throw it overboard and see which one holds the ship better.
7.3L every time on that one
Originally Posted by exiled
Thanks. I find myself doing it often. Lol. I have to keep reminding myself.
We all need to take that advise sometimes
Originally Posted by bill11012
You should head up to the pull off in Ohio thats coming up.
I'd like to, but it's not around the corner.....
I don't at all deny your case.... but if the 6.0L was as bad as you say, how do you acount for the thousands on thousands that are 100% OK?
3 motors in that time means it was some prize winning moron working on it! There is just no other way to explain it.
