Sponsored by: Real Truck
Gas vs PSD
Old May 21, 2011 | 01:32 PM
  #11536
Super08's Avatar
Super08
You won't get an argument from me about torque. That is why diesel engines are the towing kings. For me the gas engine just makes more sense and is a better match for my needs.
Old May 21, 2011 | 03:07 PM
  #11537
Snowseeker's Avatar
Snowseeker
Originally Posted by Super08
diesel engines are kings.
I think thats the end of the thread!
Old May 21, 2011 | 03:12 PM
  #11538
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by exiled
I forgot to mention that these guys doesn't know what watts/hp is. You can't judge 2 systems based on watts/hp if the factors are different. They don't relize that yet.
I.E you can clearly see how either a 60/100 watt on 120v circuit will perform. But now change it to. A 60w 220v and a 80w 120v. How does that compare? Volts is your pps "rms" amps is your "tq". The system has changed. That 60w on the 220v tells you how the power ismoving thru that system. Prolly has more amps.
Since the gasser is making 35 more hp at 1 1/2 the time and at least 25% less tq turning the rpms. You can't say oh that 6.8 is more power cause it all about the hp. Wrong.
But you don't run a 60w light bulb from 1 volt through 110 volts neither.
I get what you're saying (sort of), but you're comparing a static supply coupled with a static draw to an engine that operates over an entire RPM range.
To the guy who says BS to a 50% improvement in mpgs going from 3.73s to 4.88's, that's towing heavy. And it just points out how a V10 can greatly benefit when operated in a range that suits it. But never mind, we're all lying.
Old May 21, 2011 | 03:32 PM
  #11539
exiled's Avatar
exiled
You know what I'm saying. I didn't say thst electricty snd the combustion was the same. I was saying you can't rate 2 systems on dir. fferent factors by hp or watt. I made that very clear.
As far as gearing goes. When you go to a taller gear you raise the rpm to keep the same speed everything else being the same. Doing that is raising fuel useage. We all know that. If you have found a way to use less fuel and run more rpms get a pat. You'll be a rich man. Taller gears take more rpm to turn simple as that. The taller gear transfers more tq to ground. But it cost yoy more fuel. You can save fuel on the bottom end cause you don't have to turn as much to get going. That's all the savings there is. To run your truck at 65 mph w/ 3:73 will use less fuel than at 4:88. Heck there os a difference on the bottom line for 4.11s. Its just a few dollors for me. But then again I'm not using gears to make up a 100 ftlbs of tq. To use your sarcasism oh wait tq doesn't matter. Wrong. If that was the case you wouldn't need to lower your gears. Doesn't the math show that the gears transfer more tq per rpm than hp? Hmmmmm. Your gearing to get tq.
Old May 21, 2011 | 04:00 PM
  #11540
Johnny Langton's Avatar
Johnny Langton
Originally Posted by Snowseeker
Diesel has a hydro booster and gassers have a vacuum booster. When I was flushing my power steering/booster fluid I thought all the trucks had the hydro booster.
The 2006 F350 6.8L dually at work has hydroboost.
JL
Old May 21, 2011 | 04:02 PM
  #11541
Johnny Langton
I made a simple statement that my buddy kevin's 02 v10 put a hole in his hood w/ a sparkplug and I was told prove it or it didn't happen.
I still stand by my comment on that. Considering the thickness of the hood, and with the COP and fuel rail in the way, there is not enough force available to "launch" a plug with enough force to do this.
JL
Old May 21, 2011 | 04:04 PM
  #11542
Johnny Langton
Knowing the software and programming of these trucks, I can assure you that this is no true. More RPM's does NOT mean you are automatically going to use more fuel no matter what. Engine load has alot to do with fuel useage.
JL
Old May 21, 2011 | 04:46 PM
  #11543
Super08's Avatar
Super08
Originally Posted by PorchFarms
i would have taped that 25k to the steering wheel and traded up. in reality thats probably what the dealer was expecting him to do.
They had him... I had suggested getting a flat deck and using my truck to haul it somewhere else, but he declined. You can only do so much.
Old May 21, 2011 | 06:11 PM
  #11544
exiled's Avatar
exiled
JL
Your not the one that said anything about it. But you would lose that arguement cause it happened. And your crazy there's a lot of pressure on the combustion stroke. I know where the fuel rail is. I know what's between the coilpack and the hood. I ve seen the hood. Not pictures the hood. I've read the work order. My buddy doesn't want his stuff on line or I would post it here. But you know, if this is all yall can pick at. Hmmmmmmm
Old May 21, 2011 | 06:12 PM
  #11545
Ricohman's Avatar
Ricohman
I dumped my 6.0 before it ran out of warranty and bought a '99 V10.
I enjoyed that truck so much I bought a new 2010.
The maintenance costs and a truck I can own out of warranty are key to me. I have seen local 6.4's with problems and I'm glad I never went down that road. I may buy another diesel in the future but those motors are so expensive to repair I just can't justify it for the 4000 miles my truck is used each year on vacation or working.
Old May 21, 2011 | 06:25 PM
  #11546
Super08's Avatar
Super08
Diesel engines are the kings of every Ford shop I've been to.
Did I say that out loud?
Old May 21, 2011 | 07:25 PM
  #11547
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by william_04_x
I'm calling BS on the 50% improvement. If that were the case, every V-10 with 35's would have 4.88's.
Every V10 and 5.4 truck with 35s that really runs well does have 4.88s.
JL
All the DRW trucks have hydroboost from what I have been told.
Old May 21, 2011 | 07:27 PM
  #11548
william_04_x's Avatar
william_04_x
P-nut specifically posted that his 50% MPG improvement was unloaded.
I acknowledged that it's possible a gear change can improve mileage.
I never called "you all" liars, or even implied it.
Old May 21, 2011 | 07:59 PM
  #11549
plgebbia's Avatar
plgebbia
And of all of the persons I know that have one...I have yet to see that-and some of those trucks are tuned to make way more power than stock..
Yet, I've seen repetitive problems like I listed already with the 6.0L's.
JL
I know the 6.0L can have those issues, but I have seen 3 Duramax's with snapped cranks in the last month... and have heard of many more. I would much rather replace head gaskets than a crank.....
(there are also many times more 6.0Ls than Duramax's......)
Talk to someone who has had their Hydro-Boost fail. Or better yet, try to steer with your foot on the brake
Hydro-boost brakes are light years ahead of vacuum brakes on a diesel..... I know, I have used and worked on both.
Old May 21, 2011 | 09:12 PM
  #11550
exiled's Avatar
exiled
JL
Show me. I wanna see it. You want me to believe more rpms can = less fuel? No way. My 6.0 uses more fuel at more rpm. Dude when you hit a strain like wind, weight, a hill, or all of them yoy ADD fuel to maintain speed or gain speed. Say whatcha want. I love the idea though.
