Sponsored by: Real Truck
Gas vs PSD
Old Apr 20, 2011 | 07:58 PM
  #10891
2006lariat's Avatar
2006lariat
[quote=donovan;10243592]That is the reason the the factory computer will not let you go above 1200 degress. If you chip a diesel you need gauges.
How does the stock engine know Turbo Temp? There is no Factory Pyro on the 7.3 6.0 or 6.4.
Also if your running a "Tuned" diesel and your EGT's are at a unsafe level, alot of times it just needs more fuel. Tuners can tax stock fuel sytems and cause a lean condition. Many Cummins guys I run around with put an AirDog kit on there trucks and the EGT probs go away, Same as a PowerStroke, Not enough fuel pressure to the injectors, and it will lean it out, (high egt's) and possible failed injectors!
And The 6.0 that blew by you was just getting to the top of the hill for better cell service, to order a pizza, in texas, didnt want to wait for it! Thats how much better a Diesel is! LOL
Old Apr 20, 2011 | 08:05 PM
  #10892
pappy19's Avatar
pappy19
You've had one too many Monsters, dude. But then again, you can't help yourself....diesel is addictive and takes a while to wean off it.
Pap
Old Apr 20, 2011 | 08:10 PM
  #10893
2006lariat's Avatar
2006lariat
LOL I actually only Drink Monster with Vodka! I cant stand it! LOL
Old Apr 20, 2011 | 08:13 PM
  #10894
Zmann's Avatar
Zmann
I drink Bud Light but still my factory computer doesn't know my EGT
Old Apr 20, 2011 | 08:14 PM
  #10895
pappy19's Avatar
pappy19
Since you are an obvious 6 leaker, I understand. You are too dizzy reading your TSB's every night so you don't need Monster Energy drinks.
Pap
Old Apr 20, 2011 | 08:17 PM
  #10896
2006lariat's Avatar
2006lariat
I change oil, fuel and oil filters, work on the brakes and drive it! There is no sense worrying, if it happens it happens. Chill out, I was only givin a hard time!
Old Apr 20, 2011 | 08:18 PM
  #10897
Zmann's Avatar
Zmann
I think the 6.four has it's share of TSB's lol
I just get dizzy passing them up hill
Old Apr 20, 2011 | 08:22 PM
  #10898
pappy19's Avatar
pappy19
Not a problem, all in fun here too. I don't wish bad on any Ford owner regardless of what they drive.......even 6 leakers.
Pap
Old Apr 20, 2011 | 08:24 PM
  #10899
2006lariat's Avatar
2006lariat
[But then again, you can't help yourself....diesel is addictive and takes a while to wean off it.
Pap[/quote]
So.............Deep down Your jealous of my diesel?
Old Apr 20, 2011 | 09:19 PM
  #10900
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by exiled
Bill the problem is the head didn't have enough threads cut into it.
Thats not true. The four threads they use are strong enough to have over 100 lb ft of torque put on them without stripping.
Old Apr 20, 2011 | 09:41 PM
  #10901
pappy19's Avatar
pappy19
Pap
So.............Deep down Your jealous of my diesel?[/quote]
Adam, I have had all of the diesel fix I need: 1984 F-250 6.9, 1987 Chevy POS, 1997 F-250 7.3, 2002 F-350 7.3. I am a gasser dude till the end.
Pap
Old Apr 20, 2011 | 11:00 PM
  #10902
donovan's Avatar
donovan
easy answer
[quote=2006lariat;10245253]
Fuel tables. If you know the amount of fuel and compression you can caculate EGT. My 6.0 at stock would not go over 1200 degrees. My 6.0 had lots of power until it reached that point.
Old Apr 20, 2011 | 11:32 PM
  #10903
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
So we all agree that diesel is best right?
Old Apr 21, 2011 | 12:23 AM
  #10904
Skip1970's Avatar
Skip1970
so who would win in a dragrace? v10 or 7.3 powerstroke?
Old Apr 21, 2011 | 01:09 AM
  #10905
exiled's Avatar
exiled
You just said it. The pre 03's 4 thread heads could withstand 100+ ft of tprque applied. What your not understanding is that force is a totally different force than the heat and pressure of compression. Time and time again everyday over 10s of 1000 miles. After 03 with the 8 threads the complaints sure did shrink.
I've never torqued sparkplugs. I had a 98' 5.4 that I changed the sparkplugs every 30,000 just because I hadn't noticed the maintance guide had said 1000 miles. I hand tighten then with socket 1/8 of a turn. I did the same thing with my 04. I never had a sparkplug spit. The problem is with the design. Dry and simple.
