Sponsored by: Real Truck
Gas vs PSD
Old Apr 3, 2011 | 05:46 PM
  #10831
pappy19's Avatar
pappy19
Lets see a list of what he has done to that engine, like number of injectors and HPOP's not to mention the number of EPB valves replaced, glow plugs, CPS replacements, ad nasium. For that kind of money I could replace a V-10 short block every 200k and still be money ahead. No matter how you shake it, the V-10 will alsways come out ahead on longivity due to the low maintenance costs and low replacement costs, not to mention lower fuel costs, lower oil/fuel filter changes; you name it and the V-10 beats a diesel in almost every category.
Pap
Old Apr 3, 2011 | 06:09 PM
  #10832
Snowseeker's Avatar
Snowseeker
It was all stock right down to the air filter.
Old Apr 3, 2011 | 08:12 PM
  #10833
monsterbaby's Avatar
monsterbaby
Pap
Thanks I needed a good laugh.
NOT including injectors and other sensor you would need to replace a V10 replacment engine runs $3600. so your claiming you could replace 7 of them in the same time that one went on the base long block? Thats $25,200 NOT including labor to swap motors.
Nice try tho and thanks again for helping with my health, cause they claim a good belly laugh a day helps you stay healthy.
Old Apr 3, 2011 | 08:18 PM
  #10834
David N.'s Avatar
David N.
While extreme examples of what a particular engine has done are fun to see, they really don't give much of an indication of what can be expected from the average engine. So, I'm curious. What does everyone seriously consider the expected life of each of the engines to be? How many miles for the V10, and how many for the 7.3, 6.0, or 6.4? And just for fun, what about the 5.4?
Old Apr 3, 2011 | 08:41 PM
  #10835
MisterCMK's Avatar
MisterCMK
Nobody has mentioned the plugs the V10 spits, the coils and the exhaust manifold studs...
Old Apr 3, 2011 | 09:16 PM
  #10836
Zmann's Avatar
Zmann
actually it has been mentioned over and over not sure what pages out of the 723
loll
Old Apr 3, 2011 | 09:52 PM
  #10837
bill11012's Avatar
bill11012
Modular motor junkie
They only spit plugs when you install them wrong.
If you can read and follow basic steps, they will NEVER blow out.
Your right about the coils. They are $45 each with a lifetime warrenty from BWD and all of mine got changed the last plug swap. The Motorcrafts never last past 10 years/200K it seams.
Yea, the 11.99 stud kit is really going to break the bank...
And at over 190,000 miles mine are the factory studs still.
Run good, correct weight oil and all Motorcraft filters and they should all see well over 400K on the long block without problems.
I don't know about the 6.4 but every other engine you named has gone over that mileage many times.
The 5.4, V10 and 4.6 are all the same just so you know.
Old Apr 3, 2011 | 10:23 PM
  #10838
pappy19's Avatar
pappy19
Wrong Bozo, $2,499, FORD F250 F350 F-SERIES 6.8 LITER V10 ENGINE 2000-2001 - eBay (item 290550400339 end time Apr-04-11 14:57:52 PDT)
About the same price as rebuilt injectors and a new HPOP for a 7.3, probaly higher than that. Haven't priced them in a while. A new EBPV valve and new turbo every 100,000 miles or less will run another $1500 at least not to mention a new set of glow plugs @ $800; and that doesn't include a short block for a 7.3 @ $6,000. Yeah, go ahead and laugh cause for sure YOUR 7.3 ain't gonna make no 1 million miles.
Pap
Old Apr 3, 2011 | 10:51 PM
  #10839
MisterCMK's Avatar
MisterCMK
I am not convinced that the plug spit simply because it error in installation. If that were the case, why would the electrode gap be closed on the blown out plug?
The parts for the exhaust studs are not expensive but it certainly can be labor intensive to replace them. It just plain sucks to do. Been there, done that with both the exhaust studs and with the plug blow-outs.
Old Apr 3, 2011 | 10:53 PM
  #10840
bill11012's Avatar
bill11012
Wrong Bozo,
I don't think name calling is really necessary.
This is a fun topic but it won't be fun if it turns into name calling and fighting.
Old Apr 3, 2011 | 10:58 PM
  #10841
bill11012's Avatar
bill11012
I have never heard of one with the gap closed and that is not the norm. The only way that would happen is if the plug was launched into something that bent it. Are you saying you think it to be an internal engine problem causing them to blow?
If you have dealt with plug blow outs, its becuase it was put in wrong.
It may have been by the factory, a shop, the dealer or you but somebody messed it up. Its not hard, but you do have to follow a few basic steps.
Old Apr 3, 2011 | 11:10 PM
  #10842
MisterCMK's Avatar
MisterCMK
I did not mess up the plug install. The gap was closed on the plug after it blew out. The plug wasn't launched into anything. It has to do with the cylinder pressures.
Old Apr 3, 2011 | 11:25 PM
  #10843
bill11012's Avatar
bill11012
How much torque did you set them at?
So you saying the cylinder pressure is causing plugs to blow out? If that is the case I don't see why the end would be crushed. I also don't see why there are so many guys running nos and blowers without any trouble.
Old Apr 3, 2011 | 11:28 PM
  #10844
MisterCMK's Avatar
MisterCMK
I am posting this from my phone. I have some info on my laptop I will post tomorrow morning when I get to work.
Old Apr 3, 2011 | 11:33 PM
  #10845
BigPigDaddy's Avatar
BigPigDaddy
Are you saying that the cylinder pressure caused the electrode gap to close before the plug blew?
I hope I misunderstood that, because it is impossible for cylinder pressure to close plug gap.
