Sponsored by: Real Truck
Gas vs PSD
Old Apr 30, 2011 | 07:04 AM
  #10966
p-nut's Avatar
p-nut
Diesel. Lol.
Old Apr 30, 2011 | 07:08 AM
  #10967
p-nut's Avatar
p-nut
Originally Posted by exiled
It was emmissions that retired the 6.0. Not that anybody was complaining until they got a 6.4 then had problems of other sorts.
I'm not throwing rocks I'm just mentioning that alittle research and you can find an awsome truck that'll fit what you need. Be it a diesel or gas.
wasn't just emissions that killed the 6.0, the whole fact that it just about bankrupted ford in warranty repairs what did it in. The 6.4 was the nail in the coffin for international.
Old Apr 30, 2011 | 09:51 AM
  #10968
exiled's Avatar
exiled
I would really like to see your source of information. A lot of the 6.0 is in the 6.4. They bored the bock kept the stroke canned the fuel system went with a high pressure common rail dual egr coolers etc. The 6.0l was retired to meet emissions. Plain and simple. Ford wasn't even close to bankrupt. In 09 Ford bought navastar out of its contract. Project scorpion had been around for awhile. Ford had plans of going to an inhouse engine.
Old Apr 30, 2011 | 10:43 AM
  #10969
Tom's Avatar
Tom
We still don't have electricity and doesntnlook we'll have it anytime soon. I'd scan and post the specs out of the manual. I'd buy the lower rpm thing but the 10ks has the higher hp and higher rpm. It shows the lower than 10k to make 305hp @4200 or something like that.
Just to close the loop on this, check out THIS POST.
This is from Mike Harrison, the chief engineer for the 6.2L engine. It's the 10,000+ GVWR trucks that are de-rated on paper, but this is only due to the requirements of how they have to certify the power levels over 10,000 lbs.
Yours is rated for the full 385 HP, and the DRW trucks look like they make less power on paper. But they are the same engine; all 6.2L engines make 385 HP.
It's confusing, and we can blame our Government for that.
Old Apr 30, 2011 | 11:46 AM
  #10970
Snowseeker's Avatar
Snowseeker
Stupid government.
Old Apr 30, 2011 | 03:59 PM
  #10971
exiled's Avatar
exiled
I had it backwards I went back and reread it. I'm aware its the same engine I just don't think its programed the same. The f150 version is rated for 411 hp. There has to be a way to derive to these specs to put em on paper.
More inportant the point I was making holds true. I notice on that page you linked that Mike mentioned a trip w/ the 6.8 and 6.2ls. The 6.2l having higher revs. What I've noticed w/ the 3.73 rear is the gear search and of course that brangs higher rpm. The 4:30s sure helped there. The 6.0ls get away w/ the 3:73s because of the tq. Just like the 6.8l rear gears will make the difference.
Old Apr 30, 2011 | 05:06 PM
  #10972
Kajtek1's Avatar
Kajtek1
There is much more to engine ratings than the peak HP it can perform.
I read the story about CAT engines used in last decade widely from fire trucks, via semitrucks to diesel pushers.
The same engine could be rated at 380 HP in fire truck and 300 HP in diesel pusher.
What's the difference?
While fire truck really need peak HP for very short periods of time, it is having front radiator with good cooling. Even if it overheats for 3 minutes, it will get to the accident site.
In diesel pusher cooling is much harder to manage and those heavy vehicles can on CA 12 miles grades have gas pedal floored for 1/2 hr at the time. Manufacturers program the engine for lower output to protect it from stupid owners.
Old Apr 30, 2011 | 07:05 PM
  #10973
Super08's Avatar
Super08
Yes but in this case they are the same engine with the same power. They just took the specs at a lower rpm for the EPA thing. The engine still revs up to the same redline as the other engine with the same peak power.
Old Apr 30, 2011 | 07:20 PM
  #10974
Johnny Langton's Avatar
Johnny Langton
And there isn't a wastegate bleeding off boost, or a defueling strategy to reduce the power output.
JL
Old Apr 30, 2011 | 08:43 PM
  #10975
PorchFarms's Avatar
PorchFarms
correct me if i am wrong but didn't ford use the 6.0 in their vans past 07. the mechs got the problems worked by the end of 05 and the 06 models had the best record of all ford engines pertaining to warranty work. the 6.0 got a bad rep to begin with but now they are great engines.
Old Apr 30, 2011 | 08:50 PM
  #10976
plgebbia's Avatar
plgebbia
Ford used the 6.0L in the E-series until 09. They are a detuned version though, and the reason the vans didn't get 6.4Ls is because they wouldn't fit...
Old May 1, 2011 | 01:00 AM
  #10977
donovan's Avatar
donovan
Not mine
Not on my 6.0. The dam thing love the shop. I used it to tow and it could not stay working.
Old May 1, 2011 | 06:40 AM
  #10978
jimmyv13's Avatar
jimmyv13
Are there certain years for the V10 or 7.3L PSD that I might want to shy away from? I did find an 03 7.3L crew lariat with 148K that I am going to look at this week. He's asking 13.5...bone stock.
Old May 1, 2011 | 07:08 AM
  #10979
exiled's Avatar
exiled
To be honest. I really don't think so. If its an earlier than 03 v10 I believe I would go ahead and pull the plugs and get that out the way. Just to make sure everything there is done right. The first 7.3s had alittle trouble but they got straighten out. The 03s has the best power rateings for the 7.3s.
Old May 1, 2011 | 11:07 AM
  #10980
bill11012's Avatar
bill11012
Modular motor junkie
I would look for an 05-10 V10 becuase they had the most power.
What year is the 5.4 you have been towing it with?
