Sponsored by: Real Truck
Gas vs PSD
Old Dec 3, 2010 | 08:05 AM
  #9661
2001400ex's Avatar
2001400ex
Originally Posted by exiled
I haul w/ a diesel and don't see what your saying. My EGT go up when I go up a hill wiether fuel is added or not. When I tested the 3rd gear driving all day I had 3700-4200 rpms 1100-1200 EGTs. I haven't hurd or read anywhere where you lower your EGTs by down shifting. I've always backed off. I can see wot up hill at 4k rpms causeing high EGTs.
This being said how. Long can you hold out at 1300*? If EGTs doest back you off the trans mission temps will. I got 190* in no time when I was empty holding in 3rd. I would hate to see what would happen if loaded.
I'm going to research this. And as it always does this just may end up me trying stuff out on the road. I will be willing to post my findings if yall would like me to.
I know it sounds contrary to logic, but if you have a pyro you will see what I mean. Egts are a function of the amount of fuel, not rpms, which you kind of say in your post, yes at wot no matter the rpms, egts will be high. So when entering a mountain pass loaded, I make sure to downshift early, if I held 5th for a long time, my egts and coolant would get hotter a lot quicker than if I shift to 4th at the bottom of the hill. I don't have a pyro in my duramax, but its the exact same thing except from 6th to 5th.
Tranny temp of 190 is nothing they are built to handle 230 easy.
Old Dec 3, 2010 | 08:21 AM
  #9662
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by 2001400ex
Go back pages, 20 minutes came from a 12 mile pass several v10 guys said they will pull at full throttle like they did in the rocky mountain deal with the 2011s.
And again, that wasn't me and I had nothing to do with it
Funny how we all get lumped into one big pile
Old Dec 3, 2010 | 08:44 AM
  #9663
exiled's Avatar
exiled
Am I missing something? If you add rpms without more fuel your slowing down. Lossing momentum. Hence downshift raises rpm, but at the same throtttle position you will slow down. So I think your statement might be alittle play on words. Your not going maintain rpms if you downshift and not add fuel espeacialy up hill loaded. Not going to happen. Your going to lose momentum, and then rpms. You hit the throTtle and the rpms jump back up and then so does the EGTs.
Aight let's think this through. I was empty on flat ground, locked in 3rd. My selector was in 3rd. I kept my rpms high as I could stand. This was at the most 5 minutes. My tranny temps had already reached 190*. I would not doubt that loaded in 3rd gear @ wot the tranny would reach 230* for the rest of the climb and if you was in hilly area you would be in trouble.
Old Dec 3, 2010 | 09:04 AM
  #9664
2001400ex's Avatar
2001400ex
Have you pulled a mountain pass with a load? Basically egts level out if you keep the same amount of fuel. Tranny goes up then levels out based on the load, and coolant rises, and quickly if you are pulling a heavy load. Then the fan clutch kicks in and dropps coolant temp, while keeping tranny temp in check.
And I have seen the torqshift get to 200 doing nothing but sitting in traffic for three hours, got a pic to prove it.
Old Dec 3, 2010 | 09:05 AM
  #9665
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Art, there are only 2 piles in this discussion. If you don't like ths smell of the pile you are in, try the other pile.
Old Dec 3, 2010 | 09:25 AM
  #9666
2001400ex's Avatar
2001400ex
But you have said a 3v v10 will outpull a psd up a grade, right? And to do that admitted it takes running at 4,500 rpms or whatever, right? You might not have said "a v10 will..." but that is saying the sam thing.
No response on the egt issue?
Old Dec 3, 2010 | 09:44 AM
  #9667
tgreening's Avatar
tgreening
Originally Posted by ChargersFanInCO
Truth doesn't seem to work around here...However, you nailed them to the wall with that post.
Maybe, but no response from the other trench yet. I don't expect anyone to concede anything. I'm guessing a handful of yeah buts, I never saids, and some verbal dancing and not much else.
Kind of funny though, a bunch of grown men (?) going...
Old Dec 3, 2010 | 09:52 AM
  #9668
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by tgreening
Just a reminder. A certain someone claimed that a V10 would run 5000rpm for 20 minutes no problem, and then promptly blew one up trying to do it. ( ) I'm assuming this person had enough confidence in the engine to give a go in the first place, but after failure is giving excuses for it's failure. Ok, maintenance history noted and accepted.
If I recall there is still a V10 in the stable. One with a much better maintenance history. Now that preliminary testing is over when is the money run? IOW, back up your statement.
I know what a certain someone else would say. Run your PSD at redline along side me and I"ll do it. Thing is I don't recall anyone saying that the PSD would run at redline all day long, only that it wouldn't need to. The V10 camp though HAS made the claim that the gasser will crank 5k ad infinitum.
Personally I wouldn't run ANYthing at or near it's redline for any period of time what-so-ever. There's no way the ol' reliability / longevity graph doesn't take a serious nose dive under those conditions. There are miles, and then there are hard miles, and overall I believe one engine holds up a bit better.
And so......
The engine that blew lost oil pressure. The RPMs made it worse, but they were not the cause.
The other V10 has no tach or I would.
It upshifts at 4600, its the older less powerfull Non-PI V10.
Old Dec 3, 2010 | 10:03 AM
  #9669
krewat's Avatar
krewat
I am very careful about what I say Never said that.
I said, there are certain instances where it's POSSIBLE, and some people have actually proved it. Look at Johnny's videos for an example of that and all the hemming-and-hawing afterwards.
An excerpt from what I was saying:
"I would NOT try to pass anyone while doing it unless it was a semi at 80K struggling to get up the hill at 30MPH. But it wouldn't take 20 minutes to do so anyway. And, I would NOT run it like that with no load on it.
Do it with a STOCK diesel, and the EGTs will make you back off before that 20 minutes is up"
I meant under load. Not on flat ground. Maybe it came out wrong
But I digress.
Please stop lumping ME in with the rest of the people here who say "mine will outpull yours". I have consistently been very conservative on what I say.
However, I won't back off the idea that a V10 CAN outperform a PSD in certain situations. It's possible. It's been proven.
You can look at the evidence and accept it, or not. But please, stop trying to corner me into saying something I haven't
Old Dec 3, 2010 | 10:15 AM
  #9670
2001400ex's Avatar
2001400ex
But I digress.
Well I am not going to spend the time to go back, cause whether you said something or not doesn't matter. LOL
Which jonny videos are you referring to? I have seen them all, don't recall the specific one you cite.
And I do agree there may be some instances where a v10 can outpull a psd, though not many and it definetely is not "no matter what, the engine with the higher horsepower wins" that some dudes throw out.
But you are wrong in what you quoted above, other than the 2003/2004 psd with the older stock tune, no recent stock diesel has to worry about egts. Its a fact.
Old Dec 3, 2010 | 10:42 AM
  #9671
bill11012's Avatar
bill11012
Ok, so then the PCM defuels them to hold the EGTs down.
Right?
Old Dec 3, 2010 | 10:57 AM
  #9672
krewat's Avatar
krewat
Exactly - "some dudes" does not include me
And earlier, the 7.3, right? Because I have an '01. To be fair (as already gone through multiple times in this thread), I am comparing my '01 to a 7.3.
Right?
Waiting for an answer.
Old Dec 3, 2010 | 11:12 AM
  #9673
ChargersFanInCO's Avatar
ChargersFanInCO
But you said a V10 could run at WOT all day...You didn't say it could only do it if the engine was new, with fresh oil, a strong wind at its back, and the sun at 33-degrees on the 4th day of September...Then you went out there and blew one up in 30 seconds.
Then you try to explain it away that "The RPM's weren't the problem"....Of course not...And if you'd thrown a rod, you would be saying "But the gaping hole in the side of the block's not the problem"...it was the stuck t-stat or some other lunacy. The RPM's WERE the problem...The oil pump apparently couldn't keep up with THE HIGH RPMS!
Old Dec 3, 2010 | 11:14 AM
  #9674
exiled's Avatar
exiled
I'm going to be as fair as I can, but that requires me to answer your question w/ a question which I hate to do. Would you call going thru pigeon forge up through gatlinburg a mountain pass? I haven't been to the rockies. Wot in 3rd or any gear won't ever level off. Your going to have to let off the fuel.
Now I'm not saying you will have to back off cause of ur EGTs. I'm just saying they going to get hotter when you load that engine.
We've had em on the run for some 100s of pages now. Let's not waste this on this subject. For 1 I let up around 1100* a few times - seen 1200*. So I have to drop out of the contest I'm not so brave when it comes to pushing EGTs past 1200*. Your in the wrong kind of truck so you can't post evidence. We have a good attack on their 360 hp @5k rpms and that they aren't going to pull that for very long. If I'm right{another statement that hasn't been checked} the rev limiter won't let them keep 5k. I can't prove that yet.
  #9675
ChargersFanInCO
Yeah...you won't get a response from them...You made WAY too much sense.
