The key here is what do you define as "safe" highway speeds. I believe everywhere in Al 45 is the min. Speed limit. I've towed more than 10k with my 6150s w/ 5.4 and kept over 45 at all times. I don't know what a f250 w/ do.my poinrt is are we talking safe or lagal?
In Michigan the lowest speed allowed is 60mph on interstates where the speed limit is 70mph. I agree a 5.4, 5.3 or even lower displacements can move that weight at a lower speed and maintain that speed. Here in MI the speed limit is 70mph and you will get run over if your not traveling at that speed or near to it. A vehicle that is overloaded and not able to maintain at least the posted minimum speed should not be traveling on the highway.
Not to mention the state police EDITED in this state love to pull over vehicles that are over their GVWR and issue citations. Its a $1 per pound that a person exceeds that.
Reason: Language
Bill, I thought about all of you V10 fellas today on my way into work and this is no joke. Watched a V10 w/ duals pull out onto the highway w/ a light load behind it. They definitely had it floored. I chuckled b/c it really wasn't going anywhere and turned back around and I heard a bang and the truck had to pull over. I pulled up there to see what happened after I got my can of snuff. Hole in the oil pan. Wonder what that might have been.... I found it funny and figured it would give you V10 guys something to defend. LOL.
wow, what broke?
Originally Posted by strokin'_tatsch
Also, whenever your ready Bill my PSD is ready for some track time. It hasn't been on the track since April.
I know, I want to. I have something either in my harrnes or PCM that I have been dealing with for months that has my timing off.
As soon as the truck is running right I will take it to the track with you.
...and guess what? Semis accelerate dog slow, have low top speeds, and often have to slow down on steep grades. Why? Because they only have around 400-500HP on average. It has been discussed numerous times in here before, HP is the power an engine can do, how fast it can do work. Get two equal HP engines at the RPM they make peak power, and they will be able to pull the same load.
A 350HP gasser in 3rd gear doing 5000 RPM @ 75MPH will pull the same load just as well as a 350 diesel in 5th gear doing 2500 RPM @75MPH. It won't get as good of fuel economy, and won't sound very happy doing it, but it will still do it.
As far as the V10 that broke, I wonder how many 6.0s have done the exact same thing, or had some other kind of catastrophic failure stranding the owner?
I don't think anyone said a gasser couldn't do it I think the point that was being made was that at highways speeds with a load at its designed limit the V-10 doesn't pull the load as well as a PSD given the same circumstances. Thats all I was trying to point out in my narrow definition thru my personal experience.
Btw if your hauling over 10k with a 5.4 your grossly underpowered to be traveling on the highway and attempting to maintain a safe speed. People like you cause accidents, I know I'm a cop and have wrote accident reports for just such activities.
My truck is sitting in my driveway if you want to bring your trailer down here. I have all 3 ball sizes if it's a conventional pull and I have a 2 5/16 gooseneck if it's gooseneck trailer. I will be more than happy to pull it around for you if you want me to.
Originally Posted by exiled
I do see what your saying. The troqueshift in the v10 is the same in the psd.
You are still missing what we are saying. Yes, the tranny is the same and the gears are the same, but the ability to use those gears is not the same. What happens with the 6.0 when you pull out in 1st gear and hit 3,500 rpm? It shifts to 2nd. With the v10 it is just hitting it's powerband and will pull another 2,000 rpm before shifting. By that time the psd is shifting to 3rd.
Originally Posted by tgreening
It's pretty easy to make up your ratios to get the result you want but fact is no one is driving down the highway at a 2-1 final drive ratio. Of course it's easier climbing the hill in the lower gear, but you'll be climbing it slower. No free lunch.
I was using the 2 and 1 numbers because they are easy numbers just to show that twice the gearing will produce twice the torque, making a less powerful engine put more power to the ground. When I hit a decent sized hill at 65 mph I can downshift my 7.3 to 4th and be at the redline. That is a 4.10 final drive ratio. I can downshift my 5.4 to 3rd if I need to and still have 2,000 rpm left before I redline it. That is a 6.56 final drive ratio. So not quite a 2 to 1 ratio, but 1.6 to 1 is pretty close. That is using two trucks that both have 4.10's too.
I'm guessing that the 85,000 lb GCVW that some of them are toting around might have a bit to do with it as well, dontcha think?
You ever been run down by dead-headin semi? Slow is something those things are NOT when a driver is unladen and has places to be, and even unloaded they STILL dwarf us weight wise.
And tell us again why allll those drivers, whose very bank accounts depend on the operational costs of the vehicles they drive, have a big fat diesel under the hood rather than a big fat gasser? And brother let me tell you. There ain't nobody that can bitch about the cost of doing business like your average trucker.
Enquiring minds and all that.
Diesels get better fuel economy, that is really the only reason why. A 12 liter turbo gasoline straight 6 would have just as much low end torque, and just as much power as a 12 liter turbo diesel. The only problem is it would suck fuel down.
Semi's are always slow. Even with an empty trailer. I've been in one with an empty trailer and 65 MPH was about the end of the world. Their massive torque lets the engine live happilly at low RPM, but the lack of horsepower limits the acceleration and top speed.
I can verify this, I drove trucks for a couple years ending 6 months ago. I have spent most of my time in 2007 Kenworth T600s with Caterpillar C15 engines and 13-speed transmissions.
Even bobtail I don't think I could do 0-60 in less than 15 seconds. With a trailer I'm sure it's over 20. I have some friends who drive trucks, I'll have one of them time themselves 0-60 empty.
As Ian said, lots of torque down low and relatively low horsepower output for the large size of the engines. My 6.7L PSD has more power than many semi trucks on the road today.
I don't know about that. Lately trucks drive slower because of fuel cost and states starving for cash (and sending troopers to get some), but I remember several trips about 10 years ago. On one I was driving minivan in AZ at 85 mph and saw semi truck growing in my rear view mirror. At the time in Arizona semi truck were dictating the freeway speed and had to zigzag between slow cars.
Than another time me and my wife drove BMW to Utah to pick up older Mercedes I was buying. On the way back my wife got tailgated by semi truck. She didn't like it and took off. With unknown Mercedes I lost them at 95 mph.
In both instances the semis had big trailers.
I do see what your saying. I just haven't done a good job explaining myself. What I'm saying is that 3500 rpms is my sweet spot. I'm in my sweet spot the whole time. Just like the v10. Its like yall are saying that the psd has no sweet spot. The stragy is set up to take advantage of the rpm difference. I'm pulling w/ peak hp and tq. That's why your not walking off leaving me behind. I never said a 5.4 can't move the weight. I know it can I've owned them. I think the v10 is awesome. I have had any out pull me. That's all I'm defending. Neither engine hooked up to the torshift tranny has an advantage over me. You build a wonderful combo with idel gears and trannies and show on paper what can do what. Fact remains that unless you do so you have no advantage over me. When it comes to working that is.
Facts? You want facts? Fact: Your 2WD isn't going to take that gooseneck, let alone loaded with that excavator very far "off-road". That's a FACT. You make it sound like you go 4X4ing with a 2WD truck...In those Texas mountains...lol That is a pavement queen. And a slow one, to boot.
Thats odd, i take my 2 wheel drive further into the bush than many 4x4 trucks ever get.
Chain up the tires and learn to drive correctly.
I guess logging trucks need to have driven front wheels now to, I see them going up steep snow covered roads daily, no issue once chained up.
