Sponsored by: Real Truck
Gas vs PSD
Old Oct 7, 2010 | 02:25 AM
  #8731
ChargersFanInCO's Avatar
ChargersFanInCO
Originally Posted by Notabieberfan
Thats odd, i take my 2 wheel drive further into the bush than many 4x4 trucks ever get.
Chain up the tires and learn to drive correctly.
I guess logging trucks need to have driven front wheels now to, I see them going up steep snow covered roads daily, no issue once chained up.
Your comment leaves you WIDE OPEN for a rebuttal. Using your logic, how much further do you think one would get if they chained up all FOUR tires on a 4X4?
Old Oct 7, 2010 | 08:13 AM
  #8732
exiled's Avatar
exiled
I would not doubt that at all. There's a lot of factors that can cause loss of traction. Wet grass, loose dirt,gravels, cow manure, mud, and a whole list of stuff. A 4wd helps me maintain traction pulling a trailer through pastures and fields. I don't want to tear up my pastures making ruts when I don't have to. A grain field after its cut is a good place for slipping. If it has just rained it can get messy. I still have to get in there and load that 10k lbs 40' head and get it to the next field. Chains on drive tires are not going go make same traction as 4wd. 4 wheels pulling over 2 wins for me. Besides I don't need chains on the street and look how much time ill spend putting chains on and taking off when I go into and leave fields.4wd is much faster. Its not all about mud and fun. I learned a lession along time ago about how easy it is to loose traction. Add a trailer even empty can start a day out bad.
Old Oct 7, 2010 | 10:07 AM
  #8733
brandonward's Avatar
brandonward
I'm currently looking for a Ford F-250 or 350 crew cab. I have read several post regarding V-10 vs PSD. The problem that I'm having trouble is which to buy? I want to find one 1999-2002, because that is my price range. My needs are; I go wood cutting about three times a year and then the truck would be used for projects around the house. I'd rather have to much truck now, because who knows what I might need the truck for in the future. Any advice if I should buy a v-10 or the PSD would be helpful?
Thanks
Old Oct 7, 2010 | 10:27 AM
  #8734
dkf's Avatar
dkf
Thanks
For what you plan on using the truck for I see no reason to buy the PSD unless you just plain want it. The 7.3l trucks are still fetching decent money because of issues with the 6.0l and the emission controls on the 6.4l. You should be able to get a truck in better shape and less miles with a V10 than with a 7.3l for the same price.
Old Oct 7, 2010 | 10:43 AM
  #8735
transferred's Avatar
transferred
Thanks
If you want "too much truck" don't get a 250 as you'll only have 2,000lbs of payload. Get an F350 for an extra 1,500lbs of legal capability.
As for engines, if you're not towing then no need to spend extra for a diesel. But if you're going gas make sure it's the V10 triton as the V8 triton certainly can't be described as future proof in a heavy duty application...and don't forget to check it's a 4x4
Old Oct 7, 2010 | 10:57 AM
  #8736
ChargersFanInCO
My payload is 2750...F250, SRW, 6.4PSD. Don't know about the 99-02's though.
Old Oct 7, 2010 | 11:01 AM
  #8737
bill11012's Avatar
bill11012
Modular motor junkie
Thanks
I would go with a 2000 or newer V10. The 99s had less power.
Originally Posted by 2001400ex
But Bill, I thought v10s did not require maintenance? How can you need to "get the truck running right"
I bought this truck after the PO had just about killed it with abuse and lack of maintenace. Nothing I am having to fix on it is normal, its all damage thats having to be rapaired.
Old Oct 7, 2010 | 11:15 AM
  #8738
Kajtek1's Avatar
Kajtek1
One thing to consider with gasoline engine is smog check in states where it applies. Last gasoline El Camino always cost me at least $200 cash and lot of time at shops to pass the smog every 2 years.
Now CA makes diesel inspections as well, but they are visual only and my F450 seems to be exempt.
Old Oct 7, 2010 | 12:33 PM
  #8739
dkf's Avatar
dkf
My 04' F-250 has over 2800lbs of payload capacity.
The whole emissions thing is a money racket, even here in PA. Diesels are exempt in my county but they still charge an "Exemption Fee". (No SMOG testing in my area) Its a money racket. A diesel costs about $5 less to inspect than a gasser.
Old Oct 7, 2010 | 12:41 PM
  #8740
transferred
Yup, the 2,000 was on the low side...still, no brainer to get another 1,300lbs payload from the 350
Old Oct 7, 2010 | 01:06 PM
  #8741
ChargersFanInCO
Very low, but if the guy asking the question decided to go by what you said, and only needed 2500lbs for payload, then he'd be paying an extra $400.00 for the tags if he lived in Colorado, just for the 350. The engine's the same, transmission's the same, axle's the same, etc. Not worth the extra cost imo, and THAT is the ONLY reason I got a 250 instead of a 350, SRW, CC, 6.4...
Old Oct 7, 2010 | 01:09 PM
  #8742
ChargersFanInCO
Yep, they're bringing back the emissions testing up here for everyone. We have to do it every 2 years. It was only going to be the gassers, but people started screaming about the few idiots we have that like smoke everywhere they go, so the diesels are getting it too. I feel for the people who removed DPF's and put tuners on them. something tells me it's not going to work as designed when they slap it back on and activate whatever else hasn't been working for however long.
Old Oct 7, 2010 | 01:36 PM
  #8743
bill11012's Avatar
bill11012
In the early superdutys the F250 was 8800 GVWR and the F350 SRW was 9900 GVWR.
So an 1,100 lb diffrence.
The F250 could be as high as 3,000 payload or as low as 1,800 or so.
It depends on options. You can add 1,100 to both those numbers for the F350.
The V10 will always have around 500 lbs more payload than the PSD.
Funny thing is a 5.4 reg can 2wd Xl F250 can haul more weight than a PSD crew LB 4x4 F350.
Old Oct 7, 2010 | 02:03 PM
  #8744
dkf's Avatar
dkf
Very true. You just have determine if you want to pay the higher registration fee for the 350. Registration fees in some states are way too expensive. All you really get with a SRW 350 over a 250 is the extra labeled GVWR and 2" more block in the rear.
Old Oct 7, 2010 | 02:26 PM
  #8745
transferred
He said "because who knows what I need the truck for in the future." An F350 gives an extra 1,200lbs or so of legal capability, that's the long and short of it.
dkf...yes, very similar, rear spring pack is the only other difference I can think of...certainly annoying that some states heavily penalize the weight difference, for me it's not an option regardless (though CA is ok anyway) as all too often i'll have between one and two cubic yards of product in the bed (I've hauled 3 cu yards of topsoil in my current dually when we were missing a trailer but I won't be doing that when I'm back to SRWs.)
