Sponsored by: Real Truck
Gas vs PSD
Old Aug 21, 2010 | 08:43 AM
  #7396
bill11012's Avatar
bill11012
Modular motor junkie
Thats way off the bump stops.
Old Aug 21, 2010 | 09:47 AM
  #7397
bucci's Avatar
bucci
I had 1,960 lbs in the bed of my '03 Ram 1500 4x4 reg cab long bed and it was not on the bump stops. However, it was very close, probably an inch or less away.
800 lbs putting an F-150 on the bump stops - truck is useless.
Old Aug 21, 2010 | 10:42 AM
  #7398
ChargersFanInCO's Avatar
ChargersFanInCO
Go look at the F150 threads...4, 200lb guys in a Screw (Super Crew) and it's over GVWR... I liked my F150, but it didn't haul anything in the bed without squatting down and riding on the bump stops. Just a normal, everyday, 2008 Lariat SCrew F150 with the tow package. SCabs have a higher payload than the SCrews which is why Josh is all happy with that one. However, that one is damn near on the bump stops if not completely. The bumps stops are at, or right before level which is where that's at. Mine were at dead level. FYI, a 2010 F150 "Payload" rating for a 4X4 Screw with the 6.5' bed is 1510lbs...However, that is already exceeding the GVWR. Mine was 1280lbs for a 2008 4X4 Screw with a 6.5' bed, and at 800lbs it was on the bump stops.
Old Aug 21, 2010 | 10:49 AM
  #7399
ChargersFanInCO
Originally Posted by phillips91
Most people who bash the 5.4 have never driven one either. Or they had one with an automatic and 3.55 gear I an f-150 or they were afraid to run it over 3,000 rpm, etc. I'm not saying it's the best thing out there by any means, but it's a lot better than most want to give it credit for.
If you are ever in this area I would be more than happy to hook up to your trailer and take you for a ride. As long as it is within the legal capacity of my truck I don't mind hooking up to anyone elses trailer either.
I had a 5.4 with 3.73 gears in my F150. It was a dog in that configuration. (Again, I'm in Colorado)
Old Aug 21, 2010 | 10:51 AM
  #7400
ChargersFanInCO
lol...you're clueless about the F150, and it shows by that ^.
Old Aug 21, 2010 | 01:03 PM
  #7401
bill11012's Avatar
bill11012
Thats very true, I have never worked on or driven one.
By the time I had just my tools with me I would be well over the GVW, so I have never had any intrest in them.
So the bump stops are much higher than normal? Most things would have about 3-4" more travel before hitting the stops.
Old Aug 21, 2010 | 01:27 PM
  #7402
phillips91's Avatar
phillips91
Actually, I'll bet if you'd looked, you were on the bump stops. There's no WAY you had 1900lbs in a half ton bed without it being on them. (1500lbs for one pallet + 200lbs of the other, + 210lbs of oxygen thief...lol)
Before making a statement like "if I had looked" it would be wise to make sure the truck isn't still sitting in my driveway
Rock still in the bed
My hand between the axle and bump stop.
View without my hand in the way.
Old Aug 21, 2010 | 01:29 PM
  #7403
Tom's Avatar
Tom
Now that I'm done with the class I was in I have enough free time to dive in again...
Um...I seriously doubt it. My '07 was a similar configuration to yours and I have loaded it and pulled heavy with it numerous times.
Like this one:
350 lb bike in the bed, ~600 lb tongue weight on the trailer plus 4 people in the cab. Nowhere NEAR the bump stops.
F150s are very capable trucks, I nearly bought one to replace my dead F250. As capable as they are I was really used to the power of my '08 and didn't think I'd be happy towing heavy with the 5.4L again. Had the 6.2L been out in the F150 it would have been a done deal though.
Old Aug 21, 2010 | 01:45 PM
  #7404
phillips91's Avatar
phillips91
Originally Posted by 2001400ex
I owned a Chevy 6.0 in the 1500HD (3.4 ton minus 1 leaf spring) and stock it was 300/360, so equivalent to a 5.4, but in a 1,000 pound lighter truck. But put 10,000 pounds behind it, and it was a dog.
That being said, I have agreed there is a purpose for the 5.4..... it will not pull ahead in first gear no matter the load
But you can throw out for us to meet, but we are like 2,000 miles apart. I want to see you try to pull ahead in first gear against a 6.2 or 6.0. It won't happen. It also won't pull ahead of a NBS 7.3 on a 15% hill as you have said in the past.
Are the torque curves exactly the same? Same tranny ratios? Same rear end? Seeing as how Ford advertises the tritons as the only gas engine to make 80% of peak torque at idle, I highly doubt the chevy has the same low end power. I have pulled over 10,000 lbs with mine many times and would not call it a dog. Unless by dog you mean it has to downshift.
You still don't understand what gearing does. By multiplying torque(with gearing) that means you can take an engine with half as much engine torque but twice the gearing and put the same torque to the ground with both of them. Just do a simple experiment. Find a car or truck with a manual tranny and pull out in 1st gear. Then stop and try to pull out in 5th gear. Same engine torque, but much different result. The gear spacing between my 1st and the 1st on a TS (or an e4od) is wider than the gear spacing between your 1st and 5th. It's not just a small gearing advantage.
I made the offer for you to come ride with me and to bring your trailer, but I also made another offer. Read the rest of what I said. If ANYONE wants to get together and pull some trailers around I am all for it as long as my truck can handle the trailer. My truck will win at certain things and it will lose at others. It's not that big of a deal to admit that another truck can do something better than yours.
Old Aug 21, 2010 | 01:51 PM
  #7405
bucci's Avatar
bucci
Doesn't that tic you off! Somebody hundreds of miles away who has never seen you, your truck, or the load that was on it telling you how your truck handled the load.
Old Aug 21, 2010 | 02:37 PM
  #7406
Strokin-A-2010's Avatar
Strokin-A-2010
This thread is funny.
Old Aug 21, 2010 | 03:07 PM
  #7407
krewat's Avatar
krewat
FTE Leadership Emeritus
WELCOME to FTE!
Old Aug 21, 2010 | 03:56 PM
  #7408
scraprat's Avatar
scraprat
Top Answer: 5
Silence has fallen in the mountains of Colorado. Yea.
Old Aug 21, 2010 | 04:31 PM
  #7409
dkf's Avatar
dkf
That red 150 Josh posted looked level to me with the stone in the bed and him standing on the tailgate. It will probably take another 1k lbs before it gets to the bump stops.
Old Aug 21, 2010 | 04:44 PM
  #7410
phillips91's Avatar
phillips91
The truck is 2wd too, so it is naturally going to ride lower than a 4wd. That's why the bed isn't as high off of the tires as one would expect. Like you said, I would have felt comfortable adding even more weight to it. I drove it around for about 45 minutes today just trying it out and it handled great and never bottomed out going over speed bumps, pot holes, etc.
