Sponsored by: Real Truck
Gas vs PSD
Old Aug 18, 2010 | 03:14 PM
  #7321
2001400ex's Avatar
2001400ex
Originally Posted by phillips91
Nah, they are both 4.10, 5 speed, regular cab, xl trucks with the same size tires and weight.
Engine torque can be part of the equation as long as you are comparing them in the same gears and at the same speed/rpm because at that point the one with more engine torque is also producing more hp. Since gearing will be the same and wheel rpm the same, the one with more engine torque(and hp) will be producing more tractive force. The reason engine torque doesn't matter in this comparison(except off the line for the first 3,000 rpm) is because of the drastic difference in gearing and rpm ranges.
Honestly, I am not too impressed with the 6.2 off the line even with the 6 speed and 4.30 gears. Comparing it to my 2v 5.4 with both in 1st gear and turning 4,500 rpm the tractive force is 6,929 for the 6.2 and 7,112 for my 5.4. The 6.7 has seen a massive increase in low end power AND gets the 6 speed tranny while the 6.2 at its best is worse off the line than a 2v 5.4 with a manual.....
Josh, I thought horsepower was the only thing that matters. Now you are using math to show you would take a 6.2 off the line despite a 100hp disadvantage. I would bet any amount of money the 6.2 would take you anytime anywhere.
Old Aug 18, 2010 | 03:28 PM
  #7322
Kajtek1's Avatar
Kajtek1
Define what is steep for you? Where I live -steep is when dropped brick rolls all the way down. I did own a house with driveway so steep, that my VW had the speed margin between 15 and 20 mph to take it. When I took it too slow >>> the engine would die 1/2 way up.
When I took it too fast >>> the approach impact would lower the car to wedge the front bumper into the pavement.
Old Aug 18, 2010 | 04:08 PM
  #7323
ChargersFanInCO's Avatar
ChargersFanInCO
I went up a hill the other day to fix an a/c and thought I was going to twist the driveshaft out going up it....or roll over backwards. Coming back down was no treat either.
Old Aug 18, 2010 | 05:56 PM
  #7324
jojolima's Avatar
jojolima
I have had VERY POSITIVE experience with the V10 and the 4:30 LS. It has done the job very well. I expect to purchase a F350. 6.7 in the future. Both are great power plants.
Old Aug 18, 2010 | 07:40 PM
  #7325
phillips91's Avatar
phillips91
Go back and look at what we were talking about when I said hp is all that matters. We were comparing how an engine pulls at different rpms, not against another truck with different gearing and rpm ranges where tractive force comes into play. I said my 5.4 pulls better at 4500 rpm than it does at 2500 rpm because monsterbaby said his truck pulls better at lower rpms. The 6.2 would smoke my 5.4 in any comparison you want to do except pulling out from a dead stop. Anytime you want to come ride with me and see how good a manual tranny will get a load moving just let me know. It's a world of difference between the automatic.
Old Aug 19, 2010 | 06:43 AM
  #7326
Jrfish007's Avatar
Jrfish007
Originally Posted by Krewat
Very true. By 15%. Not enough to worry about, me thinks
I'm not saying the Dodge will make up the lost room, I'm just saying there may be points were it will gain on you, untill the Dodge shifts into the same gear.
Old Aug 19, 2010 | 06:46 AM
  #7327
Jrfish007's Avatar
Jrfish007
Originally Posted by CampSpringsJohn
Do they have the mirrors all the way out like they do here?!!! I know one of these days, I'm gonna get one of those mirrors with my work truck one day. I have a nephew that told me that having the mirrors out is suppose to be cool. I told him that having the mirrors out when not towing is the sign of a bleepin' idiot.
LMAO.... yes they do it here too. I don't understand it either, because our telephone polls are about 4" from the side of the road. You can actually drive down some of the streets here and pickup mirrors from large trucks that have been knocked off.
Nothing like seeing some jacked up truck with one extended mirror and the other one missing.
Old Aug 19, 2010 | 07:40 AM
  #7328
2001400ex's Avatar
2001400ex
Yes I have been in a 2000 psd and 1995 psd with manuals so yes I know what they are like. You still won't be close to a 6.2 off the line, down the street, or anywhere else, I don't care what your math says. You obviously have not been in a modern ford automatic.
Old Aug 19, 2010 | 07:44 AM
  #7329
Jrfish007's Avatar
Jrfish007
I believe the manuals have a low gear that is about half the size of the automatic 1st gear. The manuals 2nd gear is equivalent to the the auto's 1st gear. This would give it huge pulling power from a stop verses any auto, modern or late.
Old Aug 19, 2010 | 07:49 AM
  #7330
Johnny Langton's Avatar
Johnny Langton
Originally Posted by Jrfish007
I believe the manuals have a low gear that is about half the size of the automatic 1st gear. The manuals 2nd gear is equivalent to the the auto's 2nd gear. This would give it huge pulling power from a stop verses any auto, modern or late.
Exactly.....a 5.72 for the 5-speed or a 5.79 low gear ratio in the 6 speed vs a 3.11 in the Torqshift or a 2.71 in a 4R100. No contest there.
JL
Old Aug 19, 2010 | 08:09 AM
  #7331
2001400ex's Avatar
2001400ex
JL
Agreed, but not enough to make up for the huge hp/torque disadvantage. So maybe the first 5 ft, which would be imperceptible to the human eye. LOL
Old Aug 19, 2010 | 08:24 AM
  #7332
Johnny Langton
Do you not understand torque multiplication?
A 5.4L with just 350 ft lbs:
350 x 5.79 x 4.10=8308.6 ftlbs to the rear wheels.
A 6.0L with 570 ft-lbs:
570 x 3.11 x 4.10=7268.07 ftlbs to the rear wheels.
Yes, the manual trans 5.4L will get the load moving easier than the 6.0L with a Torqshift. Your engine torque means NOTHING with gearing that MULTIPLIES the torque.
JL
Old Aug 19, 2010 | 08:40 AM
  #7333
dkf's Avatar
dkf
Just make sure you arn't lazy shifting from 1st to 2nd with the manual...
JL how much torque multiplication does the TQ provide when its unlocked?
Old Aug 19, 2010 | 08:52 AM
  #7334
2001400ex's Avatar
2001400ex
JL
Read up a few, was talking the 6.2 with 4.30 gears that Josh was saying he could get off the line quicker.
And no he would not take my 6.0 either, with 3.73 gears. Remember I have a 45rwhp tow tune, so like 60 at the engine or whatever.
Old Aug 19, 2010 | 08:53 AM
  #7335
Johnny Langton
That is a very complicated calculation, and depends on the K-Factor of the converter amongst other things.
JL
