Sponsored by: Real Truck
Gas vs PSD
Old Jun 21, 2010 | 02:55 PM
  #5281
Jrfish007's Avatar
Jrfish007
Originally Posted by ChargersFanInCO
Not at all. The diesel is just plain better.
Diesel For The Win...since FTW means something else.
(I'm just tired of justifying why I bought one, so I'll be as rabid as the V10 guys)
Ahhh... Well diesel is the better option when towing often, as I have said many times. Still, at elevation you should really be thanking your turbo for minimizing your power losses. I've taken my car ( turbo Saab) to high elevations many times and noticed only a slight drop in power.
On a side note: I wonder if Ford's towing charts take into account elevation like that? That would become very important for the V10 owners. I'm sure it can handle 5,000 foot elevation and 15k lb trailer, but what about 10k foot? There is a big difference between a 15% loss in power and 30% loss...
Old Jun 21, 2010 | 03:09 PM
  #5282
bill11012's Avatar
bill11012
Modular motor junkie
Yes, my owners book says that a certain % of GCWR is taken off every 1,000' after I think the 5,000' mark. It uses the same formula for the 5.4, 6.8 and the 7.3.
Old Jun 21, 2010 | 03:18 PM
  #5283
bill11012's Avatar
bill11012
I'm not that rabid. If I had to tow 100,000+ miles a year a 99-03 7.3 would be my first choice becuase of the savings in fuel outweighing the other costs.
I have said before in this thread that I would rather have a 7.3 IDI or 7.3 PSD than a 460 in the OBS trucks, and that at high altitude the PSD is better stock vs stock.
For my use the V10 is cheaper to run. The ease to work on and power are the best part though.
Old Jun 21, 2010 | 03:20 PM
  #5284
Jrfish007's Avatar
Jrfish007
interesting... I was not aware of that. I figured they would go to 5,000 feet, it's not hard to get that high.
Old Jun 21, 2010 | 03:25 PM
  #5285
phillips91's Avatar
phillips91
That was sarcasm...but ok...
Sarcasm or not, I was just letting you know what you actually said and why Mike would take it the way he did.
I'm not a "v10 guy" and I'm not rabid in my support of it. I just have no problem admitting that another engine can do something better than mine. That doesn't mean I think the v10 is a better engine than the psd. I prefer to tow with my 7.3 over my 5.4 because it requires less downshifting and gets better mpg's than my 5.4. But when it comes to get up and go, it just can't compete with my 5.4.
Look at it like a bicycle. Say you and Lance Armstrong are both on a 15% grade and starting from a stop. Both of you are on 10 speeds. You get to start out in the hill gear(the one below 1st gear) and Lance has to start out in 2nd. He is the more powerful bike rider, but you are going to get the bike moving faster because of the gear reduction. That is like comparing a 5.4 with a 6 speed tranny to a psd with an automatic pulling out from a stop. Then once you get the load moving, Lance has to shift twice as quickly as you. He is still the more powerful rider, but at certain points he is going to be in 4th gear and working harder while you are in 2nd and using the gearing to keep up with him. That is like the psd shifting at 3k and the gasser pulling to 6k rpm.
Old Jun 21, 2010 | 03:35 PM
  #5286
Jrfish007's Avatar
Jrfish007
I think those of who are going to understand your gearing argument, already do.
Old Jun 21, 2010 | 03:43 PM
  #5287
phillips91's Avatar
phillips91
Sometimes you have to try different options that people can understand better....... Everyone has ridden a bike and knows that it is easier to start out in a lower gear than a higher one. It's hard to argue with that one.....
About 200 pages back someone used wrenches as an example. You can take the world's strongest man and give him a 6" wrench and have him tighten a bolt as tight as he can. Then my wife can come along behind him with a 3' breaker bar and tighten it about 10 times tighter.
Old Jun 21, 2010 | 03:54 PM
  #5288
Rush117's Avatar
Rush117
While true, there is a fallacy in your argument. First of all, the gearing difference between a hill gear and 2nd gear on bike is probably greater than the difference between rear-end gearing in our trucks. Secondly, Lance Armstrong could probably start out in 3rd gear and still whip me up one side of the hill and down the other. He just simply has so much more strength where it counts. I'm trying to think of an engine example where one of them has so much more strength to get a load moving than the other....give me a minute, I know I'll think of it.
Old Jun 21, 2010 | 04:01 PM
  #5289
bill11012's Avatar
bill11012
If both trucks have the same gears, your 6.0 will pull harder from a stop until shifting into second. Then the v10 will keep pulling much harder. When it hits second you hit third, so it keeps pulling harder. Of course, at the elavation you live at thats not the case. Most places it its though.
Old Jun 21, 2010 | 04:03 PM
  #5290
phillips91's Avatar
phillips91
I am heading out of here for now, but comparing my 5.4 with a 5.72 1st gear and a 4.10 rear end is a pretty steep gap between a a psd with a 2.70 or 3.09 1st(depending on tranny) and a 3.55/3.73 rear end(depending on year). That is a 23.45 final drive vs a 9.59 in some cases. Either way, I can assure you that my 5.4 will jerk the wheels out from under my 7.3 if I start out with my 5.4 in 1st and my 7.3 in 2nd(same ratio as an auto 1st).
Old Jun 21, 2010 | 04:07 PM
  #5291
Rush117's Avatar
Rush117
I agree Bill but my argument is based on just getting the load moving. I am quite confident that you'd beat me to the top of just about any hill, regardless of load behind the truck. That is one of the reasons you have the best truck suited for you, and mine is suited for me.
I missed the manual transmission you used in your example. My apologies.
Old Jun 21, 2010 | 06:03 PM
  #5292
bucci's Avatar
bucci
Ah, nice! The thread is back to a respectable discussion.
Old Jun 21, 2010 | 09:19 PM
  #5293
TennesseeMustangPerf's Avatar
How dare they!?!?!?
Old Jun 22, 2010 | 06:36 AM
  #5294
phillips91's Avatar
phillips91
No apology needed, but accepted anyways. In situations where both have the same tranny and the same(or even close to the same) rear ends, the psd will get the load moving easier 100% of the time when compared to any 5.4/v10. That being said, something like 97% of psd's are automatics and most come with 3.73 rear ends. Mine will fare quite well against any stock psd with that set up when it comes to getting a load moving.
Old Jun 22, 2010 | 07:21 AM
  #5295
Jrfish007's Avatar
Jrfish007
Actually in the '09-'10 at least, the PSD only came with a 3.55 in SRW form. I've heard of people having '09-'10 3.73 PSD F250's, but I think it was a special order or something. DRW you could pretty much get what ever you wanted all the way to 4.88 in the F450, but I assume we are talking about a more common F250/F350 of CC 4x4 short bed SRW, probably the most common configuration of Super Duties.
