Sponsored by: Real Truck
Gas vs PSD
Old Feb 16, 2010 | 03:15 PM
  #3556
bill11012's Avatar
bill11012
Modular motor junkie
Originally Posted by LSchicago2
My 550 weighs 13,640# with me in it. It weighs 2250 more than my old F450 with the 6.0. My 550 V10 gets 1.5 MPG less in Chicago city traffic, and about 2 MPG less on the highway. Not a huge loss, considering it weighs almost 20% more.
Thats pretty good, I wonder what the difference would be if you had a 6.0 that was not a POS.
I wouldn't admit to mpg's in the single digits, so reps for being honest lol.
Josh, thanks for the rep.
I was kind of bragging about getting close to 10 MPG at 17,000 in hills...
Old Feb 16, 2010 | 03:26 PM
  #3557
bucci's Avatar
bucci
... and your gas mileage is???
Old Feb 16, 2010 | 03:31 PM
  #3558
phillips91's Avatar
phillips91
My next door neighbor has a 6.0 that runs great and he gets between 8-9 mpg's with nothing in it but him. He drives it 3 miles to work and 3 miles home and that's it, so it doesn't even have time to warm up before he shuts it off. Most of our company 6.0's get 12-13 mpg's, but they are loaded down and the guys drive them like they stole them. I have heard ranges from 8 all the way up to 22 for it, so I wouldn't have a clue what it would actually get.
I have a mustang that is like your v10. I would put about 8 gallons in it, drive 15 miles to the track, get 6 runs in, drive 15 miles home and be almost empty lol. I figured it up one day and it was around 5-6 mpg when I ran it hard like that. A set of tires was lasting me about 300 miles, and with the gas I was burning through, I figured it was time to put her on the trailer
Old Feb 16, 2010 | 03:33 PM
  #3559
LSchicago2's Avatar
LSchicago2
My 550 will get 11 MPG at about 17,000#, @ 55 MPH (loaded with a car) it goes down about 1 MPG for every 5 mph over 55. At 65 MPH, it gets right at 9-9.3 with 4.88 gears. My 6.0 & 7.3 F450's both got 10-11 at 65 MPH, the 7.3 weighed 9900 (4.88's=10MPG) , and the 6.0 weighed 11,400 (4.30's=11 MPG). My 09 V10 weighs in at 13,640 empty.
Old Feb 16, 2010 | 03:39 PM
  #3560
bucci's Avatar
bucci
I found that 55 mph on the highway yields the best too. I've only done short trips on the highway and have relied on the computer for the highway gas mileage and it reads around 10.5 to 11. I don't expect it to be too much better than my city -- the aerodynamics of the dump body really sticks.
Old Feb 16, 2010 | 04:36 PM
  #3561
bill11012's Avatar
bill11012
300 miles on a set of tires? the worst I have ever done with my old cop cars is about 5,000 on a set. You leave smoke and black marks everyware you go? lol
5-6 is pretty bad, I don't think my V10 could get that low with out idling or pulling a sled, etc.
Old Feb 16, 2010 | 05:35 PM
  #3562
LSchicago2's Avatar
LSchicago2
My 5.4 Lightning would get about 2MPG at the track. That would be 1 pass & loop back to the starting line again.
Old Feb 17, 2010 | 07:36 AM
  #3563
phillips91's Avatar
phillips91
The tires were drag radials, so they were really soft to start with. Then throw in the fact that I saw no point in getting it out of the garage unless I was having fun with it. So it has left its share of black marks lol. 300 miles usually got me through one full race season. They wouldn't be totally slick, but slick enough that they wouldn't grip as good as I wanted them too. That's when I would take them out and see how far I could leave black marks, how many gears I could shift through while doing a burn out, etc.
If I drive it normally I can get about 15 mpg's out of it.
Old Feb 17, 2010 | 10:15 AM
  #3564
brian42's Avatar
brian42
Veteran: Navy
That's not running great. Unless he has some serious power-adders (i.e. big sticks and hot tunes), then he's got some fuel issues.
Just my .02
Old Feb 17, 2010 | 11:26 AM
  #3565
phillips91's Avatar
phillips91
Just my .02
By running great I mean it has never been in the shop or failed him in the two years he has had it. I think his poor mileage is just a result of his engine not warming up to operating temps so it can burn the fuel efficiently. I have a thunderbird turbo coupe that is like that. If I drive it to work(40 miles one way) I average 30 mpg's with it. If I let my wife drive it to work(2 miles one way) it only gets 17 mpg's. On her way to work 1.5 miles of it is downhill and she coasts, and it still gets that bad mileage. Same with her eclipse. We get 28 mpg's out of it when we take it on long trips, but she gets 18-20 driving it to work.
Old Feb 17, 2010 | 12:34 PM
  #3566
brian42's Avatar
brian42
Veteran: Navy
Sure you're mileage goes down with city driving. Running cold and having to stop/start that much weight takes extra fuel, but less than 10mpg overall is really low for a pre-DPF truck. My truck is mostly stock and was getting 15mpg overall with stock tires. I moved up to 285/75-16 size and went down to 13.5mpg overall. Most mornings I only let the engine run for 30 seconds before I pull out (don't want to bother the neighbors at 4am with my injectors firing).
I am no ASE certified mechanic, nor do I claim to be a professional of any kind, but less than 10mpg just sounds REALLY low for normal driving. The last time my fuel mileage dipped, I had a fuel leak from my bowl drain valve.
Old Feb 17, 2010 | 12:39 PM
  #3567
bill11012's Avatar
bill11012
Haha, I have been know to do that with old tires
So what motor/ trany combo does it have and what times does it run?
You are lucky living 15 miles from a drag strip, mine is a long drive.
Old Feb 17, 2010 | 12:43 PM
  #3568
bill11012's Avatar
bill11012
Originally Posted by tschoepe
You guys are forgetting the biggest advantage of the diesel...in the event of a zombie uprising that causes TEOTWAWKI diesel fuel will stay usable longer.
V10 owners = food
NO, PSD owners = food.
A V10 has 600 pounds more payload than the PSD in the same truck.
That 600 pounds of ammo I can carry that you can't will make a world of difference.
Old Feb 17, 2010 | 02:49 PM
  #3569
phillips91's Avatar
phillips91
The thing with my two gas cars is that they run different in cold mode than they do in hot mode. In cold mode they pump more fuel to the engine to get it to heat up faster. With my wife only driving 2 miles, her car never has a chance to switch to hot mode. I don't claim to be an expert on fuel injection or computer controlled stuff either, but that's what the ford garage here told me. That it's not the city part of it that's hurting her mileage, but the running cold part.
I don't know about my neighbors truck though. He just told me he was getting really bad mileage and I asked him if he had any CEL kick on or any lack of power, running bad, etc. He said it was running great, no problems, ford garage checked it and told him nothing was wrong, that he just wasn't getting it up to operating temps.
Old Feb 17, 2010 | 03:08 PM
  #3570
phillips91's Avatar
phillips91
It used to be an 86 mustang gt with a mild 351w and 5 speed manual but I am swapping all the drivetrain over to an 83 lx coupe. The time depends on the track really. I run at Bristol 99% of the time and it is about a second slower there than it is at other tracks due to the elevation and uphill track. The finish line at Bristol is something like 75-100 feet higher than the starting line, so that doesn't help things lol. It runs a 12.4 at 118-120 mph there. By comparison the 03 cobras I have raced run about a 13.5-13.8 at 100-105 mph. Not fast by any means, but a pretty quick street car. I'm working on a 351 stroked to a 427 that I'm putting in a 91 gt. That's going to be my fast one
We have another track in Rogersville, but it is only 1/8th of a mile and it's pretty sorry. It's faster than Bristol, but there was a dip towards the end of the track that was so bad it bounced a guys car and flipped it about 3 or 4 years ago. They don't take safety too seriously there either, so the guy wasn't even wearing a seat belt and got thrown from the car.
