Crewcab Only Thread.
Old Jun 2, 2016 | 10:03 AM
  #3166
highntight's Avatar
highntight
Originally Posted by Foundmydreamcrew
Speakers. 76 crew. Would like to put in 4 speakers. Don't need top quality audio and was thinking of just putting 5.25"'s back in the stock door holes. Which leads me to my question... as the back door panels are in pretty good shape, I'd hate to remove them and find that the back doors don't have stock speaker holes. Do they?
I filled my door holes back in, my own opinion, but I didnt like speakers in the doors of my rc years back. I ran a couple speakers in the pillars....
Old Jun 3, 2016 | 06:56 PM
  #3167
b79rag's Avatar
b79rag
1976 f-250
It has been awhile since i been on here. But i finally got me a crew cab.It is a 1976 f-250 4x4 short bed has a disk brake low pinion dana 60 in the front 60 rear,460 out of a newer truck. I looked up the vin and originally came with a 360, has a np 435 i think 4 speed and divorced 205. Also has some kind of pto i think bolted on the np205. truck needs alot of work roof,floor pans if i decide not to patch and probably a bed to. Will get more pics when i remember to take them.
would also like to how strong the lp 60 is and are parts fairly easy to get for it. It also has a hydraulic clutch it was wondering is factory or not.
Old Jun 13, 2016 | 08:19 AM
  #3168
Olbetsy81's Avatar
Olbetsy81
Wow its been a minute
Havent checked in here in a while.. Im a year and a half into my 4x4 conversion its gettin there!!.... Yep thats a long box steppie i found buried in the back of a ford graveyard 75 mi north of vegas... I had to have it!!
Used a 97 350 donor truck for the conversion check out the progress on fb :
facebook.com/Hawks79fordtruckbuild
Old Jun 13, 2016 | 08:24 AM
  #3169
1978crewcab's Avatar
1978crewcab
Looks good, how did you do the conversion? I just bought a 97 4x4 frame I am going to use for my conversion.
Old Jun 13, 2016 | 08:32 AM
  #3170
Olbetsy81's Avatar
Olbetsy81
I used a 97 350 donor that had the front end mashed in, used the parts and built custom spring perches onto the 2wd frame. U can see the proscess here:
Old Jun 13, 2016 | 08:41 AM
  #3171
1978crewcab
Awesome, that's what I have a 97 350 crew frame. This will help me out a lot
Old Jun 13, 2016 | 08:53 AM
  #3172
Olbetsy81's Avatar
Olbetsy81
I only used the axles and drivetrain. Mounted them up under the 79 frame. I think the 97 frame is 2.5 " or so longer. But have fun with it. U can hit up on my fb page if u need any suggestions.
Old Jun 13, 2016 | 08:59 AM
  #3173
1978crewcab
I will do that. I have a 10.25 and getting a Dana 69 correct to the year for my donor frame. I plan to replace the driveshafts. And ordering a new transfer case and 4x4 transmission. My big scare right now is the cab mounting to the frame. Did you have to do some altering to the body mount brackets? I will ask questions on your Facebook page too but can't get it to load up right now.
Old Jun 13, 2016 | 09:39 AM
  #3174
Olbetsy81's Avatar
Olbetsy81
I used the 2wd frame and left the cab on it. Would have had to move cab mounts on the 97. It was easier doing it this way anyways, besides , the 97 was pretty messed up in the front. The only thing i didnt strip off the 79 frame was the cab. No lift or space. Spent alot of time on the creeper cleanin the underside up. Lol... The spring oerches for front were pretty simple. And all i had to do in rear was move spring pads in on both sides. Way easier and simpler than a body swap in my opinion. No lift. Used the factory 97 lift block with my 79 leaf pack out back and placement of front hangers gained me 5" over stock im pretty happy with its stance.
Old Jun 15, 2016 | 03:37 PM
  #3175
Helkenn's Avatar
Helkenn
hey guys i was wondering if anyone ever put a matte black vinyl between the doors on their crew cabs like the dodges do. Like the one in the pic. i was just wondering because i have and opportunity to buy a crew cab or a supercab for my next build and i just can get over that triangle between the front and back doors and i thought maybe the vinyl would make it more appealing to me
Old Jun 15, 2016 | 05:11 PM
  #3176
classictruckman's Avatar
classictruckman
Don't know if anybody has done it, but I personally don't think it would look right with the dent style body
Old Jun 21, 2016 | 03:23 PM
  #3177
Melaney Wilson's Avatar
Melaney Wilson
crew cab wanted
looking for a project 1966 crew cab either whole truck or just Cab. any out there for sale?
Old Jun 25, 2016 | 03:34 PM
  #3178
jgoodman6891's Avatar
jgoodman6891
Would probably look like dog **** since the Ford has an actual B piller.
Old Jul 6, 2016 | 07:16 PM
  #3179
Az75F150's Avatar
Az75F150
Hello All,
I'm hoping you all will be kind to some stupid questions. I bought a '75 F150 Supercab a few weeks back that I discovered tucked in a garage with a small for sale sign. The owner says he bought from the original owner, his Dad in '76, and seemed to know the truck well. This is a real change for me as I'm typically more of a car guy but I'm just really enjoying this truck. Anyway, the seller said it has the original motor. It is a Ranger and has a 460 motor. Everything I find says that a 460 was not an option on a '75 so I am concerned that it is not the original motor.. It runs great, has 103K miles and great original paint; brown over white. I would love to hear opinions on value; it also has factory air, Psteering, Pbrakes, towing pkg..
Thanks,
Scott
Old Jul 7, 2016 | 12:28 PM
  #3180
CelticOne's Avatar
CelticOne
Regular User
Originally Posted by Az75F150
Hello All,
Thanks,
Scott
Welcome to FTE, Scott. Great place to hang out and learn a ton of stuff.
Just to let you know, you posted in a crew cab thread and you say you have a super cab. You'd be better off starting a new thread of your own in the main 73-79 forum.
Post the VIN and some pics of your truck. The VIN can be decoded to determine the original engine and other fascinating details about your truck.
