Crewcab Only Thread.
Old Aug 6, 2016 | 06:25 PM
  #3196
phlegm's Avatar
phlegm
The fill hose, or the 1" vent hose. Or get the tank with EEC and plumb it back through that hole. Lots of options.
Old Aug 7, 2016 | 02:46 AM
  #3197
Skip1970's Avatar
Skip1970
what is a ECC?
Old Aug 7, 2016 | 09:10 AM
  #3198
phlegm's Avatar
phlegm
ECC is error correcting code.
EEC is evaporative emission controls.
EEC is a fancy way of saying it has a charcoal canister on a vent off the gas tank.
Old Aug 9, 2016 | 01:15 PM
  #3199
Skip1970's Avatar
Skip1970
im trying to order thru autozone since amazon prime is being a punk bit$& to members in alaska, anyhow they dont have the exAct part number do you think one of these would work?
Old Aug 10, 2016 | 11:02 PM
  #3200
Skip1970's Avatar
Skip1970
Well I ordered the Dorman 576-035 we will see how it works
Old Aug 15, 2016 | 03:23 AM
  #3201
Coltin1992's Avatar
Coltin1992
Are there any production numbers for the crew cabs?
Old Aug 16, 2016 | 04:56 PM
  #3202
Skip1970's Avatar
Skip1970
Well it came in with my bronco 3m gal tank too. It's a bit bigger I think I will have to smash sides to get in! 38 gallons. The Dorman paint looks better then the finish on the broncos spectra. But I'm not sure it will last as well.. Dorman part 576-035 they both have same warranty
Old Aug 16, 2016 | 05:08 PM
  #3203
phlegm's Avatar
phlegm
It fits without smashing.
Here is how I installed mine.
Rear Fuel Tank Upgrade 19g to 38g - Old Ford Crew Cab Community
Old Aug 16, 2016 | 05:42 PM
  #3204
Skip1970's Avatar
Skip1970
Is yours not a highboy? Mines a 75 came with divorced tcase and 360FE
Old Aug 16, 2016 | 05:54 PM
  #3205
Skip1970's Avatar
Skip1970
Here my measurements
Old Aug 16, 2016 | 06:04 PM
  #3206
Skip1970's Avatar
Skip1970
Oops forgot the other measurements I have a couple cross members too the tank will stick out behind my receiver hitch if I don't remove one of them. I never had a tank in mine it's always had in cab one
Old Aug 16, 2016 | 06:34 PM
  #3207
phlegm's Avatar
phlegm
Mine is a frankentruck.
It started life as a 78 (non high boy) but was in an accident. Somewhere along the lines, it was rebodied with a 75 cab and box. And now I have a 78 front end (grill/surround) to put on it. But the title will still say 75.
Old Aug 16, 2016 | 08:05 PM
  #3208
Skip1970's Avatar
Skip1970
You should say the year frame before recommending tanks for 1975 crew cab fords. I'll hammer fit it I guess.
Old Aug 23, 2016 | 01:01 AM
  #3209
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Does anyone know if auto ventshade ever made a 4pc stainless window visor kit for the 73-79? I have seen pictures of them installed but can't find a part number if they ever did make them.
Old Aug 23, 2016 | 07:43 AM
  #3210
Djstright's Avatar
Djstright
I'm pretty sure any pictures you saw were just two front kits installed seeings how the rear doors are just front doors cut down and use the same glass I can't see why they shouldn't fit.
