Crewcab Only Thread.
Old Apr 10, 2016 | 06:35 PM
  #3136
Rtbcoop's Avatar
Rtbcoop
Originally Posted by phlegm
What year is your truck?
It's a 1976 truck
Old Apr 10, 2016 | 10:03 PM
  #3137
phlegm's Avatar
phlegm
Originally Posted by Rtbcoop
It's a 1976 truck
and I think that is why you are having problems. The tank is designed for later frames (37" starting in late 77+) and the earlier frames are only 34", this is not a crew cab specific issue. If you search for other threads of people swapping in larger tanks to early trucks you should find some options.
Hopefully somebody will correct me if I'm wrong, or post links.
Old Apr 11, 2016 | 03:30 AM
  #3138
Rtbcoop's Avatar
Rtbcoop
Good to know, thanks for the info! I may try to turn it sideways and make it fit. The largest tank I could find that actually fits correctly is only 23 gallons and that just isn't enough.
Old Apr 11, 2016 | 12:21 PM
  #3139
uniwagon's Avatar
uniwagon
rear tank
Hello,1980-1996 ford cab and chassis plastic tank is a direct bolt in for a 34 inch frame.the one I put in my 79 f350 crew was from a 85 gas motor truck=small hole sending unit.I used a 84 bronco II sending unit spun 180 degrees.The skid plate is the real problem most are rotted out,so you can just make straps.I bought a NOS skid plate from Tasca Ford,yes It was a lot of $$ but I did not have to make one thing.Plate was from 1991.Super camper specials have the right size rear tanks but the fill is out the rear of the tank to clear the bed mounts and they have a habit of cracking.
Chris
Old Apr 11, 2016 | 07:34 PM
  #3140
Firemedic79's Avatar
Firemedic79
What's going on guys. I just bought my first crewcab I'm pretty excited about it. I've read so much my eyes are crossed, but I can't really seem to find anyone that has completed a 4x4 conversion on a 79 without cutting and splicing the front frame stub. And Ive read about the spring hangers from a highboy on the crewcab frame but I haven't seen anything on doing that to a 79. I've built a few trucks, but I'm not a welder so that scares me. My granddad is a welder, we did a mustang 2 conversion on my 56 ford, and its still going strong. I have a 79 f150 4x4 single cab short bed I plan on using for parts. I was initially thinking of doing the conversion using coil springs, but now I'm not sure. Looking forward to hearing your thoughts and advice!
Old Apr 14, 2016 | 08:54 AM
  #3141
highntight's Avatar
highntight
Pictures or it didn't happen, lol Lets see some pics of your crew. It can be done and if you want it bad enough it will happen. keep searching the threads and some of the nice folks on here will post up some builds or at least more info for you. I just built my 4x4 front end along with many others on here. mines a little older then yours (bump) and I'm not sure of the differences between the two. Sounds like between you and your grand-pappy you have the skills to get it done... good luck and don't give up....
Old Apr 14, 2016 | 11:56 AM
  #3142
Pitcrw6's Avatar
Pitcrw6
Welcome aboard, post your question in the 73-79 forum. You will get a lot more responses and feedback since your question about isn't crew cab specific. And yes we need pics.
Old Apr 26, 2016 | 09:07 AM
  #3143
highntight's Avatar
highntight
well boys, bought the truck 5 years ago and got to enjoy the fruits of my hard work the other day... Took her for its first short trip around the block finally. Just buttoning up a few small things and its gonna be time to play a little...
A short video
http://vid949.photobucket.com/albums...psqxqhsxak.mp4
Old Apr 27, 2016 | 11:34 AM
  #3144
somethingclever's Avatar
somethingclever
wow the color really looks great...what an awesome truck.
I like the 1972 script in the front bumper - cool addition.
Old Apr 27, 2016 | 11:46 AM
  #3145
Deez-67's Avatar
Deez-67
Wwwwhat? Our own CC thread?
Picked this old dog up a few weeks ago. 1997 4x4 F250 short bed with the gas eating 460. Its a super clean truck.
I'm looking for some side steps for it now since my pregnant wife can't get in it very easy. I love how these N-Fab bars look but $500+ OUCH!
Old Apr 27, 2016 | 12:01 PM
  #3146
somethingclever
For us, yes.
For you, no.
Nice truck though...always liked 92-97.
Old Apr 27, 2016 | 04:27 PM
  #3147
highntight's Avatar
highntight
Thanks man, the front cap ended up larger then the rear one due to angle of the dangle so it just was a good spot to fill out with the 1972, did turn out cool though, thank you...
For us, yes.
For you, no.
HAHA I shouldnt be laughing, cause Im not ether. But was hilarious.
All laughing aside, bad A truck. very good looking, I also have always loved those body styles. That one looks super clean as well, nice buy.
Old May 3, 2016 | 11:35 AM
  #3148
Deez-67's Avatar
Deez-67
For us, yes.
For you, no.
Damn it!! I jumped the gun on that one. lol
Old May 3, 2016 | 09:24 PM
  #3149
Big Big Blue's Avatar
Big Big Blue
Crew Cab Headliner Plastic Center Piece
I am looking for the center piece of plastic molding that holds the rear edge of the front headliner panel and the front edge of the rear panel. It goes across from the driver side pillar to the passenger side pillar. The pieces of the one I have are in the shape of a shallow W and it snaps on the metal roof support, and has rivets approximately every 6 inches apart securing it. Does anyone know the precise name of this molding? Has anyone found this molding or a good substitute? Please let me know your thoughts and ideas.
Thanks
Old May 3, 2016 | 10:03 PM
  #3150
Pitcrw6's Avatar
Pitcrw6
Thanks
Good luck finding an OEM one. Nobody repops them. Your best bet is to create one and cover it with some fabric and use small short metal screws to screw into the metal tabs or rail that the old one snapped into. Someone else might have another way to do it.
