Crewcab Only Thread.
Old Sep 22, 2016 | 05:38 PM
  #3241
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
thread is way off topic.
Old Sep 22, 2016 | 09:34 PM
  #3242
Skip1970's Avatar
Skip1970
what did i miss???????????
Old Sep 26, 2016 | 07:00 AM
  #3243
Retreever's Avatar
Retreever
Saddle Tanks
Three years ago I bought a 7.3L 2000 F350 Lariat Crew Cab 4 x 4 LB Dually , it was a Florida truck and in excellent condition with only 127,000 miles on it. I use it to tow my 5th wheel toy hauler in the summer and it's stored in the winters.
One thing I remember, or at least think I do was heavy duty trucks like this were sometimes equipped with dual tanks with fill tubes on both sides and fuel transfer capability or tank switch capability. Did I imagine this or did it exist and if it did could I retrofit my truck with a similar arrangement.
Note: I'm not interested in putting an aux tank in the bed of the truck I'm just curious about the "saddle" tank solution.
TIA , Retreever
Old Oct 4, 2016 | 08:17 PM
  #3244
Biz77's Avatar
Biz77
Originally Posted by Wyofordguy
Has anyone had any luck finding rear door window regulators. I thought I could modify one from a front door, but it looks to be a real pain to get it apart and still be able to reassemble it into something functional. Hopefully I'm wrong?
I have read that the rears are same as the front just from the opposite sides. So rear dr uses front passenger.
Old Oct 17, 2016 | 07:19 PM
  #3245
PACrewCab's Avatar
PACrewCab
What you read is not true. In the picture below, The regulator with the long arm is for a front door and the other one is for the rear door.
Old Oct 20, 2016 | 02:41 AM
  #3246
78_f800crewcab4x4
I said off topic because of some cheesy brand trucks. Then someone posts a 2000 crew cab. Still off topic. These posts should be deleted or thread closed due to clutter. Is anyone in charge?
Yes the rear door regulators are different.
Old Oct 20, 2016 | 03:43 PM
  #3247
teds74ford's Avatar
teds74ford
I agree. This is supposed to be only to support technical info related to the dentside crew, not be a "hey look at my _____ crewcab" thread.
Old Oct 30, 2016 | 11:30 AM
  #3248
Djstright's Avatar
Djstright
So I picked up a decent set of door panels with the wood grain trim. But I can't find a rear set. Anyone know how rare the rears are?
Old Oct 30, 2016 | 04:35 PM
  #3249
Pitcrw6's Avatar
Pitcrw6
Nobody repops the rear doors. You might have to get creative and make ur own or fix the ones you have.
Old Oct 30, 2016 | 09:45 PM
  #3250
jtjohn302's Avatar
jtjohn302
hey new to the forum i was wondering if the front ends are the same suspension wise on the 2wd dually trucks? i assume they are, since the dually stuff is usually aftermarket kits correct? im wanting to buy drop beams for it and not sure if the djm will work or not they just say 1965-1979 f100. thanks for the help
pic of my truck as it sits now
Old Nov 3, 2016 | 07:15 AM
  #3251
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Back on track sort of? SEMA show pics.
78_f800crewcab4x4 looks like the 1st pic got their inspiration from you and your build.
Old Nov 3, 2016 | 11:13 AM
  #3252
pinto_351's Avatar
pinto_351
that first pic is his old bronco.
Old Nov 3, 2016 | 03:48 PM
  #3253
77&79F250's Avatar
77&79F250
So now we know thanks...
Old Nov 3, 2016 | 04:53 PM
  #3254
78_f800crewcab4x4
Yeah that's my first body, A for effort to the builder. Be prepared for the next SuperBronco to be even better. I already intend to go four-link, 8.3 Cummins and air brakes with a similar tube subframe...all of the lessons learned on the F100 Viking build and all the details will make their way into the truck.
Old Nov 3, 2016 | 06:19 PM
  #3255
77&79F250's Avatar
77&79F250
That amount of fab work is inspiring.
