Crewcab Only Thread.
Old Jan 17, 2014 | 07:07 PM
  #2446
blue04.5's Avatar
blue04.5
I'd be looking for places where water is getting in. How is the window rubber on the doors? I personally have a suspect place on the underhood body seam that I need to address.
Thank you for the kind words btw.
Old Jan 17, 2014 | 07:44 PM
  #2447
Bobird's Avatar
Bobird
No Problem, lots of good info here.
I need to crawl around the truck for a few hours and take a look. I also need to pull the Mat & headliner and check for rust. Maybe treat it with a rust inhibiter.
Old Jan 20, 2014 | 06:18 PM
  #2448
Bobird's Avatar
Bobird
Has anyone seen any pictures or diagrams on original assembly of the crew cabs? I'm getting ready to mate the back half of my crew cab to the front half of my single cab. Just wondering we're (exactly) they were originally joined together??
Old Jan 21, 2014 | 09:56 AM
  #2449
Pitcrw6's Avatar
Pitcrw6
Sorry I cant help you out on that one.
Old Jan 21, 2014 | 12:25 PM
  #2450
ChaseTruck754's Avatar
ChaseTruck754
Fordification seems to have some dimensioned frame drawings if I remember correctly
Old Jan 21, 2014 | 08:38 PM
  #2451
Bobird's Avatar
Bobird
Thanks, I'll give it a look
Old Jan 27, 2014 | 07:11 PM
  #2452
dgully's Avatar
dgully
OK I decide to go with the CARR hoop II side steps, question is does anyone have pictures of how they mounted them on a crew cab? curious because the rear doors have that step in the cab.
Or does anyone have pictures of some other ideas.
Thank you
Old Jan 27, 2014 | 07:25 PM
  #2453
dgully's Avatar
dgully
ok cant get the pic to upload, still trying to figure how to post a pic, wish it was easier
Old Jan 27, 2014 | 07:39 PM
  #2454
dgully's Avatar
dgully
[/IMG]
Old Jan 27, 2014 | 07:40 PM
  #2455
dgully's Avatar
dgully
ok figured out, just took a bit, is there an easier way?
Old Jan 28, 2014 | 12:51 AM
  #2456
fordtrucknut's Avatar
fordtrucknut
Not Really, Photobucket and then copy and paste the image link...BTW...Very Sharp looking CREW!!!
Old Jan 28, 2014 | 12:00 PM
  #2457
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
You are doing what?
I may be the only one on the forum that has extensive knowledge of crew cab assembly, structure and cab joining.
You are going to need to drill spot welds along the windshield seam and save your crew roof intact unless it is totally rotted all the way around. Factory floor joints are obvious once you pull the seats.
Old Jan 28, 2014 | 01:04 PM
  #2458
Bobird's Avatar
Bobird
Thanks, looks like the joint is just under the seat. So middle door pillar will go with rear doors. Is the roof spot welded also or am I to make a surgical cut? Roof is only bad on one section pass side drip rail. I have a donor single cab that I was hoping to cut patches out of. Care to make a trip to sunny Cape Cod?
Old Jan 28, 2014 | 01:37 PM
  #2459
78_f800crewcab4x4
Maybe just cut the windshield pillar. That's easy to cut and join, no warpage and thicker metal. Then cut the welds along the floor pan, followed by cutting the rocker panel near or on the old joint. Make sure that you have everything leveled out and have the doors aligned perfectly on the donor cab, then match the door gaps before doing final welding.
I recommend starting a build thread and get your pic posting going. Then I can help if you have pics of what your doing or are about to do.
Old Jan 28, 2014 | 02:06 PM
  #2460
Bobird's Avatar
Bobird
Great thanks,
I'll get build thread going. I'm still trying to get my mind around the project so might be a little while. Till then I may bug you with more Q's
Is there a lot of work into swapping the 4x4 gear from my 75 600 4x4 to the 78 600 2x4? All trucks are in my photos.
Jim
