Crewcab Only Thread.
Old Feb 1, 2014 | 10:48 AM
  #2461
77&79F250's Avatar
77&79F250
Moderator & parts slinger
In case anyone in the area just won the lottery.....Ford 1978 F250 4x4 crew cab cummins Diesel
Not mine, cause I did NOT win.
Old Feb 1, 2014 | 11:11 AM
  #2462
Bobird's Avatar
Bobird
Nice, that's a good deal for someone !
Old Feb 1, 2014 | 04:28 PM
  #2463
choptop49ford's Avatar
choptop49ford
I wish that he had it for sale when I was looking. I wonder what the interior is like? My truck is almost done now but damn.....
Old Feb 3, 2014 | 01:11 PM
  #2464
USMC0351fordtruckin's Avatar
USMC0351fordtruckin
Originally Posted by bronkntrukholik
I found this '77 f250 4x2 cab at a local junkyard, I couldn't let it get crushed so I brought it home to be stored for a little while to I figure out what i wanna do with it , for a PA truck, it is pretty descent, has a little rust but is repairable
<a href="http://s179.photobucket.com/albums/w287/bronkntrukholik/Mobile%20Uploads/?action=view&current=downsized_1125091457.jpg" target="_blank"><img src="http://i179.photobucket.com/albums/w287/bronkntrukholik/Mobile%20Uploads/downsized_1125091457.jpg" border="0" alt="Photobucket"></a>
Did you get that cab from Clark's
Old Feb 3, 2014 | 10:52 PM
  #2465
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
Originally Posted by Bobird
Great thanks,
I'll get build thread going. I'm still trying to get my mind around the project so might be a little while. Till then I may bug you with more Q's
Is there a lot of work into swapping the 4x4 gear from my 75 600 4x4 to the 78 600 2x4? All trucks are in my photos.
Jim
They always appeared to have the same frame. Just dif springs and mounts and a t case mount.
Old Feb 8, 2014 | 09:30 AM
  #2466
77&79F250's Avatar
77&79F250
And here is a great priced rig for those looking. Not mine and it does not need to be either says the boss. lol
1976 Ford Crewcab 1 Ton Dually
Old Feb 8, 2014 | 10:34 AM
  #2467
choptop49ford
Thought this was a good photo opp
Old Feb 8, 2014 | 10:53 AM
  #2468
Bobird's Avatar
Bobird
Looks great! I've been trying to figure out a color for my build. Whites now a contender. Window tint looks good too.
Old Feb 8, 2014 | 11:32 AM
  #2469
choptop49ford
Thanks! Not a huge fan of white but it was the factory color and wembelton white is more of a cream so it's not bad, kinda growing on me. Still would like to find the trim for the rear doors and between the doors for the dent only) so I can break it up a little. If I don't find it I may go with the explorer stripes like my reg cab.
Old Feb 8, 2014 | 12:06 PM
  #2470
Eli1644's Avatar
Eli1644
Hey choptop what size tire and rims you got on the crew? Looks great!
Old Feb 8, 2014 | 12:33 PM
  #2471
choptop49ford
Thanks. They are 16.5 mags (powder coated) with 37/12.50s. They actually belong on my reg cab but I wanted to see how they looked after I lifted my crew. I have another set of the same sloted mags that I polished for my crew whenever I decide if I want to run 35's, 37's, or 38's.
Old Feb 8, 2014 | 04:16 PM
  #2472
Eli1644's Avatar
Eli1644
Nice. I'm looking for some tires. But 37's won't fit... Nice looking fords!
Old Feb 10, 2014 | 04:28 PM
  #2473
punkrockpilot's Avatar
punkrockpilot
just a lil crew **** from our SoCal meet in Pismo this weekend.
Old Feb 10, 2014 | 04:55 PM
  #2474
77_crew's Avatar
77_crew
your truck looks great punkrockpilot!!!
Old Feb 10, 2014 | 04:58 PM
  #2475
77_crew's Avatar
77_crew
HI guys. I already posted this in my cummins/crewcab build thread, but i thought that is might be a good idea to copy and paste it in this thread as well.....
Hey, can any of you guys that have the racetrack trim on their crew give me the length of the little short piece of LOWER trim that goes between the front and rear doors. I think the pillar measures around 2 1/2" so i was going to make a custom piece of trim around 2 1/4" long.
And can you tell me if it is square on both ends, or does one end have a slightly sloped end to help it clear the door when its opened just like the upper trim piece does.
I cut down a damaged front door piece, and was going to use both ends of it to make my two pieces, but then i noticed that it too has a slope on one end...so this got me thinking about this....
Thanks in advance!!
