IHC "Blue" CPS
Old Jan 24, 2006 | 05:48 AM
  #196
Craven's Avatar
Craven
Originally Posted by 99F-250lova
HX line for DI???
HX hose From Diesel Innovations. http://www.dieselinnovations.com/di.php
Old Jan 24, 2006 | 05:53 AM
  #197
99F-250lova's Avatar
99F-250lova
Oh ok, I just purchased SS HPX!
Old Jan 24, 2006 | 06:58 AM
  #198
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by Aarkie
You will need to get a pulse from an injector or someplace else for a reference as to when it is firing. This may help in telling what it is doing with the timing. If you just have the pluse you will not be able to say if it shifts the timing or not. Good luck.
Way ahead of you!! I have access to an optical tachometer here at work that also can be used as a triggering device for my DSO. What better way to check the correlation between CPS waveforms than by using a FIXED triggering signal on the crankshaft (which DIRECTLY drives the camshaft gear)?
FYI:
The camshaft 'reluctor' wheel has the open slots (or CPS "off-time") spaced 15 degrees apart. They are all of equal size EXCEPT one of them which is narrower signifying cylinder number 1 TDC compression. The PCM NEEDS to know exact location at all times.
Cody
Old Jan 24, 2006 | 08:11 AM
  #199
Kwikkordead's Avatar
Kwikkordead
HX line for DI???
Dieselinnovations had one of the early versions of the HX line made with flex hose. I have that on my truck and it's still dry and no bubbles. I made sure that both connectors are pointing at each other when I installed it. So far so good.
I'm getting the solid line at the first sign of trouble.
I think the HX line is the biggest contributor to a smooth idle in the morning. I never ever had the romps that so many complain about, but it was a lot noisier before I put in the line.
Old Jan 24, 2006 | 08:51 AM
  #200
fd1109's Avatar
fd1109
Picked mine up at the IH dealer for $100.08 . Installing it tonight , hopefully with some of the noticable benifiets that others have had.
Old Jan 24, 2006 | 09:16 AM
  #201
99F-250lova
wow, I just picked mine up for 72 dollars which included shipping.
Old Jan 24, 2006 | 09:18 AM
  #202
99F-250lova
Sorry, I thought you were talking about SS HPX.
Old Jan 24, 2006 | 08:35 PM
  #203
fd1109's Avatar
fd1109
Noticible differance with the Blue cps. Smoother idle , more responsive rev-up and seems to have more power, will have to see how the mileage is . This is good stuff!!
Pretty smooth going in also. Thanks
Old Jan 24, 2006 | 08:52 PM
  #204
fd1109's Avatar
fd1109
Will the "blue" work on a 96 psd?
Old Jan 24, 2006 | 10:13 PM
  #205
TXsnyper's Avatar
TXsnyper
I keep reading so many good things about the "blue" cps. I feel like a dumba$$ asking but what is the "blue" cps? Smoother running and 1.5 mpg better sounds like something I want to know more about.
Old Jan 24, 2006 | 10:15 PM
  #206
TXsnyper's Avatar
TXsnyper
Smile
[QUOTE=TXsnyper]I keep reading so many good things about the "blue" cps. I feel like a dumba$$ asking but what is the "blue" cps? Smoother running and 1.5 mpg better sounds like something I want to know more about.[If it ain't smoken, it ain't STROKEN !]
Old Jan 24, 2006 | 10:58 PM
  #207
Aarkie's Avatar
Aarkie
Cleatus12R, I was hoping you would be ahead of me but it never hurts to ask. Sounds like you can get your hands on some nice toys.
Old Jan 25, 2006 | 07:31 AM
  #208
Craven's Avatar
Craven
[QUOTE=TXsnyper]
It is a camshaft position sensor part # 1807339C92 made for the IHC DT466 engine, which seems to improve things when installed in our engines.
If you read this whole thread, every page. You'll know as much as everyone else, which is, no one knows why it works the way it does. All I can say is, it made my trucks engine quieter, smoother and I picked up over 1.5mpg.
Old Jan 25, 2006 | 07:35 AM
  #209
cleatus12r's Avatar
cleatus12r
Butt-Head
Nice toys, nah. But working as a tech in a Chevy dealership has its perks....job security being one of them.
Update:
Here is a list of mods/etc. and the approximate mileage of each. Keep in mind that this is all unloaded and the speed is the legal speed limit (75) that has been corrected for tire sizes (I'm **** about driving the speed limit). Also, all mileage is hand-figured (no lie-o-meter readings). I don't figure mileage on commuting....all 200+ mile trips.
1. Purchased truck with 4" exhaust, K&N intake, Western Diesel 60 HP chip, and 285/75-16s.
Best mileage attained: 14.6 and pretty well average for a few tankfuls.
2. Removed chip. Started using Power Service (white) religiously.
Best mileage: Not figured (couldn't stand to drive it).
3. Uploaded SCMT 90 HP tune. Tpok out "chip"....still have it, but it's worthless. Just makes lots of smoke and high EGTs.
Best mileage: 18.4
4. Purchased new tires in 255/85-16 size. (same height, just about 1.2 inches narrower per tire)
Best mileage: 20.56!!!
5. Installed "blue" CPS
Best mileage on FIRST TANKFUL: 21.95 MPG
Now, I realize that there are a LOT of variables when figuring mileage so with the advice from this board, here are the variable I have tried to keep as constant as possible:
Full tank (yes, to the top of the filler neck)
Same fueling station
Same pump too!!! Small town. Boulder, MT
SAME ROUTE every time...sometimes 200 miles, sometimes 420 miles.
Cruise control on 70.5 MPH the whole way. Only one interstate interchange and no traffic.
Maybe a fluke? Who knows? I'll keep track and let you know what I find out this weekend.
Cody
Old Jan 25, 2006 | 09:47 AM
  #210
4X4 IN REFUGIO's Avatar
4X4 IN REFUGIO
That Is Excellant Fuel Milage...... Wish I Could Get That..... Fuel Millage Does Vary From Truck To Truck.
The Best I've Ever Done Is About 17.5 - 18.0 Mpg. With All My Mods And Reasonable Driving ( Mostly Highway )
