IHC "Blue" CPS
Old Jan 1, 2006 | 08:21 PM
  #46
Miescha's Avatar
Miescha
PSNUT:
Great pics for a non-mechanic like myself. Thanks a million!
Old Jan 1, 2006 | 09:18 PM
  #47
dvfd12's Avatar
dvfd12
Do you have to shim it? it appears to be a little longer than the stock one or is that just from the flange out?
Old Jan 1, 2006 | 09:24 PM
  #48
guzzle92's Avatar
guzzle92
No shimming necessary...
Old Jan 2, 2006 | 05:25 PM
  #49
twags6's Avatar
twags6
Will the "blue" CPS work on the OBS trucks? My dad's got a 97 F-250HD 7.3L. From what we know its the original CPS. I'm planning on getting a blue one for my 01, but I'll pick up two if it'll work in his engine.
Old Jan 2, 2006 | 06:01 PM
  #50
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it will work on all years 7.3 powerstroke engines as far as i know.
Old Jan 3, 2006 | 06:11 PM
  #51
PSNut's Avatar
PSNut
Got my blue CPS in tonight...will keep u posted on changes.
Old Jan 3, 2006 | 06:24 PM
  #52
jtharvey's Avatar
jtharvey
Please, keep us updated. I just ordered mine today. I'm hoping it will be here by the weekend!!
Old Jan 3, 2006 | 07:21 PM
  #53
empiretc's Avatar
empiretc
Mine still hasnt come in...
Old Jan 3, 2006 | 07:36 PM
  #54
jtharvey's Avatar
jtharvey
Where did you order if from and when? I ordered mine from Diesel Power Products.
Old Jan 3, 2006 | 07:45 PM
  #55
PSNut's Avatar
PSNut
Just picked it up at the IHC dealer on my way home from work.$102.
Took 10min to change. Tough time getting old one out. difficult access.
Old Jan 3, 2006 | 07:54 PM
  #56
blown99's Avatar
blown99
You guys should at least check the air gap on your cam sensors. .025 - .030 is the spec. There are two different size/length sensors so be sure you install teh correct length sensor. After working at international for 10 yrs I've replaced many many blue sensors in the DT and a fraction of them have been the black sensors from the T444E. We used to put the black ones in some DT's that had continuous problems with cmp noise.
Old Jan 3, 2006 | 07:59 PM
  #57
dvfd12's Avatar
dvfd12
Dumb question. How do you check?
Old Jan 3, 2006 | 08:11 PM
  #58
PSNut's Avatar
PSNut
I believe the part # posted in this thread is correct and not the p/n for the wrong one.
Old Jan 3, 2006 | 08:20 PM
  #59
blown99's Avatar
blown99
"I believe the part # posted in this thread is correct and not the p/n for the wrong one."
Just saying, don't walk into an international dealer and say give me a blue cam sensor as there are several different ones.
You would have to check the clearence with a depth mic. Navistar has a very nice tool that takes all the guess work out of the job. With a depth mic., remove the sensor, install the mic into the sensor hole, and run it in until it bottoms out on a vane of the pick up wheel and read what the mic is. Then measure the flange of the sensor to the base. Subtract the two readings and you should be in the .025 - .030 range. I have found on many 444 that the air gap is to large and the front cover needs to be sanded/ground down a bit to put the clearence back into spec. I've seen the sensors working but cutting out intermittantly with air gaps of .050", ground the cover and reinstalled the sensor and never had a problem since.
Old Jan 3, 2006 | 08:22 PM
  #60
dvfd12's Avatar
dvfd12
Thank you.
