400 HP Engine Build - Input Needed
Old Oct 31, 2022 | 12:41 PM
  #406
PriusLover's Avatar
PriusLover
Second time better be the charm
Old Oct 31, 2022 | 02:18 PM
  #407
Walleye Hunter's Avatar
Walleye Hunter
Good luck!
Old Oct 31, 2022 | 06:00 PM
  #408
ESwift's Avatar
ESwift
CNCFAB
We need details! :-)
Old Oct 31, 2022 | 06:31 PM
  #409
FordTruckNoob's Avatar
FordTruckNoob
It is a built spare engine from a recently retired pro tractor pulling team I bet.
Old Dec 8, 2022 | 11:37 PM
  #410
PriusLover's Avatar
PriusLover
One head turned out to be cracked. Junkyard was able to source another one... hopefully this checks out and we'll be all good.
Crazy how common cracked heads are on 7.3. I wonder if that's due to people tuning without keeping track of combination temps?
Old Dec 9, 2022 | 07:33 AM
  #411
FordTruckNoob
Ayyyayay. Sorry to hear that.
I think your guess for why there are so many cracked heads is a good one. I have seen/heard so many stories of people paying attention to EGTs only after the engine has blown at least once. *raises hand guiltily*
Old Dec 9, 2022 | 09:17 AM
  #412
z31freakify's Avatar
z31freakify
Was the crack between the valves? My old mill had cracks on them in those places had to use another set of heads for that reason. Good luck on your engine build.
Old Dec 9, 2022 | 09:24 AM
  #413
F350towing's Avatar
F350towing
Hmmm…
A crack head, Maybe it came from the wrong side of the truck???
Seriously though I’ve been following and feel for you as you go through all hoops to get this done.
Old Dec 9, 2022 | 12:14 PM
  #414
PriusLover's Avatar
PriusLover
The original heads both had cracks between valves and some radiating outward from the glowplug and injector holes (no doubt stress risers). The bad head on the core engine had one crack radiating from a valve (past the seat). Maybe a combination of beyond-design-limit combustion temps, thermal cycling, and a lack of adequate chamfer on those areas?
My OG heads were running fine even with the cracks so who knows how big of an issue they present in practice.
Old Jan 14, 2023 | 04:13 PM
  #415
PriusLover's Avatar
PriusLover
Two junkyard heads later and I still haven't found one without crack. No choice but to keep going though.
On the plus side, block machining should start next week! If I can find a second head soon the machining work should be complete in a few weeks.
When head surfaces this shop always produces a surface Ra that's friendly to MLS head gaskets. I've seen it mentioned that composite gaskets need some "seasoning" time where you need to be mindful of the cylinder pressures... if the shop is going to machine the head surface fine enough for MLS, there any downside to using Cometic gaskets for this build? I've heard they are good to go from the start and don't require the "seasoning" period.
Also is it worthwhile to cryo treat stock forged rods? Or at they proven to 800-1000 ft-lb?
Old Jan 14, 2023 | 06:25 PM
  #416
FordTruckNoob
Happy New Year @PriusLover !! Haven't seen you in awhile. Glad to hear things are progressing although I have to ask, have you considered a Cummins swap after finding so many cracked Powerstroke blocks?
Old Jan 14, 2023 | 06:35 PM
  #417
FinnishStroker's Avatar
FinnishStroker
Only cracked heads?
One block was dropped and screwed by machine shop?
Old Jan 14, 2023 | 07:04 PM
  #418
PriusLover's Avatar
PriusLover
Cheers. I thought about it before this all began but it seems like a lot of headache, money, and if I was going to do the work I'd rather put one in a pre-2017 6.7 superduty with an nicer body and interior. Plus I don't have a garage.
Originally Posted by FinnishStroker
Only cracked heads? One block was dropped and screwed by machine shop?
Here's the total count:
-Original block was ****ed up by shop #1, they sourced a another one and did shoddy work on it.
-Both OG heads were cracked, so I bought replacements, which they did shoddy work on.
-Shop #1 kept the engine they ****ed up and reimbursed me for a core (engine #2) I procured from a junkyard.
-Shop #2 said all the parts from engine #2 were good except one cracked head. Junkyard supplied me with another head which turned out to be cracked as well... and then another head which turned out to be cracked as well.
So next week will be about trying to find a head that isn't cracked lol. So far more common areas are the valve seats, with cracks extending below were the new seats will go. New machinist thinks this is due to Intl using the bare iron as the valve seat face.
Old Jan 14, 2023 | 07:56 PM
  #419
FordTruckNoob
I suck at the reading comprehension. I mean cracked heads.Here's a set, no cracks guaranteed.
https://killdevildiesel.com/collecti...der-heads-pair
Old Jan 14, 2023 | 08:23 PM
  #420
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Does KDD machine heads in the USA that are cast in overseas?
