400 HP Engine Build - Input Needed
Old Mar 11, 2022 | 07:26 PM
  #31
FordTruckNoob's Avatar
FordTruckNoob
Eggcellent
Old Mar 12, 2022 | 07:21 AM
  #32
FinnishStroker's Avatar
FinnishStroker
Originally Posted by Bitterroot Diesel
No taxes or shipping charges
International sales too?
Old Mar 12, 2022 | 07:24 AM
  #33
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
International customers have to pay shipping and duties.
Old Mar 12, 2022 | 07:30 AM
  #34
FinnishStroker
Just teasing.
Is my free injector flow test still available?
PriusLover
I'm running DIY 205/80 hybrids with 44psi/3bar boost.
Stock valve springs and head bolts.
525k miles unopened engine.
Old Mar 12, 2022 | 07:31 AM
  #35
Bitterroot Diesel
Former Vendor
Yes Sir it is.
Old Mar 12, 2022 | 01:14 PM
  #36
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I'm curious as heck about the source of the metal grindage. Please go forensic when the engine is opened up to pinpoint the issue.
Old Mar 12, 2022 | 04:23 PM
  #37
Bill Kay's Avatar
Bill Kay
I didn’t see anyone reply to the Bosch glow plugs you have listed. In the past the FTE group only recommended genuine Motorcraft(careful not to buy fakes) or the Beru plugs. Beru is the original manufacturer of the Motorcraft glow plugs.
Maybe the FTE community has accepted the Bosch plugs and I am just not aware of it as I’m not on here as much as I use to be.
Good luck!
Old Mar 12, 2022 | 07:07 PM
  #38
PriusLover's Avatar
PriusLover
Stock valve springs and head bolts​​​​​
Good that stock headbolts should work. I'm surprised that you're running that level of boost with stock springs. That's about 96 pounds force on the valve being held closed by springs that are probably rather tired at this point.
What kind of exhaust backpressure do we see with a max of 40PSI boost? Based on the limited info available it's ~ 60 PSI? That'd equate to 131lb force on the exhaust valve, 87 on the intake valve. Seems the 910s can be shimmed to provide the needed force to counteract those pressures, while the beehives should not only provide the needed force but also stay at that spec longer than the 910s. Feel free to correct me if my math or assumptions are off.
Went ahead and ordered the beehives because KC Turbos had them far cheaper than elsewhere (lifters too).
I'm quite curious myself and eager to see what it looks like inside.
Old Mar 12, 2022 | 07:16 PM
  #39
Bitterroot Diesel
Former Vendor
Bosch makes great automotive components. I wouldn't be afraid to use Bosch glow plugs.
Old Mar 12, 2022 | 07:23 PM
  #40
FordTruckNoob
If memory serves, mine was at about 45psi for EBP. However, that was an instantaneous reading while boost was building to a controller limited maximum of 50psi during data-logging runs.
Old Mar 13, 2022 | 12:48 PM
  #41
PriusLover's Avatar
PriusLover
Got our strong coffees made for the engine pull today. Never done this before so should be interesting
Old Mar 13, 2022 | 12:59 PM
  #42
FordTruckNoob
Please set up a live webcam feed.
Old Mar 13, 2022 | 05:14 PM
  #43
Dan V's Avatar
Dan V
That does not look like strong coffee that I'm used to.
"Strong enough to float a bullet..hot enough to make it go off."
Old Mar 13, 2022 | 05:22 PM
  #44
FordTruckNoob
Not everybody drinks bitumen like you Dan.
Old Mar 13, 2022 | 07:25 PM
  #45
SkySkiJason's Avatar
SkySkiJason
This guy pulls a 7.3 in under 2mins here!!
https://m.youtube.com/watch?v=lX5yQDqChx0
