EBPV delete
Old May 2, 2022 | 10:47 AM
  #181
SkySkiJason's Avatar
SkySkiJason
Originally Posted by smitty59
Has anyone else had a problem taking the ebp line to exaust manifold off? I took mine off yesterday and stripped the connector from line to manifold. I have a new line from when I changed the EBP sensor but I had to order a new manifold conector from RiffRaff.
Yes, exhaust parts are famous for SUCKING like that. Penetrant is your friend. Oxy/acetylene (thermal manipulation) are your friends when that doesn’t work.
Old May 2, 2022 | 01:32 PM
  #182
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I removed and cleaned my EBPS tube years ago and at ~200,000 miles. It too was a bear to budge off and a bit of 50/50 ATF/isopropyl alcohol worked well at getting the fitting off. I too thought I was going to break it, but it eventually came off. I ended having to order a new EBPS as the original was done for.
It happens and at least it was not an expensive or labor intensive part to replace.
Old May 3, 2022 | 08:02 AM
  #183
smitty59's Avatar
smitty59
Thanks guys I thought I had done something wrong. I sprayed it withPB Blaster and broke a 16mm box end wrench trying to get it off. My son finally got it off with a 5/8" wrench and a pipe cheater! Shipping was more expensive than the part!!!!!!
Old May 3, 2022 | 10:08 AM
  #184
Kwikkordead's Avatar
Kwikkordead
I used to call it "thermal persuasion".
Those old air cooled VWs that had the exhaust nuts rusted to the studs when I was just trying to replace a rotted muffler never stood a chance when they were heated up red hot and then some gentle persuasion applied. If a stud broke off, then it was time to replace the cylinder head on those old aluminum heads and I didn't want to have to go through all that just for a broken stud. (Gotta keep the good customer relations intact. )
Old May 3, 2022 | 10:45 AM
  #185
FordTruckNoob's Avatar
FordTruckNoob
For heating metal without an open flame, there is this:
https://smile.amazon.com/Bolt-Buster...ps%2C80&sr=8-5
Old May 3, 2022 | 01:57 PM
  #186
smitty59's Avatar
smitty59
IMPRESSIVE!!!!!!!! I got a little work done on the 7.3 today.
Old May 3, 2022 | 02:10 PM
  #187
smitty59's Avatar
smitty59
Old May 3, 2022 | 02:27 PM
  #188
SkySkiJason
That’s NICE!!!
Old May 3, 2022 | 02:58 PM
  #189
brian42's Avatar
brian42
Veteran: Navy
So that's what the valley looks like!
Old May 3, 2022 | 03:13 PM
  #190
Sous's Avatar
Sous
FTE Emeritus
I really should have painted my engine valley when I had everything out of it in 2018... Looking great sir, keep up the good work!
Originally Posted by Brian42
​​​​​​​So that's what the valley looks like!
Old May 3, 2022 | 04:14 PM
  #191
smitty59's Avatar
smitty59
Thank you guys! I would have never been able to tackle this project without you guys' advice,knowledge and support so again thanks!!!!! I will keep ya'llposted with the progress.....
Old May 3, 2022 | 06:01 PM
  #192
RacinJasonWV's Avatar
RacinJasonWV
Keep coming back and we’ll keep spending your money!
Looking good. Can’t wait to hear your impressions once it’s back together.
Old May 8, 2022 | 01:30 PM
  #193
smitty59's Avatar
smitty59
Hey guys, being it's Momma's Day weekend I didn't get to the 7.3. Did a lot of yard work that she wanted done. I put 8 tons of fresh sand on the beach, built her a new swing down on the point by the picknic table,added cap block on the seawall and trimmed limbs on the Leland Cypress trees. Whew I'm whooped!!! Hopefully I will get back on it when she goes back to work tomorrow.LOL!!!! I will take some pics of the progress.
Old May 8, 2022 | 07:25 PM
  #194
RacinJasonWV
Any photos? Sound interesting.
Old May 11, 2022 | 11:03 AM
  #195
smitty59's Avatar
smitty59
Neighbor's fence
