EBPV delete
Old Jan 19, 2022 | 09:37 AM
  #31
Kwikkordead's Avatar
Kwikkordead
Originally Posted by Y2KW57
How bad does a leak have to be to need attention on a regular basis?
Was oil running out?
Or was there just a witness film of sooty grime covering the area?
It was dripping off the bottom of the bell housing and subsequently spotting the front of my nice, clean, and freshly washed RV.
Old Jan 19, 2022 | 09:46 AM
  #32
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That sounds like a lot of leaking for an EBPV.
Mine only has the oily grime film and discoloration.
No drips under the truck.
Old Jan 19, 2022 | 11:20 AM
  #33
smitty59's Avatar
smitty59
What do you guys think about a Wicked Wheel for the turbo?
Old Jan 19, 2022 | 11:25 AM
  #34
Kwikkordead
It was one of the first and best mods I did for my truck. Had a LOT of compressor stall when pulling the 5th wheel up hills. WW cured that 100%, and as an added bonus, gave it the nice, classic turbo whistle.
Old Jan 19, 2022 | 11:36 AM
  #35
smitty59's Avatar
smitty59
Thanks kwikkordead!
Old Jan 19, 2022 | 12:01 PM
  #36
RacinJasonWV's Avatar
RacinJasonWV
Wicked wheel is outdated.
Billet wheel is the current upgrade go-to part.
I like the 4/4 wheel Riffraff sells.
You could also spring for the KC balanced assembly which incorporates a redesigned turbine. It also comes with a rebuild kit I believe.
Leaking EBPV…
Dad’s 325k truck appeared to leak from the EBPV slightly. I would see just a few dribbles on the ground at times when parked. I never did a detailed diagnosis but it looked to be a small leak the the rod of the actuator. From memory it was (actively) wet at the rod. Not enough of a leak to worry about so he rolled with it. It was worse in winter which I figured was due to the rod actuating more. Again, just assumptions though.
Old Jan 19, 2022 | 12:13 PM
  #37
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Instead of repeating information stated by another FTE'r, I will simply quote them. Which I have done below.
I ran the Riffraff 4/4 for quite a few years and it was a solid performer.
Old Jan 19, 2022 | 07:06 PM
  #38
T-wood's Avatar
T-wood
I always thought the leak from the ebpv was hastened/encouraged by inactivity. All of mine are disconnected and flap wired open. Except on my truck and i did rebuild it. But still havent used it as a exhaust brake. Cody your endorsement here makes me want to try it.
I dont notice its loss for warming up my excursion or van. Seat heaters warm me up in the ex. And my van gets to park in the garage (equipment theft prevention). So cold mornings arent so bad rolling to work.
Old Jan 20, 2022 | 07:23 AM
  #39
SkySkiJason's Avatar
SkySkiJason
I have fixed a number of trucks that the EBPV poured oil onto the ground while activated. I agree that ‘lack of use’ was the most likely cause.
I often find a lot of dirt and grime inside the pedestal where the actuator rod exits. Perhaps lack of use and build-up of grime (plugging the drain hole?) is the cause of some of the leaks I see?
Old Jan 24, 2022 | 09:09 AM
  #40
smitty59's Avatar
smitty59
Ok guys I think I have made up my mind. I am going to order : KC balanced turbo wheel kit, EBPV delete pedestal, Up pipe upgrade and new intake boots. What am I forgetting?
Old Jan 24, 2022 | 09:23 AM
  #41
kbeefy's Avatar
kbeefy
Might as well get plenum inserts.
Old Jan 24, 2022 | 09:25 AM
  #42
BWST's Avatar
BWST
Got Data?
‘While you’re in there’ consider removing the clamps on fuel lines from filter to heads before they rub through the lines. SS braided hoses from Riffraff are solid upgrade for reliability.
Upgrading to JIC HPOP lines from Riffraff is also a recommended upgrade.
No matter what, rebuild the water drain valve on fuel bowl with the upgraded ‘blue’ o-rings.
Plenum inserts, t-bolt clamps to replace the worm clamps and Riffraff CAC boots are other good options.
Consider doing all of these items SSJ suggested.
Old Jan 24, 2022 | 09:26 AM
  #43
Rot Box 2's Avatar
Rot Box 2
Is the ebpv delete turbo housing in your cart as well? I went with the plenum inserts as well to prevent crushing while I had it down that far
Old Jan 24, 2022 | 01:20 PM
  #44
brian42's Avatar
brian42
Veteran: Navy
If you get the plenum inserts I recommend "upgrading" the clamps to the boot clamps instead of worm clamps.
Old Jan 24, 2022 | 01:26 PM
  #45
z31freakify's Avatar
z31freakify
You can get these instead of the inserts gets rid of the flimsy plenums, although not as bad *** as Clay's plenums with O ring but its cheap alternative and gives you the opportunity of re sealing the plenums.
https://www.ebay.com/itm/20341396531...3ABFBM2vbT2NFf
