EBPV delete
Old Apr 6, 2022 | 08:21 AM
  #121
smitty59's Avatar
smitty59
Anyone tell me where I can go to get a CCV relocate that I can buy the parts rather than pay for the kit and pay for shipping?
Old Apr 6, 2022 | 08:41 AM
  #122
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
FTE'r @JimmyWayne23 appears to have made his own version of the CCV mod in the post linked below.
Link: https://www.ford-trucks.com/forums/1...l#post20352546
FTE'r F0rdC0wB0y went with the International draft tube in one of his 7.3L's. Not really in line with your question, but a great option if you are going to delete the CCV tube to the intake.
Link: https://www.ford-trucks.com/forums/1...l#post20163739
Alternatively, take some measurements and get some angles and go to a parts store to build your own draft tube. I did a similar thing when I went to a T4 kit and needed a much longer and angled CCV tube.
Old Apr 6, 2022 | 12:57 PM
  #123
SkySkiJason's Avatar
SkySkiJason
Flip the doghouse around the other way and run straight 3/4” hose out to the firewall, over the brake booster and down under the truck.
The upward slope away from doghouse will help oil vapors condense and drain back to engine instead of blowing all over under the truck.
Cold climates beware of places in a longer hose that water can condense and freeze - blocking the tube.
Old Apr 6, 2022 | 12:59 PM
  #124
RacinJasonWV's Avatar
RacinJasonWV
I bought the specific grade (oil resistant) hose, a brass coupling nipple, some hose clamps, and a set of CCV doghouse orings. Turn the doghouse around. Loop the hose up over the master cylinder and keep a downward slope to the exit point along the frame. Mine exits right in front of the fuel tank.
Old Apr 6, 2022 | 02:00 PM
  #125
smitty59's Avatar
smitty59
Great,thanks guys!!
Old Apr 10, 2022 | 08:57 AM
  #126
smitty59's Avatar
smitty59
Hey guys it's me again, like I said before"I dont know what I would do without my FTE friends". I would like to know if I should upgrade the OE banjo bolts to RR banjo bolts.Thank you guys for your knowledge and wisdom......
Old Apr 10, 2022 | 09:16 AM
  #127
Sous's Avatar
Sous
FTE Emeritus
In my humble opinion, no. No I would not upgrade to the RR banjo bolts and I did not upgrade to them.
Again, just my opinion.
Old Apr 10, 2022 | 10:56 AM
  #128
SkySkiJason
I’ve never ‘upgraded’ banjo bolts or fuel line fittings.
Old Apr 10, 2022 | 11:08 AM
  #129
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Stock banjo bolts here as well.
Old Apr 10, 2022 | 02:56 PM
  #130
smitty59's Avatar
smitty59
Thank all of you for your opinions.You guys are awesome!!!!!!!
Old Apr 11, 2022 | 08:05 AM
  #131
smitty59's Avatar
smitty59
Hey SSJ I was cleaning the spider yesterday and I tried to put compressed air through the small port that has the blue cap on it in this picture and it seemed to be completely clogged.
Old Apr 11, 2022 | 10:47 AM
  #132
brian42's Avatar
brian42
Veteran: Navy
There's an orifice in that port (at the wall of the spider). It's only 1-2mm wide so any air you blow in there will feel like it's clogged.
Old Apr 11, 2022 | 12:09 PM
  #133
smitty59's Avatar
smitty59
Oh ok thank you my friend!!!!!!
Old Apr 12, 2022 | 01:00 PM
  #134
smitty59's Avatar
smitty59
Is it necessary to keep the foil wrap insulation on the driver side hot pipe?
Old Apr 12, 2022 | 02:07 PM
  #135
brian42's Avatar
brian42
Veteran: Navy
Nope. Many of us have deleted it.
I got tired of it once it started to crack and peel so deleted it for a better appearance (and to stop nicking my fingers on the edges).
I don't know how much heat it actually insulates (in or out of the pipe) but it does insulate some sound. IIRC I could hear the turbo a little more after taking the insulation off.
