EBPV delete
Old Mar 27, 2022 | 11:34 AM
  #106
smitty59's Avatar
smitty59
SSJ what do you plug the red and green line connections with?
Old Mar 27, 2022 | 02:24 PM
  #107
SkySkiJason's Avatar
SkySkiJason
The port on the 5-way plenum gets a vacuum plug and a tiny zip tie to hold it on. The hole in intake tube for green hose gets a screw/bolt.
Old Mar 27, 2022 | 02:36 PM
  #108
smitty59's Avatar
smitty59
Thank you very much my friend. The tear down is done and in the process of cleaning the valley. A lot of junk and oil residue in the valley.Still a lot of cleaning to do before painting and assembly but slowly but surely.
Old Mar 27, 2022 | 03:32 PM
  #109
SkySkiJason
Found a pic of plugged spider.
Old Mar 27, 2022 | 03:34 PM
  #110
smitty59's Avatar
smitty59
Cool thank you!!!!!!
Old Mar 27, 2022 | 05:02 PM
  #111
smitty59's Avatar
smitty59
SSJ with the mods I'm doing and deleting the red and green do I need RiffRaff OCR?
Old Mar 28, 2022 | 06:44 AM
  #112
SkySkiJason
I don’t remember what mods you’re doing. With no chip, you probably won’t see +24psi that would set SES. If you have a chip with good tuning, it won’t set SES light. If you have a chip with ‘poor tuning’, the SES light will come on for awhile after you exceed +24psi - not the end of the world.
There is a small group who believe that the boost foolers ‘protect’ the MAP sensor, but 1000’s of us have been showing the MAP sensor 30, 40, and even over 50psi for YEARS without damage.
Old Mar 28, 2022 | 11:46 AM
  #113
brian42's Avatar
brian42
Veteran: Navy
I did the same. The bolt in the intake tube got a dab of RTV around the head to make sure it stayed in place and makes a good seal.
I got tired of replacing the vacuum cap every so often (it gets hot under the hood so eventually dries out and cracks) so ended up converting the port into a 1/16" NPT cap:
My 9 Month Long Summer Project (Injectors, Cups, Gauges, Racor, and More) - Page 2 - Ford Truck Enthusiasts Forums (ford-trucks.com)
If you look inside the spider, the orifice (opening) is actually only a couple of millimeters wide but I went whole hog and plugged it permanently.
Old Mar 29, 2022 | 07:44 AM
  #114
smitty59's Avatar
smitty59
Thank you guys for your help.I'd be lost without ya'll!!!!!!
Old Mar 29, 2022 | 10:38 AM
  #115
smitty59's Avatar
smitty59
Hey ya'll,let me say first that I value ya'lls opinions. My 7.3 has nearly 300k on it and I have it torn down to the bare valley,heads,plenums and valve covers. I would like to ask if ya'll think,while I have it down this far,should I pull the GP's and injectors (OEM) and replace GP's and have the Injectors rebuilt? Thanks in advance for your input.....
Old Mar 29, 2022 | 06:41 PM
  #116
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
You can test the GP's with a multimeter to see if they are still functioning. You can also pull one to verify they are of good quality.
As for the injectors, don't fix it until it breaks...
Old Mar 29, 2022 | 07:33 PM
  #117
kd5zll's Avatar
kd5zll
Bail out! Bail out! Bail out! That was my mistake.... i decided to change glow plugs.....
Old Mar 30, 2022 | 05:12 PM
  #118
smitty59's Avatar
smitty59
Thank you guys,I appreciate ya.I assume checking the GPs whith an ohm meter on the UVCG plug.Is that right?
Old Mar 30, 2022 | 07:21 PM
  #119
RacinJasonWV's Avatar
RacinJasonWV
You should be able to check them directly with the valve covers off.
But yes, you can also check through the connector on the gasket plug.
Old Mar 31, 2022 | 05:40 AM
  #120
smitty59's Avatar
smitty59
Thank you RacinJasonWV!
