EBPV delete
Old Feb 4, 2022 | 08:06 AM
  #76
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by smitty59
Hey everybody I will have all of my upgrade parts by the end of today but I don't think I will be able to start the tear down this weekend. I don't know when yet but when I do I hope ya''l will wish me luck that all goes smooth and solves all of my 7.3 issues. Thank you all for your support!!!!!
You will do great!
Just take your time, think about the task at hand and then execute. We (the FTE community) are here to help you along the way. We can certainly be of help here on the forum and in person at times. I see you are near lake Oconee in GA. We have been known to show up and help a fellow FTE'r out when they need assistance. I have been on the receiving end of this act of kindness before and it was a life saver for me and my family.
One thing you can do prior to starting the actual work, get your sequence of removal and installation set on a piece of paper. That way, you won't waste time saying things like "OK, what is next..."
Old Feb 4, 2022 | 05:34 PM
  #77
smitty59's Avatar
smitty59
Thank you Sous, I will do that and thanks for the advice and encouragement!
Old Feb 4, 2022 | 08:16 PM
  #78
carl2591's Avatar
carl2591
not sure how tall your tire are, but i jacked each side up, took off the tires, put a couple of bolt back on to hold the rotors on and lowered them on to a 2x6 on the ground.. make getting in and working a bit easier.. I took me a couple week working a couple days and getting parts, find something else and take care of that..
I did turbo bearing to 360, smoothed out inside the exhaust side of turbo so EBPV valve did not hang up when closed, updated o'rings in pedestal, repiped fuel lines with port in rear driver head, water pump and t-stat to 205, new o ring in fuel bowl, replace regulator, rebuild sensor on HPOP, new HPOP lines and fitting on lines, top radiator hose replace with ambulance type that goes around the belt vs through, etc etc etc/
Old Feb 7, 2022 | 12:01 PM
  #79
smitty59's Avatar
smitty59
It's me AGAIN!!!! Before I start on my adventure I'm trying to gather everything I need, like Sous suggested.I was wondering what sealant I need to use on the plenums,threads on bolts and where to use what grade# of Locktite and where to use it. Any advice in this area would be greatly appreciated.
Old Feb 7, 2022 | 06:45 PM
  #80
Sous's Avatar
Sous
FTE Emeritus
Plenum sealant is TA-31 and is gray in color.
@Wes444 is good with loctite and their proper applications. Perhaps he can offer some advice.
Old Feb 7, 2022 | 06:54 PM
  #81
Wes444's Avatar
Wes444
I haven't done plenums yet, so haven't researched loctite for those particular bolts. My guess would be 242 or 243.
Most your loctite choices are based off the size of the bolt being used. Occasionally, like with 242 & 243 the ratings are for the same size bolts. The difference being 242 is not oil resistant so requires living room coffee table assembly like cleanliness for proper cure. Vs 243 is oil resistant to obtain full strength during cure so you don't have to be so stringent in your cleaning practices.
So, if the plenum bolts fall into the size rating for the two loctites I mentioned I'd recommend 243
which is good for 1/4” to 3/4” bolts with a break free strength of 230inch pounds. 242 has the same ratings, but it's not oil resistant for it's cure
That said if the plenum bolts are 1/4" I'd be leary of using 243 in that application unless the bolts used are above a grade 5, or 8.8 if metric. Reason being the hold strength of the loctite can be higher than the bolt's shear rating for cheap grade Chinesium or bulk bin bolts
Old Feb 8, 2022 | 07:38 AM
  #82
smitty59's Avatar
smitty59
Thank you for the great info.I'm not sure what size bolts are in the plenums yet but I will make the decision on Locktite after I pull one. Again thanks I have an idea on which one to use now.
Old Feb 8, 2022 | 09:10 AM
  #83
SkySkiJason's Avatar
SkySkiJason
If plenums are resealed with TA31, the bolts are probably not required after it cures. I’ve never used thread locker on them and don’t think I’ve ever found them loose from the factory.
Old Feb 8, 2022 | 11:43 AM
  #84
smitty59's Avatar
smitty59
Sounds good.I just drove my truck 24 miles and my gauge showed 0 EBP cold and 0 EBP hot.Good thing I'm gojng to delete.
Old Feb 8, 2022 | 12:29 PM
  #85
SkySkiJason
The EBPV should only close at idle or under certain, rare light throttle conditions.
There will always be exhaust back pressure while driving. This is a measure of the resistance of air going through the turbo. Ideally, we want a 1:1 ratio or lower (EBP to boost ratio).
I think some tuning strategies use the EBPS (off front of passenger side exhaust manifold), so deleting this is not usually recommended.
Old Feb 8, 2022 | 08:27 PM
  #86
Wes444's Avatar
Wes444
So my ebp sensor pigtail clips were not fully seated inside the pigtail, and it ran very odd at idle, almost like a random injector would have 5 times the ICP as the others going to it. Not the same injector and a steady rhythm of a one bad injector, but a random injector here and there every 2h4 seconds. No codes, hard or soft. Then the ebp read 48.5 at all times, even with the engine off.
Not sure why yours would read zero tho. Make sure it's plugged in, if so you probably need to clean the tube. Chuck some weed eater string into a drill. Or if it's really bad a broken bicycle cable on the drill to clean it out. Your ebp tube could be completely rusted thru too, some have posted pictures of theirs being in two pieces.
Old Feb 9, 2022 | 08:24 AM
  #87
smitty59's Avatar
smitty59
I replaced the EBPS and cleaned the tube less than a year ago. I don't know why the tube would be clogged up so soon because it had 290k on it when I replaced sensor and cleaned the tube. All of this started after the ""NO SERVICE"" fiasco!!!!!!!
Old Feb 9, 2022 | 08:32 AM
  #88
smitty59's Avatar
smitty59
Hey SkySkiJason is that paint or powder coat on turbo, pedestal and spider? Pics posted 1/25/2022
Old Feb 9, 2022 | 10:50 AM
  #89
SkySkiJason
All paint. I use rustoleum 2x coverage spray paint for everything that is not exhaust/HOT and VHT ‘flameproof’ header paint (2000*F) on those parts.
Surface prep is key to success. Everything must be 100% free of oil/grease being critical.
Old Feb 9, 2022 | 12:29 PM
  #90
smitty59's Avatar
smitty59
Gotcha!!! Thank you so much my friend. Do you ever bead blast any of the parts?
