EBPV delete
Old Apr 12, 2022 | 02:30 PM
  #136
smitty59's Avatar
smitty59
That's what I wanted to hear!That thing really looks bad under the hood.
Old Apr 12, 2022 | 04:25 PM
  #137
RacinJasonWV's Avatar
RacinJasonWV
So you liked hearing this answer to your question or want to hear more of the turbo?
Puns are fun.
Old Apr 13, 2022 | 07:24 AM
  #138
smitty59's Avatar
smitty59
HaHaHa both!!!!!!!
Old Apr 13, 2022 | 12:16 PM
  #139
smitty59's Avatar
smitty59
How many turns on the wastegate rod can I safely do after deleting the red and green hoses?
Old Apr 13, 2022 | 01:39 PM
  #140
cleatus12r's Avatar
cleatus12r
Butt-Head
If it's a factory rod, you won't be able to turn it in enough to totally bottom it out. To totally bottom out the actuator to keep the wastegate from opening at all (be forewarned, if you don't relieve the crimp by heating or grinding, you might twist the rod off), you need to remove the eye end and cut off about 8-10mm of threads.
Safely? No modifications are "safe" but a stock-injector vehicle can completely disable it.
Old Apr 13, 2022 | 03:15 PM
  #141
smitty59's Avatar
smitty59
Thank you sir!
Old Apr 13, 2022 | 06:36 PM
  #142
RacinJasonWV
Yep, I broke one on Dad’s truck when rebuilding his turbo due to the crimp. Good thing I had a used spare on hand.
Old Apr 14, 2022 | 07:37 AM
  #143
smitty59's Avatar
smitty59
Thanks for the heads up on the crimp.I probably would have grabbed the thing with a pair of Chanel Lock pliers and gave her a good cranking!!!!!
Old Apr 14, 2022 | 07:52 AM
  #144
smitty59's Avatar
smitty59
How about just a turbo wastegate actuator upgrade 33psi from Amazon?
Old Apr 14, 2022 | 08:01 AM
  #145
FordTruckNoob's Avatar
FordTruckNoob
I have always wondered why we don’t just get rid of the actuator and safety-wire the wastegate shut on the MSTs.
Old Apr 14, 2022 | 09:18 AM
  #146
brian42's Avatar
brian42
Veteran: Navy
I didn't because I would fail my smog check.
Non-OEM looking wastegate controller = fail (have that t-shirt)
No red/green lines = fail (have that t-shirt)
Red/green lines not hooked up = fail (have that t-shirt)
Turbo does not have GARRETT stamped in the housing = fail
At least that's the way it goes in my neck of the woods.
Old Apr 14, 2022 | 09:26 AM
  #147
FordTruckNoob
I have always wondered why people live in states with smog checks.
I keed I keed.
Old Apr 14, 2022 | 09:43 AM
  #148
SkySkiJason's Avatar
SkySkiJason
Waste of time and money. We don’t need a WG for a properly-sized and set up turbo.
Need a ‘WG actuator eliminator’. Safety wired shut is ghetto.
Some weld it shut and no actuator is required.
The truth is a cranked-down factory actuator is economically superior (free), easy and adequately effective.
The WG’s primary job is to prevent over speeding the turbine shaft and keep the wheels from being damaged. Limiting drive pressure also puts a lid on EBP to boost delta, helping to extend the life of journal bearings, etc.
If you’re spanking your stock turbo to 40psi daily, you should probably upgrade. But a stock, tuned truck that is normally driven like a responsible adult will not see enough ‘abuse’ to make a substantial difference in reliability/service life.
This is 160/30’s and RDP 4+4 compressor wheel and 360* thrust washer rebuild. Up to about 30psi of boost, EBP/Boost are close to 1:1. It starts getting ugly over 30psi - but that is rare driving conditions.
https://m.youtube.com/watch?v=tc5Zx7sMHYM
Old Apr 14, 2022 | 11:47 AM
  #149
FordTruckNoob
What about doing it with gold safety wire to complement the diamond grillz? Will that make it classy?
Well yes but we know that stock/mildly improved fueling won't be enough to overspeed the turbo.
Old Apr 14, 2022 | 03:48 PM
  #150
smitty59's Avatar
smitty59
I assume the crimps are the two dimples on the sides of the adjusting end of the actuator rod.And yes I know what *** U ME spells!!!!!!LOL
