EBPV delete
Old Apr 14, 2022 | 04:03 PM
  #151
cleatus12r's Avatar
cleatus12r
Butt-Head
Yep, the dimples.
Old Apr 14, 2022 | 05:43 PM
  #152
smitty59's Avatar
smitty59
Thank you my friend.Much appreciated!!!!!
Old Apr 16, 2022 | 07:39 PM
  #153
smitty59's Avatar
smitty59
Any pointers on how to get the big red o-ring to stay on the cold air side of the turbo so I can put it back together?
Old Apr 16, 2022 | 07:51 PM
  #154
SkySkiJason's Avatar
SkySkiJason
Chassis/bearing grease.
Old Apr 16, 2022 | 08:32 PM
  #155
smitty59's Avatar
smitty59
Oh man thank you so much.I wish I had thought of that.
Old Apr 17, 2022 | 01:54 PM
  #156
smitty59's Avatar
smitty59
Happy Easter everyone!Have any of you guys deleted the fuel bowl and if you have what system did you put back in?
Old Apr 17, 2022 | 02:56 PM
  #157
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Happy Easter to you as well sir!
I have not deleted the fuel bowl, but I know that @ESwift has. Perhaps he will be along shortly to answer your questions and address your concerns.
Old Apr 17, 2022 | 04:26 PM
  #158
ESwift's Avatar
ESwift
CNCFAB
I deleted my fuel bowl with a cncfab 4 line feed/bowl delete kit, an airdog II and a g&r sump. All purchased from Cncfab. It is a nice setup, but really no need to delete the fuel bowl. One of those things I did planning on a more extensive build that I decided to refrain from completing. But no fuel bowl makes for working on the hpop a breeze, I can swap pumps in about 20 minutes from stop to running again
My other truck I did the in tank mods, a pre pump filter and then a rebuilt bowl with a cncfab 4 line feed/ bowl retain kit.
Old Apr 18, 2022 | 04:49 AM
  #159
Jamon Norton's Avatar
Jamon Norton
I’ve deleted mine on my 99.5 I did in tank mods with bigger pick up, lines, dual spin on filters, dual Bosch 44 pumps, fuel regulator and a 4 corner feed from cnc fab
Old Apr 18, 2022 | 06:46 AM
  #160
SkySkiJason
Why would you want to delete the factory fuel filter? It does an excellent job of filtering the fuel and removing air that may have entered the system.
Most fuel bowl deletes are a compromise to efficiency, reliability and readily available parts for repair.
Old Apr 18, 2022 | 07:41 AM
  #161
smitty59's Avatar
smitty59
I am greatful to you guys for the info.I will not be deleting the fuel bowl on my truck because I trust you guys!!!!!Always great advice!!!!
Old Apr 18, 2022 | 09:20 AM
  #162
brian42's Avatar
brian42
Veteran: Navy
I have a tube of silicone o-ring lube that I use. Great for holding o-rings in place and keeping them from rolling during re-installation:
O-ring lubrication (dieselorings.com)
Not as much of a effective route like SSJ but that tube has lasted me at least 5 years. I have various greases around but it is convenient to just grab "the tube". YMMV
Old Apr 18, 2022 | 10:32 AM
  #163
smitty59's Avatar
smitty59
brian42 I hate to be a pain but what size drill bit did you use and where did you get the 1/16" NPT plug?I just got back from ACE and HOME DEPOT and neither place knew what I was asking for.Imagine that!!!!!!
Old Apr 18, 2022 | 10:39 AM
  #164
smitty59's Avatar
smitty59
First let me thank ya'll for the advice on the o-ring thing.Funny thing is I tried for thirty minutes to put the new o-ring on without my glases on so my son was here for Easter brunch.I asked him to have a look at it for me.He looked at me kinda funny and said dad the old one is still on there!He pulled it off and installed the new one no problem.I think I will be wearing my glasses from now on.....
Old Apr 18, 2022 | 11:52 AM
  #165
brian42's Avatar
brian42
Veteran: Navy
Some drill bit sizes for making the hole for an NPT fitting are not numbers, they are letters. Most tool stores won't know this unless you find a crusty old gearhead.
You need a "D" drill bit. It is specifically for drilling the hole for tapping a 1/16" NPT fitting.
Here's a chart for future use if you desire:
NPT Tap Drill Chart | DrillsandCutters.com
