EBPV delete
Old May 13, 2022 | 10:27 AM
  #211
SkySkiJason's Avatar
SkySkiJason
Originally Posted by smitty59
What intake do you guys recomend? I currently have a K&N.
Almost anything is better than k&n....
https://www.ford-trucks.com/forums/1...th-extras.html
Old May 13, 2022 | 10:28 AM
  #212
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Stock is good if your other air consuming parts are stock (turbo, injectors, tuning, etc...) as long as the stock box is not broken or damaged and seals well. If you want to upgrade as some of us like to do, your two best bets are the AIS intake (recently discontinued and difficult/expensive to find) or the Donaldson Blue 6637 style intake. Other than that you can get into S&B, Airaid, etc...
You would be best suited with a dry filter over an oiled filter though whichever path you take.
Old May 13, 2022 | 11:11 AM
  #213
RacinJasonWV's Avatar
RacinJasonWV
I’m used to people not taking my advice. It’s just usually not people as smart as you!!
Im kidding!! Nothing wrong with what you did. I just don’t find stuff in the tank that could plug up the pickup - except the failed umbrella pieces. Actually, very seldom does anyone even need to change the WIX 33972.
Yes, this I can agree with for sure.
Originally Posted by brian42
I never had a problem with my pickup tube getting clogged in the 10+ years and ~180K miles I had it installed.
I remember a “recent” (within the last year maybe) issue someone was having after the Hutch. Seems like he ended up having a piece of paper or sticker stuck in the pickup tube.
I agree though it’s unlikely.
Smitty, I too prefer the AIS intake system. Unfortunately they are hard to find now since rumor has it they’ve been discontinued.
Old May 13, 2022 | 01:22 PM
  #214
brian42's Avatar
brian42
Veteran: Navy
I had a 6637 "conversion" forever with no issues on my stock injectors. Simple, pretty cheap, and easy to modify the OEM setup for the bigger filter.
Old May 13, 2022 | 03:44 PM
  #215
smitty59's Avatar
smitty59
Just my luck RacinJasonWV, day late,dollar short........The 6637 sounds like the best bett for me because I don't drive the truck more than mabe 150 miles a month.
Old May 13, 2022 | 04:00 PM
  #216
Sous's Avatar
Sous
FTE Emeritus
If you are going with a 6637 style filter, might I be so bold to suggest a pre-filter cover as seen below in my engine bay and at the link below to Riffraff Diesel. The covers come in a variety of colors. The tube/connection between the filter and the intake tube on my truck is actually the same tube that FTE'r Brian42 owned. He sold it to me when his truck was totaled by a careless Jeep driver.
Link: https://www.riffraffdiesel.com/6637-...t-cover-black/
Old May 13, 2022 | 05:44 PM
  #217
smitty59's Avatar
smitty59
Mr. Sous that is a mighty purty engine bay right there my friend if I do say so myself!!!!! And you may be so bold I respect your advice very much. I will defintely add a sock to the 6637 from RR. Now I just have to find a scrap piece of 4" exaust pipe somewhere????
Old May 13, 2022 | 05:54 PM
  #218
brian42's Avatar
brian42
Veteran: Navy
You can ask around at your local exhaust shops that work on diesels if they have some scrap 4" piping lying around.
It cost me a little more than what others invested but this is what I bought 10+ years ago and it's still living today in Sous' truck:
Amazon.com: Spectre Performance 9709 4" Straight Aluminum Intake Tube : Automotive Amazon.com: Spectre Performance 9709 4" Straight Aluminum Intake Tube : Automotive
Old May 13, 2022 | 07:23 PM
  #219
RacinJasonWV
Grab the Donaldson Blue filter while ordering that cover. Riffraff also sells a kit, but with just a pipe and clamp you can piece this together cheaper.
Donaldson Blue Filter
Old May 14, 2022 | 06:46 AM
  #220
smitty59's Avatar
smitty59
Thanks ya'll Donaldson Blue is out of stock at RR but it is on order with brian42's 4" aluminum and blue cover so thanks again!!!!!!
Old May 15, 2022 | 07:27 PM
  #221
smitty59's Avatar
smitty59
Hey SSJ does Copper Coat hold the gaskets on the ends of the oil cooler?
Old May 16, 2022 | 06:40 AM
  #222
SkySkiJason
It can. Easier to use a helper if you have that option.
Old May 16, 2022 | 09:09 AM
  #223
smitty59's Avatar
smitty59
Ok thanks my friend.
Old May 16, 2022 | 05:43 PM
  #224
smitty59's Avatar
smitty59
Old May 16, 2022 | 05:47 PM
  #225
smitty59's Avatar
smitty59
