EBPV delete
Old Jun 2, 2022 | 02:19 PM
  #256
smitty59's Avatar
smitty59
Yessir I know that you are right but a man can dream. Other than the leaks the engine is a hoss and I think I will keep it around for as long as I am able to work on it and when I can't it will be up to my son as to what to do with her. I got the oil cooler back on so time will tell if she is fixed or not and if I have to spring for a new set of gaskets......
Old Jun 4, 2022 | 05:15 PM
  #257
smitty59's Avatar
smitty59
Oh man, I put the Strickly Diesel dipstick adapter on the 7.3 today. D A N G!!!!!! that was a job and a half.....but it's done now. I hope I don't have to worry about that again. The starter is back on and hocked up. Getting closer. Also a little up top.
Old Jun 6, 2022 | 02:19 PM
  #258
SkySkiJason's Avatar
SkySkiJason
If you paint the alternator/PS pump bracket, you’ll want to clean the contact points with alternator and block. The alternator grounds through its body, through bracket, then block and back to battery.
Old Jun 7, 2022 | 07:18 AM
  #259
smitty59's Avatar
smitty59
Oh man thanks SSJ, I just installed that bracket Sunday.... I will have to uninstall and clean the points you told me about.. I had no idea so thanks again my friend
Old Jun 7, 2022 | 07:24 AM
  #260
FordTruckNoob's Avatar
FordTruckNoob
Not as critical on the passenger side bracket since that is for the AC compressor. Still a good idea to clean contact surfaces to avoid galvanic corrosion issues though.
Old Jun 7, 2022 | 12:14 PM
  #261
smitty59's Avatar
smitty59
Will do ,thank you
Old Jun 12, 2022 | 05:22 PM
  #262
smitty59's Avatar
smitty59
I'm almost done!!!!!!!!
Old Jun 12, 2022 | 05:39 PM
  #263
smitty59's Avatar
smitty59
Old Jun 12, 2022 | 10:10 PM
  #264
RacinJasonWV's Avatar
RacinJasonWV
Looking good!
Old Jun 13, 2022 | 06:22 AM
  #265
SkySkiJason
4-legged helper appears to approve!
Looks great man!
Old Jun 13, 2022 | 07:43 AM
  #266
FordTruckNoob
I'm loving the touch of blue on the alternator bolt heads. Now you have to do all the other visible bolt heads for the AC compressor, HPOP reservoir, plenums......
Old Jun 13, 2022 | 07:59 AM
  #267
V-22 Osprey's Avatar
V-22 Osprey
Finish line in sight…like we are ever finished!
Old Jun 13, 2022 | 08:12 AM
  #268
smitty59's Avatar
smitty59
Hahaha!!!! The bolt heads on the alternator were a mistake Yeah SSJ the little man in the backround is in my son's shadow wherever he goes. He is a rescue that my son found at my hunting camp that someone had abandonded,dirty and starving....Scooter has been with us now for about 3 and a half years.
  #269
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Definitely in the running for best looking engine bay of 2022.
Old Jun 13, 2022 | 08:18 AM
  #270
smitty59's Avatar
smitty59
Amen V-22 Osprey A-M-E-N!!!!!!!
