EBPV delete
Old Jun 25, 2022 | 08:32 AM
  #301
Kwikkordead's Avatar
Kwikkordead
Originally Posted by smitty59
I don't remember where I got the gaskets because I have ordered every single part on the NET because of where I live.....But this time I know I ordered them from RiffRaff Diesel!! I will install them today. I am cconfused because the first time I installed the cooler I used Permatex High Tack Gasket Sealant on one side of the gasket to hold the gasket in place while I installed it and it leaked. I removed it and put the sealant on both sides of the gasket and still a leak?????
I HATE PERMATEX. Use on any sort of rubber o-ring style gasket, even if it's square, a thin coating of plumber's faucet lube or silicone grease. All you need is enough to make it slick and give it the ability to "squirm around" in the valley and adapt to the heating and cooling of the parts that are mated together and seal it all up. Petroleum based grease has the potential of swelling an o-ring designed to work in an aqueous environment such as a cooling system due to the materials that it is made of. Using this method I've NEVER had a coupling leak for a very long time, if ever.
Old Jun 25, 2022 | 08:49 AM
  #302
smitty59's Avatar
smitty59
So don't use vaseline on the o-rings inside the oil cooler when I put the ends on the tube?
Old Jun 25, 2022 | 02:32 PM
  #303
smitty59's Avatar
smitty59
!!!!!!!SUCCESS!!!!!!! I got the oil cooler put back on with the new Ford OEM gaskets and no leaks. Started her up and after about 5 minutes in stock mode she is running pretty smooth. I have to put the right fender liner back in tomorrow and take her for a drive but I think she is pretty good. I want to thank all of you guys that helped me through this fiupgrade) I will keep you posted on the results of the build. Thanks again!!!!!!!
Old Jun 25, 2022 | 02:39 PM
  #304
smitty59's Avatar
smitty59
Old Jun 25, 2022 | 03:21 PM
  #305
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Outstanding news and we look forward to the test drive update.
That is a very nice looking engine bay. Attention to detail and the little things make a big difference.
Old Jun 25, 2022 | 04:47 PM
  #306
ESwift's Avatar
ESwift
CNCFAB
The drivers side intercooler pipe in backwards?
Old Jun 26, 2022 | 11:38 AM
  #307
Rot Box 2's Avatar
Rot Box 2
I’m embarrassed to pop my hood now! Wow that’s a nice engine bay
Old Jun 26, 2022 | 01:38 PM
  #308
smitty59's Avatar
smitty59
I am going to have to take a second look at the charge pipes hahaha. I think I may have them switched up now that you mention it!!!!!! Too funny
Old Jun 26, 2022 | 04:39 PM
  #309
smitty59's Avatar
smitty59
Happy to report the drivers side charge pipe was on and in the correct spot but I routed it on top of the power steering pump instead of below the ps pump. Thanks to SSJ in one of his post he had a picture that I could refer back to so that I could route it correctly. I will post a pic tomorrow of the corrected routing. Thank you for pointing that out to me!!!!!!
Old Jun 26, 2022 | 06:01 PM
  #310
Sous's Avatar
Sous
FTE Emeritus
If that is the only thing that was screwy after all of that, then you "done did good."
Old Jun 26, 2022 | 07:25 PM
  #311
RacinJasonWV's Avatar
RacinJasonWV
It’s pretty and all, but how’s it running now?!?
Old Jun 26, 2022 | 07:47 PM
  #312
z31freakify's Avatar
z31freakify
Could of kept it there vato, now that pretty blue paint is hidden.
Old Jun 27, 2022 | 07:14 AM
  #313
smitty59's Avatar
smitty59
I haven't taken her out yet for a test drive. I was putting the fender liner back in yesterday and whille I had the wheel off I looked down at the brake pads and realized it was time for a new set. Of course like everything else on her I had a hard time getting the drivers side wheel off. When I did the caliper slider rod was frozen up so after about an hour of beating and trying to get it out we(my son and I) got the torch out and heated it until it gave up. We went to Advance Auto and got the pads but of course they didn't have the rods or the rubber dust covers so I have to go to a different city to pick them up today. I will let ya'll know how she runs soon, I HOPE!!!!! And the charge pipe looks alot better in it's 'possed to be position. It did look ridiculous where it was before
Old Jul 10, 2022 | 11:23 AM
  #314
smitty59's Avatar
smitty59
z31freakify which way did you mean vato?
Old Jul 12, 2022 | 05:28 AM
  #315
FordTruckNoob's Avatar
FordTruckNoob
I am actually beginning to wonder if having the hot CAC pipe go over the PS pump is the superior way to route it. It avoids rubbing the PS pump's output hose fitting.
