4WD conversion
Out of cusiosity I just went to the Vivid Racing website and can't find the kit that he posted either, or at least it doesn't come up in a search for 99-00 F-250 lift or leveling kits.
Just for now anyway. Here is just about the only e99 adjustable track bar I can find. It looks like it's well made. It'll be a bit before it gets here though. I think the spacers will work for the time being until this gets here. I haven't ordered it yet. Thanks!
https://www.amazon.com/Forged-Track-.../dp/B07XLTZGZV
Joel, someone used more force than Tristan had available to get that track bar on the donor truck. It’s much easier to take track bar off than put it back on - every time.
3” lift is just barely beyond what works easily with stock length track bar. You’ll see the ‘mini-spring packs’ at ‘2.8” lift’ for this reason. Even then, the compromise is the axle is not centered under the truck.
Tristan, you will not be able to ‘space the track bar down’ with simple spacers. The complex shape and odd angles prevent the easy fix your dad has proposed.
It also appears the sway bar end links are longer than stock E99. Maybe they are L99 with the E99 style frame mounts? Either way, there may be other challenges to just ‘removing the lift components’. I feel like modifying your track bar is the most economical option you have right now. Cut the track bar you have now and add a sleeve of heavy wall tubing over it, then weld it back together at the length you need.
Like I said in a text yesterday, you can drive the truck without track bar or rear blocks if you need transportation. Just let your britches hang down if you don’t put the rear blocks in - you’ll fit in with the brodozers better that way. Bump steer and ‘death wobble’ is possible, but not likely a problem on a drive you could ride your bicycle on.
I also figured it would be a pain to remove the front shackle extensions and try to line the leaf springs back up with the longer rear hangers. Again I apologize for my ignorance and I do not know that this is true.
There is no reason to apologize or feel bad. I was/am in no way trying to come off as mad, a jerk, or annoyed. It's cool you're taking on this project with no experience....we all started somewhere.
I eat, sleep, and dream everything 7.3L and have been modifying them for years. I started like you.....diving into the unknown.
Good luck with whatever you decide to do with it from this point!
It was a good idea anyway!
Now that you mention it, my end links do look a lot different than Joel's. With these sleeve of tubing be the length of the track bar or just long enough to reattach it with some overhang?
I may just do that. Length in the track bar that is. I will see what I can come up with. I have called all the jobs I was supposed to be at today and informed them that I may be late a day or so. The schedule is clear for today so that I may get the truck on the road properly!
Cut in the middle, put a piece of tubing over, weld in a spacer to the bar, grind to size, slide the tubing over, then weld on the tubing.
The track bar is not a critical component so....
Do what you need to do.
Not gonna lie, I did the same to a draglink on a previous pickup I lifted 21" that ran 49" tires. Not proud of it but I was a dumb kid at the time. I did the track bar and sway bar links the same way.
Don't do the draglink.....NOT SAFE.
Arigato! (Japanese for thanks)
For those who don’t know, Hyakkimaru is an anime character.
The upper bracket bolts sheared off in the wreck so taking it apart was fairly easy. Gravity helped!
Tristan, I can't wait to see you and your lifted 4x4 at the next GTG! I can just see you grinning ear to ear as we all get to see the results of all your hard work.
And I'm proud to be a part of this awesome community of 7.3 lovers who step in to help one another like this.
Now if only there was this kind of support for computer nerds who moves their office PC to another case so they can build a file server resulting in a dead office computer. Which runs their business...
