4WD conversion
Old Jan 22, 2022 | 01:29 PM
  #316
Hyakkimaru's Avatar
Hyakkimaru
Which bar do you need to know about? I don’t know the answer but can brave the cold long enough to go get you a few photos if it would help. You asking about the sway bar?
I meant to put a picture in the other post! The main end link itself. It's got curves in it. I just don't know which way it goes. Thanks!
  #317
petrokiller's Avatar
petrokiller
Great progress you have made Your Purple Highness!!
LMAO
Hope you can lift the truck a few more inches easily.
You could also let alot of air out the tire if needed.
Bee you tee full sunny cool day here in the 40s now.
Hope it's better weather there for you.
Old Jan 22, 2022 | 01:31 PM
  #318
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The orientation of the end links can be confusing. You are not alone in wondering which way is up.
I'm hesitant to respond, because you have the older design, and while I can always refer to the newer design under my truck, I don't remember much about the endlinks in the older design... only that the pillow blocks were stamped and below the frame flange (versus castings nested above the frame flange) and the heat shielding added to protect the grease seal membrane from heat exposure of the down pipe.
Old Jan 22, 2022 | 01:49 PM
  #319
runningman777's Avatar
runningman777
I sent you this via text, but here it for everyone else. This is the passenger side on my e99 F350 4x4.
Old Jan 22, 2022 | 01:54 PM
  #320
Hyakkimaru's Avatar
Hyakkimaru
LMAO
Much better weather today! Sunny, no wind and somewhere in the 40s to 50s for the high today! Unfortunately I don't think I can let quite that much air out of the tire...
Old Jan 22, 2022 | 02:05 PM
  #321
RacinJasonWV's Avatar
RacinJasonWV
I will not get a photo unless you want me to. Based on Y2K’s info about the newer being different and the fact that runningman already shared the correct photo it seems mine may just add confusion.
Old Jan 22, 2022 | 02:07 PM
  #322
Hyakkimaru's Avatar
Hyakkimaru
Don't worry about it! Thank you for helping regardless! I got it taken care of! I have the driver side shock tower on and I am on the rear bolt of the leaf spring. After that I'll put the sway bar in and then my front axle!
Old Jan 22, 2022 | 02:09 PM
  #323
runningman777
You will be stretching them legs to get in that truck...good thing you got your new running boards!
Old Jan 22, 2022 | 02:10 PM
  #324
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
And he'll be wheeling by sun down.
And on the 7th day, he rested.
Hail to our Purple Highness!
Old Jan 22, 2022 | 03:05 PM
  #325
Hyakkimaru's Avatar
Hyakkimaru
for some reason my phone double posted. Ignore this reply
Old Jan 22, 2022 | 03:08 PM
  #326
Hyakkimaru's Avatar
Hyakkimaru
Well, I ordered a pitman arm for a four-wheel drive 32 splined e99, turns out the e99 4x4 pitman arm is a smaller diameter 32 spline. About 1/8 in different. Basically I have to get another steering gear like Jason said. They don't make a pitman arm that'll fit on the splines of my steering gear. It is what it is. Sway bars in. Getting ready to Jack the truck up some more and put the front end on.
Old Jan 22, 2022 | 03:37 PM
  #327
FordTruckNoob's Avatar
FordTruckNoob
JB Weld and duct tape solves all problems.
Old Jan 22, 2022 | 03:49 PM
  #328
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I bought a steering gear at AutoZone when I had a failure while traveling. It was a piece of crap that was loose and leaked from day one, but it got me back on the road and it worked as a core return for a BlueTop. Not ideal, but if you need a gear like yesterday, that is an option.
Old Jan 22, 2022 | 03:51 PM
  #329
petrokiller
Zip ties will hold it in addition to Leonard parts list.
Wonder if they would take your 2wd gear box as a core at BlueTop?
If you have to Google 20% off coupon for advance auto.
Ya know if ya gotta get a local gear for know
Old Jan 22, 2022 | 04:33 PM
  #330
cleatus12r's Avatar
cleatus12r
Butt-Head
Not to be a postwh*re but this is next week's (unless the schedule fills up) conversion. Same 2wd regular cab........
but different......
