F250 Project
Old May 8, 2020 | 09:09 PM
  #196
Red60's Avatar
Red60
Another victory
The vent covers are a small victory but the machinist called to say my heads and dynamic balance is 100% complete! Its Friday on Mothers day weekend so maybe I will get my engine parts next week. That is exciting if I can build my motor soon!!
Old May 13, 2020 | 03:48 PM
  #197
Red60's Avatar
Red60
289 Heads
Update! Got all the machinist work back and I am excited! All new and ready to rumble!
All staimless oversized valves
Hardened seats
screw in studs
all new valve guides
Teflon stem seals
hardened keepers
cam matched double springs
spring perches machined to correct height
One sad note...
Waiting on my new cam! The one I want uses Winsor firing order and he accidentally ordered the standard 302 firing order.
0.065 between the valves and intake is flush with the combustion chamber. They look maximized! 58cc chambers should yield 11:1
Old May 13, 2020 | 07:32 PM
  #198
spurredon's Avatar
spurredon
Man, they look great! Nothing like using old iron.
Old May 17, 2020 | 03:43 PM
  #199
Red60's Avatar
Red60
Wheel cleanup on street set
The wheels need cleaned up with new paint. Opinions on black center vs plain white?
Original minus rusting wheel hubs
Stainless added to original
Black center and stainless
No matter what I do they need paint! Also considered blue center to match truck color.
After I save up for a while offroad 33’s look better in the wheelwell but they cost more than a mortgage payment!
Old May 17, 2020 | 04:44 PM
  #200
JohnNewb's Avatar
JohnNewb
black really dresses them up. Color match would probably look good too.
Old May 17, 2020 | 06:24 PM
  #201
spurredon's Avatar
spurredon
I like the black. Color match can be a little too pretty in my opinion. All black might be nice.
Old May 17, 2020 | 06:54 PM
  #202
Red60's Avatar
Red60
A little too pretty meaning not tough guy? Or??
LOL
Old May 19, 2020 | 07:57 PM
  #203
spurredon's Avatar
spurredon
LOL
I guess, maybe too nice. Not flowing with the utility vibe of the truck. Or?? lol
Old May 19, 2020 | 08:19 PM
  #204
Red60's Avatar
Red60
I agree! Too indistinct and sort of a cop out. Nothing against those who color match, but my build needs independence and strength! Not to mention fiscally conservative...
Old May 19, 2020 | 08:24 PM
  #205
Red60's Avatar
Red60
I cant help myself... they are so awesome!
For my build these were a big cahuna! Bear with me, the motor build is soon... Friggin C19 and freight delays!
Old May 19, 2020 | 08:34 PM
  #206
JohnNewb's Avatar
JohnNewb
So if the truck is a manly color like charcoal grey or dark blue, color match ok. If not you nay get beat up at gas station. I do like the black center. It changes the look completely of the generic white rims. I had same rims on a jeep when I wanted oversized tires. Didn't want to spend a fortune. Also parked jeep in remote desert areas while hiking hills and didn't want to tempt anyone.
Old May 19, 2020 | 08:36 PM
  #207
spurredon's Avatar
spurredon
They really are nice. The head surface looks almost velvety. I have a 302 block, heads and crank at the machine shop right now. been there for a week. The guy is good so he is swamped. Buy anyway, I will be fondling it a bit when I get it back. lol
Old May 23, 2020 | 08:26 PM
  #208
Red60's Avatar
Red60
I welded up 8 holes in the tailgate. Why would anyone drill 8 holes in these truck gates??
two sets of four holes. Anyone know of period specific brackets that were used on the tailgate of these trucks?!?
It looks like I will be welding up the passengers step for similar swiss cheese. Not rust, drilled 3/8-1/2” holes!!!
Old May 23, 2020 | 09:27 PM
  #209
Red60's Avatar
Red60
I’ve leaned welding holes is hard because of my lack of patience. Of course I burned through on half of them! More practice to come. Both bolts holding the hinge on broke instead of coming loose... same thing I feel will happen on the fender bolts but limited access (PITA). Who can give me pointers so its easier?!?
Old May 23, 2020 | 10:03 PM
  #210
JohnNewb's Avatar
JohnNewb
The fender to cab is pretty easy. Lots of PB Blaster rust penetrant first. Those six nuts, two radiator support bolts, and the inner fender to firewall straps, and two nuts on fenders and front clip comes off as a unit. Easier to access all those bolts holding fenders, grille, valance, radiator support off truck.
