F250 Project
Old Sep 5, 2020 | 05:51 PM
  #286
spurredon's Avatar
spurredon
Originally Posted by Red60
Motor is setting in its home motor mounts secured... All thats left is everything else. LOL
Finally in correct position!
Congrats, it has been awhile for you. I know the feeling. I am still fighting with the bell housing bolts on my '93! That thing looks great by the way.
Old Sep 6, 2020 | 05:29 PM
  #287
Red60's Avatar
Red60
Custom clutch slave cylinder hydraulic line installed and ready to be secured. Next is bleed-out procedures...
Old Sep 6, 2020 | 06:55 PM
  #288
spurredon's Avatar
spurredon
You really got me with the flex hose down low like that.
Old Sep 6, 2020 | 10:40 PM
  #289
Red60's Avatar
Red60
I figure the engine will have the most movement relative to the frame/cab. The cab and frame flex but rubberized clamps should allow smaller movements than engine torque motor movements... Does anyone else see anything I might be overlooking (before I fill and bleed the system)?
Old Sep 7, 2020 | 06:02 PM
  #290
Red60's Avatar
Red60
Clutch now activates with the pedal!
I also primed the oil and it shows 50-60PSI
Started accessory installation, getting too hot to work comfortably so hopefully more this evening.
Old Sep 7, 2020 | 07:36 PM
  #291
spurredon's Avatar
spurredon
I like that dark Blue on the rocker covers. "Old Ford Blue", I should say. The same color as your blood. lol
Old Sep 8, 2020 | 04:29 PM
  #292
Red60's Avatar
Red60
Wind/forest fires/power outages = no progress but at least not under evacuation yet...
Old Sep 8, 2020 | 04:38 PM
  #293
JohnNewb's Avatar
JohnNewb
Where are you located,? We are smoked out from the two big fires east of Los Angeles. Neither is close to us here in the desert.
Old Sep 8, 2020 | 07:10 PM
  #294
Red60's Avatar
Red60
Oregon in the east side of the valley in the foothills. west of the big fires traveling west.
Old Sep 8, 2020 | 07:13 PM
  #295
spurredon's Avatar
spurredon
Wow, that is impressive. Sure hope you get some soaking rain.
Old Sep 8, 2020 | 07:56 PM
  #296
JohnNewb's Avatar
JohnNewb
You have us beat. I thought it was all California.
Old Sep 19, 2020 | 09:45 PM
  #297
Red60's Avatar
Red60
Home from fire evacuation last Sunday. Got some time this weekend to weld brackets. Dana 24 shifter bracket, transmission and bracket are cut, welded, painted and installed! The tunnel cover needed the shifter hole moved forward and is done but the paint is drying. I still need to work out the exhaust as a last conversion to work out.
Dana 24 divorced transfer case shifter originally bolted to the side of a T98 transmission so a bracket was required for this new process transmission.
Transmission bracket was kept simple too since it only needed 1” drop below the frame
Old Sep 20, 2020 | 06:29 PM
  #298
spurredon's Avatar
spurredon
Glad you are back at your place and it is still there. Great to see some progress pics. No question it should be strong.
Old Sep 21, 2020 | 09:13 PM
  #299
Red60's Avatar
Red60
The driveline between the transmission and transfer case needed TLC. Its now clean and black. New u-joints tomorrow.
The transmission shifter hole had to move 2.25” forward.
Old Sep 22, 2020 | 07:06 PM
  #300
spurredon's Avatar
spurredon
That will be rolling under it's own power soon.
