Another build thread
Old May 21, 2020 | 10:11 PM
  #166
7.3 forever's Avatar
7.3 forever
Honestly I don’t have problem with that at all but I’m on such a tight schedule trying to get this and another truck done. All before July 11 I haven’t had much time for other stuff but some time Thad be great for sure.
Old May 22, 2020 | 02:22 PM
  #167
Hit Man X's Avatar
Hit Man X
Thumbs up
Originally Posted by 7.3 forever
Also curious on another thing the fluid damper came with a fan clutch spacer. Has anyone ran this setup without spacer with a 6.0 plastic fan?
I had to use the spacer with the OE steel fan, I am curious what you find...as I would prefer a lighter mass fan that moves more air.
Also, just about impossible to R&R the belt with the water pump pulley. Toss a SD one on (smaller so moves more coolant and more air through radiator and condenser) OR toss the 94-97 style on a lathe and remove some material. I did the SD one, no issues with stock belt or belt slip.
Old May 23, 2020 | 09:53 PM
  #168
7.3 forever
Well so far got the block cleaned primered and painted black also got valve covers and oil pan powder coated. Hopefully tomorrow I’ll get the timing cover cleaned reinstalled and mostly assembled if all goes well
Old May 25, 2020 | 05:03 PM
  #169
7.3 forever
Well got a lot done just not all I wanted to but definitely getting closer all new rail plugs. Full force diesel rail inserts and Mark Fugazzotto topside efuel installed. New melling lpop very close to being ready to install.
Old May 25, 2020 | 10:01 PM
  #170
BBslider001's Avatar
BBslider001
Nice work! Hope it runs as good as it looks!
Old May 25, 2020 | 10:49 PM
  #171
7.3 forever
Thanks I sure hope it does to we will see though.
Old May 26, 2020 | 09:05 AM
  #172
97-psd's Avatar
97-psd
It is coming together now. It should be a strong puller
Old May 31, 2020 | 01:11 AM
  #173
7.3 forever
Well got my oil cooler resealed and cleaned today along with my rear engine plate resealed. Also got the new rear main installed starting to really come together.
Old May 31, 2020 | 08:34 AM
  #174
BBslider001
BOOM. Is that a RiffRaff Banjo bolt? ANy noticeable difference? I have always wondered.
Old May 31, 2020 | 08:49 AM
  #175
7.3 forever
The holes in the banjo bolt are probably 3times the size or better. My main issue was I wanted to reseal the oe banjo bolts but It was during week while I was ordering stuff. And there is two different styles of oem banjos apparently so I just decided to upgrade which I’m really happy with.
Old May 31, 2020 | 10:39 AM
  #176
nateairman's Avatar
nateairman
The third photo from the top with the riff raff laser engraved bolt. Is this the banjo bolt? Are they on the back of the head as well?
And what does it seal?
Edit:
Nevermind! I looked it up on riffraff.
Old May 31, 2020 | 11:12 AM
  #177
7.3 forever
Yeah I installed them in front and in rear I didn’t know which style banjo bolts I had. And didn’t know which orings I needed and just decided to order for front and rear. I know totally not needed but figured why not. At this point anyway. I’m already this deep down the rabbit hole didn’t see any harm now.
Old May 31, 2020 | 08:56 PM
  #178
nateairman's Avatar
nateairman
The only regret I have is not doing the rear main and resealing the plate. I suspect I have a leak somewhere around there.
Old May 31, 2020 | 09:33 PM
  #179
7.3 forever
I considered not doing the rear plate but just couldn’t let myself not while I was there to easy to do while out not to.
Old May 31, 2020 | 09:36 PM
  #180
7.3 forever
Well got last coat of paint on pretty much ready to install the oil pan now
